    Error on update to MM 2.11.0
    32 Posts 2 Posters 9.0k Views 2 Watching
      sdetweil @killing joke
      @killing-joke said in Error on update to MM 2.11.0:
      I git pulled the MM.
      AND did an npm install
      correct?
      (I wish u had used my upgrade script)
      see https://github.com/sdetweil/MagicMirror_scripts
      • K Offline
        killing joke @sdetweil
        thanks for the very quick reply.
        I don´t know, but when I try to start the MM with “npm start” the following error occurs which let me think it didn´t installed it properly?!
        pi@raspberrypi:~ $ npm start
        npm ERR! code ENOENT
        npm ERR! syscall open
        npm ERR! errno -2
        npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm ERR! enoent This is related to npm not being able to find a file.
        npm ERR! enoent
        npm ERR!     /home/pi/.npm/_logs/2021-11-14T17_51_18_189Z-debug.log
        pi@raspberrypi:~ $
        If my MM works again, I will definitly use your script to update it in the future. ;-)
        Best Regards from Germany
        Daniel
          @killing-joke you have to be in the MagicMirror folder to do npm start… you are in the users (pi) root
          cd MagicMirror
          npm start
          • K Offline
            I could facepalm me so hard for my last post since I want to hurry up my own post.
            Anyway, of course i have to be in the MM folder. but then it occurs the error which i wrote in my first code.
            How can I check the status of my npm?
              @killing-joke
              npm -v
              node -v
              • K Offline
                npm version 6.14.5
                node version 9.11.2
                  @killing-joke
                  to update manually you did
                  ~/MagicMirror
                  git pull
                  npm install
                  right?
                    @killing-joke no… that won’t do…
                    best thing is to run my upgrade script
                    and use force, instead of apply (because u already have the mm code pulled down)
                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                    • K Offline
                      I “git pulled” it in my MM folder but I didn´t installed npm again. I thought it is independent from the MM.
                      installed it again know but following occurs
                      pi@raspberrypi:~/MagicMirror $ npm install
                      > magicmirror@2.11.0 install /home/pi/MagicMirror
                      " && cd vendor && npm install --loglevel=error
                      > @fortawesome/fontawesome-free@5.15.4 postinstall /home/pi/MagicMirror/vendor/node_modules/@fortawesome/fontawesome-free
                      > node attribution.js
                      Font Awesome Free 5.15.4 by @fontawesome - https://fontawesome.com
                      License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL 1.1, Code: MIT License)
                      added 1 package from 1 contributor, removed 74 packages, updated 5 packages and audited 9 packages in 11.012s
                      found 0 vulnerabilities
                      > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
                      > npm run install-fonts && echo "MagicMirror installation finished successfully!
                      > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
                      > echo "Installing fonts ...
                      " && cd fonts && npm install --loglevel=error
                      updated 1 package and audited 1 package in 2.515s
                      audited 1172 packages in 61.47s
                      70 packages are looking for funding
                        run `npm fund` for details
                      found 88 vulnerabilities (4 low, 42 moderate, 40 high, 2 critical)
                        run `npm audit fix` to fix them, or `npm audit` for details
                      afterwards the same error occurs as in the first post described.
                        magicmirror@2.11.0
                        but u still have 2.11 installed
                        so the git pull failed
                        • 1 / 4
