    Error on update to MM 2.11.0
    32 Posts 2 Posters 8.3k Views 2 Watching
    • K Offline
      killing joke
      Dear all,
      after a long time I want to restart my not-finished-yet project.
      So I pluged in the cables to my raspberry pi logged into it via remotecontrol. I updated and upgraded my pi and afterwards I git pulled the MM.
      Till then I can´t start the MM because of the following error.
      > magicmirror@2.11.0 start /home/pi/MagicMirror
      App threw an error during load
      Error: Cannot find module 'logger'
      Require stack:
          at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Function.Module._load (internal/modules/cjs/loader.js:531:27)
          at Module.require (internal/modules/cjs/loader.js:685:19)
          at require (internal/modules/cjs/helpers.js:16:16)
          at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:13:13)
          at Module._compile (internal/modules/cjs/loader.js:786:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
          at Module.load (internal/modules/cjs/loader.js:645:32)
      A JavaScript error occurred in the main process
      Uncaught Exception:
      Require stack:
      Does anyone know what I an do to fix my problem?
      Thanks in advance and best wishes from Germany
      Daniel
        sdetweil @killing joke
        @killing-joke please run my script…
        https://forum.magicmirror.builders/topic/15862/error-on-update-to-mm-2-11-0/9?_=1636915152762
          @killing-joke said in Error on update to MM 2.11.0:
          AND did an npm install
          correct?
          (I wish u had used my upgrade script)
          see https://github.com/sdetweil/MagicMirror_scripts
          • K Offline
            killing joke @sdetweil
            thanks for the very quick reply.
            I don´t know, but when I try to start the MM with “npm start” the following error occurs which let me think it didn´t installed it properly?!
            pi@raspberrypi:~ $ npm start
            npm ERR! code ENOENT
            npm ERR! syscall open
            npm ERR! errno -2
            npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
            npm ERR! enoent This is related to npm not being able to find a file.
            npm ERR! enoent
            npm ERR!     /home/pi/.npm/_logs/2021-11-14T17_51_18_189Z-debug.log
            pi@raspberrypi:~ $
            If my MM works again, I will definitly use your script to update it in the future. ;-)
            Best Regards from Germany
            Daniel
              @killing-joke you have to be in the MagicMirror folder to do npm start… you are in the users (pi) root
              cd MagicMirror
              npm start
              • K Offline
                I could facepalm me so hard for my last post since I want to hurry up my own post.
                Anyway, of course i have to be in the MM folder. but then it occurs the error which i wrote in my first code.
                How can I check the status of my npm?
                  @killing-joke
                  npm -v
                  node -v
                  • K Offline
                    npm version 6.14.5
                    node version 9.11.2
                      @killing-joke
                      to update manually you did
                      ~/MagicMirror
                      git pull
                      npm install
                      right?
                        @killing-joke no… that won’t do…
                        best thing is to run my upgrade script
                        and use force, instead of apply (because u already have the mm code pulled down)
                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                        • K Offline
                          I “git pulled” it in my MM folder but I didn´t installed npm again. I thought it is independent from the MM.
                          installed it again know but following occurs
                          pi@raspberrypi:~/MagicMirror $ npm install
                          > magicmirror@2.11.0 install /home/pi/MagicMirror
                          " && cd vendor && npm install --loglevel=error
                          > @fortawesome/fontawesome-free@5.15.4 postinstall /home/pi/MagicMirror/vendor/node_modules/@fortawesome/fontawesome-free
                          > node attribution.js
                          Font Awesome Free 5.15.4 by @fontawesome - https://fontawesome.com
                          License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL 1.1, Code: MIT License)
                          added 1 package from 1 contributor, removed 74 packages, updated 5 packages and audited 9 packages in 11.012s
                          found 0 vulnerabilities
                          > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
                          > npm run install-fonts && echo "MagicMirror installation finished successfully!
                          > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
                          > echo "Installing fonts ...
                          " && cd fonts && npm install --loglevel=error
                          updated 1 package and audited 1 package in 2.515s
                          audited 1172 packages in 61.47s
                          70 packages are looking for funding
                            run `npm fund` for details
                          found 88 vulnerabilities (4 low, 42 moderate, 40 high, 2 critical)
                            run `npm audit fix` to fix them, or `npm audit` for details
                          afterwards the same error occurs as in the first post described.
                          • 1 / 4
