    Bullseye
    45 Posts 8 Posters 27.2k Views 9 Watching
      sdetweil @BKeyport
      @bkeyport think I fixed it… give it a try, still bullseye in the urls
      BKeyportB 1 Reply Last reply
      • bugsounetB
        bugsounet Banned @sdetweil
        @sdetweil said in Bullseye:
        @bert269 we need node 14 for MM… the bullseye is only node 12
        are you sure ?
        S 2 Replies Last reply
          sdetweil @bugsounet
          @bugsounet i get v12.22.5 right after boot up, image downloaded yesterday
            sdetweil @bugsounet
            @bugsounet did u select yes to install updates during setup? I selected no… do it later
            reflashing SD card now.
              I get on 1st boot after config, enabling ssh , and setting hostname
              node -v
              v12.22.5
              cat /etc/apt/sources.list.d/nodesource.list
              cat: /etc/apt/sources.list.d/nodesource.list: No such file or directory
              ls /etc/apt/sources.list.d
              raspi.list vscode.list
              • bugsounetB
                bugsounet Banned
                curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                can help ?
                  sdetweil @bugsounet
                  @bugsounet i got it in the latest script… different approach, but understand
                  O 1 Reply Last reply
                  • O
                    OberfragGER @sdetweil
                    Sorry for asking but i dont get the point.
                    1 day before the release of Bullseye i installed busetr an used your script to get MM working. That worked flawless. Glad i made a backup then with my config.
                    Days later, i upgraded to Bullseye and MM was not working any longer. I thought due some autostart things or something like that.
                    When i now make a fresh bullseye install and use your script- is that working? No, or?
                      sdetweil @OberfragGER
                      @oberfragger yes, if you use the bullseye adjusted url (note the word master is replaced by bullseye i the url)
                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/bullseye/raspberry.sh)"
                      I don’t want to break the current version while we test this out…
                      I just updated the instructions with this link
                        DJBOOB66
                        Ok i tried
                        And it did not work. What I did was use the master version then rename MM folder after install then use above code and then it work?
                          sdetweil @DJBOOB66
                          @djboob66 can u post the ~/install.log?
                            DJBOOB66
                            I have to do it again but will do it as soon as i can or is log found on file and were?
                            • BKeyportB
                              @sdetweil Failed all over the place.
                              I’ll upload install.log, then nuking card and starting over.
                                sdetweil @BKeyport
                                @bkeyport did u use the bullseye link ?
                                before then if u used the old link, things get messed up w no recovery (well there is but it’s half an hour of ugly work)
                                reflash
                                • BKeyportB
                                  @sdetweil Yes, I used the bullseye link. installing a new card now.
                                    DJBOOB66
                                    the install went without problem this time only thing did diff was i SSH not VNC will test VNC install and see if error.
                                    the only think i get is
                                    “Installing dependencies …
                                    npm WARN deprecated @stylelint/postcss-markdown@0.36.2: Use the original unforke d package instead: postcss-markdown
                                    npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older v ersions may use Math.random() in certain circumstances, which is known to be pro blematic. See https://v8.dev/blog/math-random for details.
                                    npm notice created a lockfile as package-lock.json. You should commit this file.
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^2.3.2 (node_modules/je st-haste-map/node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@ 2.3.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”} )
                                    npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta | | >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dep endencies yourself.”
                                    Do i need to fix anything??
                                    Hope this helps.
                                      sdetweil @DJBOOB66
                                      @djboob66 no, nothing to fix
                                      • BKeyportB
                                        On new card it worked flawlessly. I’m assuming the old conditions of partial installs and whatnot had the old install broke things.
                                        Nothing but warnings about depreciated modules.
                                          sdetweil @BKeyport
                                          @bkeyport said in Bullseye:
                                          that we can’t do anything about. not our code
                                          • AssassinsA
                                            Assassins
                                            Dont Update, Bulleyes is so much slow, and it not drive 100% yet.
                                            Buster work 100%, and much faster
                                            • 2 / 3
