    Error on update to MM 2.11.0
    32 Posts 2 Posters 12.0k Views 2 Watching
      sdetweil @killing joke
      @killing-joke
      to update manually you did
      ~/MagicMirror
      git pull
      npm install
      right?
        @killing-joke no… that won’t do…
        best thing is to run my upgrade script
        see https://github.com/sdetweil/MagicMirror_scripts
        and use force, instead of apply (because u already have the mm code pulled down)
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
        • K
          killing joke @sdetweil
          I “git pulled” it in my MM folder but I didn´t installed npm again. I thought it is independent from the MM.
          installed it again know but following occurs
          pi@raspberrypi:~/MagicMirror $ npm install
          > magicmirror@2.11.0 install /home/pi/MagicMirror
          " && cd vendor && npm install --loglevel=error
          > @fortawesome/fontawesome-free@5.15.4 postinstall /home/pi/MagicMirror/vendor/node_modules/@fortawesome/fontawesome-free
          > node attribution.js
          Font Awesome Free 5.15.4 by @fontawesome - https://fontawesome.com
          License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL 1.1, Code: MIT License)
          added 1 package from 1 contributor, removed 74 packages, updated 5 packages and audited 9 packages in 11.012s
          found 0 vulnerabilities
          > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
          > npm run install-fonts && echo "MagicMirror installation finished successfully!
          > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
          > echo "Installing fonts ...
          " && cd fonts && npm install --loglevel=error
          updated 1 package and audited 1 package in 2.515s
          audited 1172 packages in 61.47s
          70 packages are looking for funding
            run `npm fund` for details
          found 88 vulnerabilities (4 low, 42 moderate, 40 high, 2 critical)
            run `npm audit fix` to fix them, or `npm audit` for details
          afterwards the same error occurs as in the first post described.
            @killing-joke said in Error on update to MM 2.11.0:
            magicmirror@2.11.0
            but u still have 2.11 installed
            so the git pull failed
            • K
              funny, but when i go into the MM folder and type “git pull” it says it´s the latest software… (in German)
                @killing-joke do
                cd MagicMirror
                git remote -v
                grep version package.json
                • K
                  @sdetweil result as followed
                  pi@raspberrypi:~/MagicMirror $ git remote -v
                  origin	https://github.com/MichMich/MagicMirror.git (fetch)
                  origin	https://github.com/MichMich/MagicMirror.git (push)
                  pi@raspberrypi:~/MagicMirror $ grep version package.json
                    "version": "2.11.0",
                    “version”: “2.11.0”,
                    definitely NOT the latest
                    S K 2 Replies Last reply Reply Quote 0
                      @sdetweil please run my script…
                      • K
                        ok, i will do
                          @killing-joke please run my script…
                          https://forum.magicmirror.builders/topic/15862/error-on-update-to-mm-2-11-0/9?_=1636915152762
                          • K
                            pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                            No LSB modules are available.
                            doing test run = false
                            Minimum Node version: v14.0.0
                            Installed Node version: v9.11.2
                            Node should be upgraded.
                            A Node process is currently running. Can't upgrade.
                            Please quit all Node processes and restart the installer.
                            pi 813 764 0 19:45 ? 00:00:00 sh -c DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js pi 817 813 0 19:45 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js pi 876 817 0 19:45 ? 00:00:05 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js pi 882 876 0 19:45 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote pi 968 882 0 19:46 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote pi 1133 876 0 19:46 ? 00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --field-trial-handle=16961185687081278422,14233476580341739937,131072 --disable-features=LayoutNG,SpareRendererForSitePerProcess --gpu-preferences=IAAAAAAAAAAgAAAgAAAAAAAAYAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --service-request-channel-token=5596814612634470352 pi 1946 1944 0 20:03 pts/0 00:00:00 grep node
                            how can I end a Node process to try again?
