    Error on update to MM 2.11.0
    32 Posts 2 Posters 9.0k Views 2 Watching
    • K Offline
      killing joke @sdetweil
      thanks for the very quick reply.
      I don´t know, but when I try to start the MM with “npm start” the following error occurs which let me think it didn´t installed it properly?!
      pi@raspberrypi:~ $ npm start
      npm ERR! code ENOENT
      npm ERR! syscall open
      npm ERR! errno -2
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/.npm/_logs/2021-11-14T17_51_18_189Z-debug.log
      pi@raspberrypi:~ $
      If my MM works again, I will definitly use your script to update it in the future. ;-)
      Best Regards from Germany
      Daniel
        sdetweil @killing joke
        @killing-joke you have to be in the MagicMirror folder to do npm start… you are in the users (pi) root
        cd MagicMirror
        npm start
        • K Offline
          I could facepalm me so hard for my last post since I want to hurry up my own post.
          Anyway, of course i have to be in the MM folder. but then it occurs the error which i wrote in my first code.
          How can I check the status of my npm?
            @killing-joke
            npm -v
            node -v
            • K Offline
              npm version 6.14.5
              node version 9.11.2
                @killing-joke
                to update manually you did
                ~/MagicMirror
                git pull
                npm install
                right?
                  @killing-joke no… that won’t do…
                  best thing is to run my upgrade script
                  see https://github.com/sdetweil/MagicMirror_scripts
                  and use force, instead of apply (because u already have the mm code pulled down)
                  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                  • K Offline
                    I “git pulled” it in my MM folder but I didn´t installed npm again. I thought it is independent from the MM.
                    installed it again know but following occurs
                    pi@raspberrypi:~/MagicMirror $ npm install
                    > magicmirror@2.11.0 install /home/pi/MagicMirror
                    " && cd vendor && npm install --loglevel=error
                    > @fortawesome/fontawesome-free@5.15.4 postinstall /home/pi/MagicMirror/vendor/node_modules/@fortawesome/fontawesome-free
                    > node attribution.js
                    Font Awesome Free 5.15.4 by @fontawesome - https://fontawesome.com
                    License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL 1.1, Code: MIT License)
                    added 1 package from 1 contributor, removed 74 packages, updated 5 packages and audited 9 packages in 11.012s
                    found 0 vulnerabilities
                    > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
                    > npm run install-fonts && echo "MagicMirror installation finished successfully!
                    > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
                    > echo "Installing fonts ...
                    " && cd fonts && npm install --loglevel=error
                    updated 1 package and audited 1 package in 2.515s
                    audited 1172 packages in 61.47s
                    70 packages are looking for funding
                      run `npm fund` for details
                    found 88 vulnerabilities (4 low, 42 moderate, 40 high, 2 critical)
                      run `npm audit fix` to fix them, or `npm audit` for details
                    afterwards the same error occurs as in the first post described.
                      @killing-joke said in Error on update to MM 2.11.0:
                      magicmirror@2.11.0
                      but u still have 2.11 installed
                      so the git pull failed
                      • K Offline
                        funny, but when i go into the MM folder and type “git pull” it says it´s the latest software… (in German)
                        • 1 / 4
