    Bullseye
    45 Posts 8 Posters 26.8k Views 9 Watching
    • bugsounetB
      bugsounet Banned
      curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
      can help ?
        sdetweil @bugsounet
        @bugsounet i got it in the latest script… different approach, but understand
        • O
          OberfragGER @sdetweil
          Sorry for asking but i dont get the point.
          1 day before the release of Bullseye i installed busetr an used your script to get MM working. That worked flawless. Glad i made a backup then with my config.
          Days later, i upgraded to Bullseye and MM was not working any longer. I thought due some autostart things or something like that.
          When i now make a fresh bullseye install and use your script- is that working? No, or?
            sdetweil @OberfragGER
            @oberfragger yes, if you use the bullseye adjusted url (note the word master is replaced by bullseye i the url)
            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/bullseye/raspberry.sh)"
            I don’t want to break the current version while we test this out…
            I just updated the instructions with this link
              DJBOOB66
              Ok i tried
              And it did not work. What I did was use the master version then rename MM folder after install then use above code and then it work?
                sdetweil @DJBOOB66
                @djboob66 can u post the ~/install.log?
                  DJBOOB66
                  I have to do it again but will do it as soon as i can or is log found on file and were?
                  • BKeyportB
                    @sdetweil Failed all over the place.
                    I’ll upload install.log, then nuking card and starting over.
                      sdetweil @BKeyport
                      @bkeyport did u use the bullseye link ?
                      before then if u used the old link, things get messed up w no recovery (well there is but it’s half an hour of ugly work)
                      reflash
                      • BKeyportB
                        @sdetweil Yes, I used the bullseye link. installing a new card now.
                          DJBOOB66
                          the install went without problem this time only thing did diff was i SSH not VNC will test VNC install and see if error.
                          the only think i get is
                          “Installing dependencies …
                          npm WARN deprecated @stylelint/postcss-markdown@0.36.2: Use the original unforke d package instead: postcss-markdown
                          npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older v ersions may use Math.random() in certain circumstances, which is known to be pro blematic. See https://v8.dev/blog/math-random for details.
                          npm notice created a lockfile as package-lock.json. You should commit this file.
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^2.3.2 (node_modules/je st-haste-map/node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@ 2.3.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”} )
                          npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta | | >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dep endencies yourself.”
                          Do i need to fix anything??
                          Hope this helps.
                            sdetweil @DJBOOB66
                            @djboob66 no, nothing to fix
                            • BKeyportB
                              On new card it worked flawlessly. I’m assuming the old conditions of partial installs and whatnot had the old install broke things.
                              Nothing but warnings about depreciated modules.
                                sdetweil @BKeyport
                                @bkeyport said in Bullseye:
                                that we can’t do anything about. not our code
                                • AssassinsA
                                  Assassins
                                  Dont Update, Bulleyes is so much slow, and it not drive 100% yet.
                                  Buster work 100%, and much faster
                                    sdetweil @Assassins
                                    @assassins on what device? pi4 seems faster
                                    pi3 seems slower
                                    AssassinsA 1 Reply Last reply Reply Quote 0
                                    • AssassinsA
                                      Assassins @sdetweil
                                      Both, pi3+ is much slower, and pi4 8gb is a little bit slower, But restart Big time hole time, so i mean Bulleyes is not 100% y’et, But Buster run without trouble on both.
                                      • BKeyportB
                                        BKeyport Module Developer @Assassins
                                        An FYI to the issues within Bullseye. If you’re using OMX, it won’t work by default in Bullseye, and as it’s depreciated, we’re kinda on our own. Basically, They’ve gone through and renamed most of the libraries used by OMX.
                                        Issue these commands in a sudo session to get OMX to work until you figure out a new video streaming solution:
                                        cd /usr/lib/arm-linux-gnueabihf
                                        ln -s libmmal_core.so.0 libmmal_core.so
                                        ln -s libmmal_util.so.0 libmmal_util.so
                                        ln -s libmmal_vc_client.so.0 libmmal_vc_client.so
                                        ln -s libbcm_host.so.0 libbcm_host.so
                                        ln -s libvcsm.so.0 libvcsm.so
                                        ln -s libvchiq_arm.so.0 libvchiq_arm.so
                                        ln -s libvcos.so.0 libvcos.so
                                        curl -sSfLO 'https://raw.githubusercontent.com/raspberrypi/firmware/master/opt/vc/lib/libbrcmEGL.so'
                                        curl -sSfLO 'https://raw.githubusercontent.com/raspberrypi/firmware/master/opt/vc/lib/libbrcmGLESv2.so'
                                        curl -sSfLO 'https://raw.githubusercontent.com/raspberrypi/firmware/master/opt/vc/lib/libopenmaxil.so'
                                        – B
                                        • 2 / 3
