    Bullseye
    45 Posts 8 Posters 26.1k Views 9 Watching
      sdetweil @BKeyport
      @bkeyport yeh, I installed nvm, then installed 14 and it was ok… then switched to 17 with nvm and its ok…
      not sure how to correct script yet
        I have updated the scripts… for bullseye…
        give it a try
        in each of the urls, replace master with bullseye to get the latest version
        for example install
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
        replace master
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/bullseye/raspberry.sh)"
        raspiberry.sh, fixuppm2.sh and screensaver.sh have been updated
        let me know
        • BKeyportB Offline
          Installing helper tools ...
          Updating packages ...
          [     <=>        ]Check current Node installation ...
          Node.js is not installed.
          Installing Node.js ...
          chmod: cannot access '/usr/share/doc/nodejs/api/embedding.json.gz': No such file or directory
          Reading package lists... Done
          Building dependency tree... Done
            libc-ares2 libjs-highlight.js nodejs-doc
          Use 'sudo apt autoremove' to remove them.
          The following NEW packages will be installed:
            nodejs
          0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
          Need to get 0 B/22.9 MB of archives.
          After this operation, 116 MB of additional disk space will be used.
          Selecting previously unselected package nodejs.
          (Reading database ... 99829 files and directories currently installed.)
          Preparing to unpack .../nodejs_14.18.1-deb-1nodesource1_armhf.deb ...
          Unpacking nodejs (14.18.1-deb-1nodesource1) ...
          dpkg: error processing archive /var/cache/apt/archives/nodejs_14.18.1-deb-1nodesource1_armhf.deb (--unpack):
           trying to overwrite '/usr/share/doc/nodejs/api/embedding.json.gz', which is also in package nodejs-doc 12.22.5~dfsg-2~11u1
          dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
          Errors were encountered while processing:
          E: Sub-process /usr/bin/dpkg returned an error code (1)
          node version is bash: line 227: node: command not found
          bash: line 229: node: command not found
          Node.js installation Done! version=
          /usr/bin/env: ‘node’: No such file or directory
          Minimum npm version: V6.0.0
          Installed npm version: V
          npm should be upgraded.
          Installing npm ...
          E: Unable to correct problems, you have held broken packages.
          npm installation Done! version=V
          Cloning MagicMirror ...
          Cloning into 'MagicMirror'...
          remote: Enumerating objects: 325, done.
          remote: Counting objects: 100% (325/325), done.
          remote: Compressing objects: 100% (290/290), done.
          remote: Total 325 (delta 53), reused 146 (delta 22), pack-reused 0
          Receiving objects: 100% (325/325), 477.94 KiB | 4.78 MiB/s, done.
          Resolving deltas: 100% (53/53), done.
          Cloning MagicMirror Done!
          touch: cannot touch '/etc/chromium-browser/customizations/01-disable-update-check': No such file or directory
          Installing dependencies ...
          Unable to install dependencies!
          log added to issue…
            sdetweil @BKeyport
            @bkeyport wonderful…
              sdetweil @BKeyport
              @bkeyport think I fixed it… give it a try, still bullseye in the urls
              • bugsounetB Offline
                bugsounet Banned @sdetweil
                @sdetweil said in Bullseye:
                @bert269 we need node 14 for MM… the bullseye is only node 12
                are you sure ?
                  sdetweil @bugsounet
                  @bugsounet i get v12.22.5 right after boot up, image downloaded yesterday
                    sdetweil @bugsounet
                    @bugsounet did u select yes to install updates during setup? I selected no… do it later
                    reflashing SD card now.
                      I get on 1st boot after config, enabling ssh , and setting hostname
                      node -v
                      v12.22.5
                      cat /etc/apt/sources.list.d/nodesource.list
                      cat: /etc/apt/sources.list.d/nodesource.list: No such file or directory
                      ls /etc/apt/sources.list.d
                      raspi.list vscode.list
                        bugsounet Banned
                        curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                        can help ?
                          sdetweil @bugsounet
                          @bugsounet i got it in the latest script… different approach, but understand
                          • O Offline
                            OberfragGER @sdetweil
                            Sorry for asking but i dont get the point.
                            1 day before the release of Bullseye i installed busetr an used your script to get MM working. That worked flawless. Glad i made a backup then with my config.
                            Days later, i upgraded to Bullseye and MM was not working any longer. I thought due some autostart things or something like that.
                            When i now make a fresh bullseye install and use your script- is that working? No, or?
                              sdetweil @OberfragGER
                              @oberfragger yes, if you use the bullseye adjusted url (note the word master is replaced by bullseye i the url)
                              I don’t want to break the current version while we test this out…
                              I just updated the instructions with this link
                                DJBOOB66
                                Ok i tried
                                And it did not work. What I did was use the master version then rename MM folder after install then use above code and then it work?
                                  sdetweil @DJBOOB66
                                  @djboob66 can u post the ~/install.log?
                                    DJBOOB66
                                    I have to do it again but will do it as soon as i can or is log found on file and were?
                                    • BKeyportB Offline
                                      @sdetweil Failed all over the place.
                                      I’ll upload install.log, then nuking card and starting over.
                                        sdetweil @BKeyport
                                        @bkeyport did u use the bullseye link ?
                                        before then if u used the old link, things get messed up w no recovery (well there is but it’s half an hour of ugly work)
                                        reflash
                                        • BKeyportB Offline
                                          @sdetweil Yes, I used the bullseye link. installing a new card now.
                                            DJBOOB66
                                            the install went without problem this time only thing did diff was i SSH not VNC will test VNC install and see if error.
                                            the only think i get is
                                            “Installing dependencies …
                                            npm WARN deprecated @stylelint/postcss-markdown@0.36.2: Use the original unforke d package instead: postcss-markdown
                                            npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older v ersions may use Math.random() in certain circumstances, which is known to be pro blematic. See https://v8.dev/blog/math-random for details.
                                            npm notice created a lockfile as package-lock.json. You should commit this file.
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^2.3.2 (node_modules/je st-haste-map/node_modules/fsevents):
                                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@ 2.3.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”} )
                                            npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta | | >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dep endencies yourself.”
                                            Do i need to fix anything??
                                            Hope this helps.
                                            • 2 / 3
