    Error on update to MM 2.11.0
    32 Posts 2 Posters 12.0k Views 2 Watching
      sdetweil @killing joke
      @killing-joke said in Error on update to MM 2.11.0:
      I git pulled the MM.
      AND did an npm install
      correct?
      (I wish u had used my upgrade script)
      see https://github.com/sdetweil/MagicMirror_scripts
      • K
        killing joke @sdetweil
        thanks for the very quick reply.
        I don´t know, but when I try to start the MM with “npm start” the following error occurs which let me think it didn´t installed it properly?!
        pi@raspberrypi:~ $ npm start
        npm ERR! code ENOENT
        npm ERR! syscall open
        npm ERR! errno -2
        npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm ERR! enoent This is related to npm not being able to find a file.
        npm ERR! enoent
        npm ERR!     /home/pi/.npm/_logs/2021-11-14T17_51_18_189Z-debug.log
        pi@raspberrypi:~ $
        If my MM works again, I will definitly use your script to update it in the future. ;-)
        Best Regards from Germany
        Daniel
          @killing-joke you have to be in the MagicMirror folder to do npm start… you are in the users (pi) root
          cd MagicMirror
          npm start
          • K
            I could facepalm me so hard for my last post since I want to hurry up my own post.
            Anyway, of course i have to be in the MM folder. but then it occurs the error which i wrote in my first code.
            How can I check the status of my npm?
              @killing-joke
              npm -v
              node -v
              • K
                npm version 6.14.5
                node version 9.11.2
                  @killing-joke
                  to update manually you did
                  ~/MagicMirror
                  git pull
                  npm install
                  right?
                    @killing-joke no… that won’t do…
                    best thing is to run my upgrade script
                    and use force, instead of apply (because u already have the mm code pulled down)
                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                    • K
                      I “git pulled” it in my MM folder but I didn´t installed npm again. I thought it is independent from the MM.
                      installed it again know but following occurs
                      pi@raspberrypi:~/MagicMirror $ npm install
                      > magicmirror@2.11.0 install /home/pi/MagicMirror
                      " && cd vendor && npm install --loglevel=error
                      > @fortawesome/fontawesome-free@5.15.4 postinstall /home/pi/MagicMirror/vendor/node_modules/@fortawesome/fontawesome-free
                      > node attribution.js
                      Font Awesome Free 5.15.4 by @fontawesome - https://fontawesome.com
                      License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL 1.1, Code: MIT License)
                      added 1 package from 1 contributor, removed 74 packages, updated 5 packages and audited 9 packages in 11.012s
                      found 0 vulnerabilities
                      > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
                      > npm run install-fonts && echo "MagicMirror installation finished successfully!
                      > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
                      > echo "Installing fonts ...
                      " && cd fonts && npm install --loglevel=error
                      updated 1 package and audited 1 package in 2.515s
                      audited 1172 packages in 61.47s
                      70 packages are looking for funding
                        run `npm fund` for details
                      found 88 vulnerabilities (4 low, 42 moderate, 40 high, 2 critical)
                        run `npm audit fix` to fix them, or `npm audit` for details
                      afterwards the same error occurs as in the first post described.
                        magicmirror@2.11.0
                        but u still have 2.11 installed
                        so the git pull failed
                        • K
                          funny, but when i go into the MM folder and type “git pull” it says it´s the latest software… (in German)
                            @killing-joke do
                            cd MagicMirror
                            git remote -v
                            grep version package.json
                            • K
                              @sdetweil result as followed
                              pi@raspberrypi:~/MagicMirror $ git remote -v
                              origin	https://github.com/MichMich/MagicMirror.git (fetch)
                              origin	https://github.com/MichMich/MagicMirror.git (push)
                              pi@raspberrypi:~/MagicMirror $ grep version package.json
                                "version": "2.11.0",
                                “version”: “2.11.0”,
                                definitely NOT the latest
                                S K 2 Replies Last reply Reply Quote 0
                                  @sdetweil please run my script…
                                  • K
                                    ok, i will do
                                      @killing-joke please run my script…
                                      https://forum.magicmirror.builders/topic/15862/error-on-update-to-mm-2-11-0/9?_=1636915152762
                                      • K
                                        pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                        No LSB modules are available.
                                        doing test run = false
                                        Minimum Node version: v14.0.0
                                        Installed Node version: v9.11.2
                                        Node should be upgraded.
                                        A Node process is currently running. Can't upgrade.
                                        Please quit all Node processes and restart the installer.
                                        pi 813 764 0 19:45 ? 00:00:00 sh -c DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js pi 817 813 0 19:45 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js pi 876 817 0 19:45 ? 00:00:05 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js pi 882 876 0 19:45 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote pi 968 882 0 19:46 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote pi 1133 876 0 19:46 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --field-trial-handle=16961185687081278422,14233476580341739937,131072 --disable-features=LayoutNG,SpareRendererForSitePerProcess --gpu-preferences=IAAAAAAAAAAgAAAgAAAAAAAAYAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --service-request-channel-token=5596814612634470352 pi 1946 1944 0 20:03 pts/0 00:00:00 grep node
                                        how can I end a Node process to try again?
                                          @killing-joke
                                          pm2 stop all
                                          then
                                          ps -ef | grep node | grep -v color
                                          it should return no output
                                          • K
                                            pi@raspberrypi:~/MagicMirror $ pm2 stop all
                                            [PM2] Applying action stopProcessId on app [all](ids: 0)
                                            [PM2] [MagicMirror](0) ✓
                                            │ App name    │ id │ mode │ pid │ status  │ restart │ uptime │ cpu │ mem    │ user │ watching │
                                            │ MagicMirror │ 0  │ fork │ 0   │ stopped │ 0       │ 0      │ 0%  │ 0 B    │ pi   │ disabled │
                                             Use `pm2 show <id|name>` to get more details about an app
                                            pi@raspberrypi:~/MagicMirror $ ps -ef | grep node | grep -v color