                              @killing-joke
                              pm2 stop all
                              then
                              ps -ef | grep node | grep -v color
                              it should return no output
                              • K
                                pi@raspberrypi:~/MagicMirror $ pm2 stop all
                                [PM2] Applying action stopProcessId on app [all](ids: 0)
                                [PM2] [MagicMirror](0) ✓
                                │ App name    │ id │ mode │ pid │ status  │ restart │ uptime │ cpu │ mem    │ user │ watching │
                                │ MagicMirror │ 0  │ fork │ 0   │ stopped │ 0       │ 0      │ 0%  │ 0 B    │ pi   │ disabled │
                                 Use `pm2 show <id|name>` to get more details about an app
                                pi@raspberrypi:~/MagicMirror $ ps -ef | grep node | grep -v color
                                  @killing-joke ok, now run my script again
                                  • K
                                    I did.
                                    afterwards “npm start” but with a black screen of my MM.
                                    But I need to rest for today… tomorrow is another day to have fun with it!
                                    Thanks for today
                                    Installing Node.js ...
                                    gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
                                    Paketlisten werden gelesen... Fertig
                                    Abhängigkeitsbaum wird aufgebaut.
                                    Statusinformationen werden eingelesen.... Fertig
                                    Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
                                      realpath
                                    Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
                                    Die folgenden Pakete werden aktualisiert (Upgrade):
                                      nodejs
                                    1 aktualisiert, 0 neu installiert, 0 zu entfernen und 14 nicht aktualisiert.
                                    Es müssen 23,0 MB an Archiven heruntergeladen werden.
                                    Nach dieser Operation werden 57,2 MB Plattenplatz zusätzlich benutzt.
                                    Holen:1 https://deb.nodesource.com/node_14.x stretch/main armhf nodejs armhf 14.18.1-1nodesource1 [23,0 MB]
                                    Es wurden 23,0 MB in 5 s geholt (4.587 kB/s).
                                    apt-listchanges: Lese Changelogs...
                                    (Lese Datenbank ... 123797 Dateien und Verzeichnisse sind derzeit installiert.)
                                    Vorbereitung zum Entpacken von .../nodejs_14.18.1-1nodesource1_armhf.deb ...
                                    Detected old npm client, removing...
                                    Entpacken von nodejs (14.18.1-1nodesource1) über (9.11.2-1nodesource1) ...
                                    nodejs (14.18.1-1nodesource1) wird eingerichtet ...
                                    Trigger für man-db (2.7.6.1-2) werden verarbeitet ...
                                    node version is
                                    Node.js installation Done! version=v14.18.1
                                    Minimum npm version: V6.0.0
                                    Installed npm version: V6.14.15
                                    No npm upgrade necessary.
                                    upgrading from version 2.11.0 to 2.17.1
                                    fetching latest revisions
                                    there are 5 local files that are different than the master repo
                                       fonts/package-lock.json
                                       modules/default/calendar/calendar.js
                                       package-lock.json
                                       package.json
                                       vendor/package-lock.json
                                    any *-lock.json files do not need to be saved
                                    do you want to save these files for later   (Y/n)?y
                                    npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/aws4
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/bowser
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/helmet-csp
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mocha/node_modules/minimist
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mocha/node_modules/mkdirp
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mocha/node_modules/p-limit
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mocha/node_modules/yargs-parser
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/moment
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/request/node_modules/tough-cookie
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/string.prototype.trimstart
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/string.prototype.trimleft
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/es-abstract
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/string.prototype.trimend
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/string.prototype.trimright
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs-unparser/node_modules/p-limit
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs-unparser/node_modules/yargs-parser
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/express-ipfilter
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/grunt-markdownlint
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/simple-git
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/es-abstract/node_modules
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/helmet/node_modules
                                    npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/simple-git/node_modules
                                    npm ERR! code EACCES
                                    npm ERR! syscall access
                                    npm ERR! path /home/pi/MagicMirror/node_modules/aws4
                                    npm ERR! errno -13
                                    npm ERR! Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/aws4'
                                    npm ERR!  [Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/aws4'] {
                                    npm ERR!   errno: -13,
                                    npm ERR!   code: 'EACCES',
                                    npm ERR!   syscall: 'access',
                                    npm ERR!   path: '/home/pi/MagicMirror/node_modules/aws4'
                                    npm ERR! }
                                    npm ERR!
                                    npm ERR! The operation was rejected by your operating system.
                                    npm ERR! It is likely you do not have the permissions to access this file as the current user
                                    npm ERR!
                                    npm ERR! If you believe this might be a permissions issue, please double-check the
                                    npm ERR! permissions of the file and its containing directories, or try running
                                    npm ERR! the command again as root/Administrator.
                                    npm ERR!     /home/pi/.npm/_logs/2021-11-14T19_31_28_554Z-debug.log
                                    	  package.json not found for module MMM-SunRiseSet
                                    adding package.json for module MMM-SunRiseSet
                                    	 require for request in module MMM-SunRiseSet not found in package.json package.json for module MMM-SunRiseSet
                                    installing request for module MMM-SunRiseSet
                                    npm notice created a lockfile as package-lock.json. You should commit this file.
                                    	 require for request in module MMM-AVStock not found in package.json package.json for module MMM-AVStock
                                    installing request for module MMM-AVStock
                                    processing for module MMM-Carousel please wait
                                    up to date in 0.732s
                                    processing complete for module MMM-Carousel
                                    processing for module MMM-DWD-WarnWeather please wait
                                    added 47 packages from 58 contributors and audited 47 packages in 6.397s
                                    2 packages are looking for funding
                                    processing complete for module MMM-DWD-WarnWeather
                                    processing for module MMM-SunRiseSet please wait
                                    added 47 packages from 58 contributors and audited 47 packages in 6.702s
                                    processing complete for module MMM-SunRiseSet
                                    processing for module MMM-AVStock please wait
                                    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                    added 53 packages from 62 contributors and audited 54 packages in 11.297s
                                    processing complete for module MMM-AVStock
                                    processing for module MMM-Fuel please wait
                                    npm WARN deprecated @stylelint/postcss-markdown@0.36.2: Use the original unforked package instead: postcss-markdown
                                    npm WARN deprecated babel-eslint@10.1.0: babel-eslint is now @babel/eslint-parser. This package will no longer receive updates.
                                    added 464 packages from 298 contributors and audited 464 packages in 84.828s
                                    101 packages are looking for funding
                                    found 6 moderate severity vulnerabilities
                                    processing complete for module MMM-Fuel
                                    we stashed a set of files that appear changed from the latest repo versions. you should review them
                                    see installers/stashed_files for the list
                                    you can use git checkout stash@{0} -- filename to extract one file from the stash
                                    or git stash pop to restore them all
                                    WARNING..
                                    WARNING.. either will overlay the file just installed by the update
                                    WARNING..
                                    > magicmirror@2.17.1 start /home/pi/MagicMirror
                                    [2021-11-14 20:35:10.378] [LOG]    Starting MagicMirror: v2.17.1
                                    [2021-11-14 20:35:10.425] [LOG]    Loading config ...
                                    [2021-11-14 20:35:10.441] [LOG]    Loading module helpers ...
                                    [2021-11-14 20:35:10.451] [LOG]    No helper found for module: MMM-Carousel.
                                    [2021-11-14 20:35:10.454] [LOG]    No helper found for module: alert.
                                    [2021-11-14 20:35:10.494] [LOG]    Initializing new module helper ...
                                    [2021-11-14 20:35:10.496] [LOG]    Module helper loaded: updatenotification
                                    [2021-11-14 20:35:10.500] [LOG]    No helper found for module: clock.
                                    [2021-11-14 20:35:10.628] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-ical'
                                    Require stack:
                                    - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
                                    - /home/pi/MagicMirror/modules/default/calendar/node_helper.js
                                    [2021-11-14 20:35:10.630] [LOG]    Loading module helpers ...
                                    [2021-11-14 20:35:10.631] [LOG]    No helper found for module: MMM-Carousel.
                                    [2021-11-14 20:35:10.632] [LOG]    No helper found for module: alert.
                                    [2021-11-14 20:35:10.634] [LOG]    Initializing new module helper ...
                                    [2021-11-14 20:35:10.634] [LOG]    Module helper loaded: updatenotification
                                    [2021-11-14 20:35:10.635] [LOG]    No helper found for module: clock.
                                    [2021-11-14 20:35:10.640] [ERROR]  App threw an error during load
                                    [2021-11-14 20:35:10.642] [ERROR]  Error: Cannot find module 'node-ical'
                                    Require stack:
                                        at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                        at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                        at Module.require (internal/modules/cjs/loader.js:685:19)
                                        at require (internal/modules/cjs/helpers.js:16:16)
                                        at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:10:14)
                                        at Module._compile (internal/modules/cjs/loader.js:786:30)
                                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                        at Module.load (internal/modules/cjs/loader.js:645:32)
                                    [2021-11-14 20:35:10.645] [ERROR]  Whoops! There was an uncaught exception...
                                    [2021-11-14 20:35:10.646] [ERROR]  Error: Cannot find module 'node-ical'
                                    Require stack:
                                        at Module.load (internal/modules/cjs/loader.js:645:32) {
                                      code: 'MODULE_NOT_FOUND',
                                      requireStack: [
                                        '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js',
                                        '/home/pi/MagicMirror/modules/default/calendar/node_helper.js',
                                        '/home/pi/MagicMirror/js/app.js',
                                        '/home/pi/MagicMirror/js/electron.js',
                                        '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                        undefined
                                    [2021-11-14 20:35:10.659] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    [2021-11-14 20:35:10.660] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    Fontconfig warning: "/etc/fonts/fonts.conf", line 100: unknown element "blank"
                                    [2021-11-14 20:35:11.331] [LOG]    Launching application.
                                    [2021-11-14 20:37:36.856] [LOG]    Shutting down server...
                                    [2021-11-14 20:37:36.862] [LOG]    Stopping module helper: updatenotification
                                    [2021-11-14 20:37:36.864] [LOG]    Stopping module helper: updatenotification
                                    [2021-11-14 20:37:36.865] [ERROR]  Whoops! There was an uncaught exception...
                                    [2021-11-14 20:37:36.866] [ERROR]  TypeError: Cannot read property 'close' of undefined
                                        at App.stop (/home/pi/MagicMirror/js/app.js:257:14)
                                        at App.<anonymous> (/home/pi/MagicMirror/js/electron.js:139:7)
                                        at App.emit (events.js:200:13)
                                        at Object.exports.execute (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu-item-roles.js:286:23)
                                        at MenuItem.click (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu-item.js:46:20)
                                        at Function.executeCommand (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu.js:32:17)
                                    [2021-11-14 20:37:36.870] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    [2021-11-14 20:37:36.871] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    [2021-11-14 20:37:38.262] [LOG]    Shutting down server...
                                    [2021-11-14 20:37:38.265] [LOG]    Stopping module helper: updatenotification
                                    [2021-11-14 20:37:38.266] [LOG]    Stopping module helper: updatenotification
                                    [2021-11-14 20:37:38.268] [ERROR]  Whoops! There was an uncaught exception...
                                    [2021-11-14 20:37:38.269] [ERROR]  TypeError: Cannot read property 'close' of undefined
                                    [2021-11-14 20:37:38.271] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    [2021-11-14 20:37:38.272] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    [2021-11-14 20:37:39.822] [LOG]    Shutting down server...
                                    [2021-11-14 20:37:39.823] [LOG]    Stopping module helper: updatenotification
                                    [2021-11-14 20:37:39.824] [LOG]    Stopping module helper: updatenotification
                                    [2021-11-14 20:37:39.826] [ERROR]  Whoops! There was an uncaught exception...
                                    [2021-11-14 20:37:39.827] [ERROR]  TypeError: Cannot read property 'close' of undefined
                                    [2021-11-14 20:37:39.829] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    [2021-11-14 20:37:39.830] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      @killing-joke crazy
                                      sudo rm -rf node_modules
                                      the update didn’t work (write access) almost like someone did sudo npm install at one time.
                                      run my script again
                                      • K
                                        @sdetweil I did the described code
                                        and run your script again. The result as followed…
                                        pi@raspberrypi:~ $ sudo rm -rf node_modules
                                        pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                        Installed Node version: v14.18.1
                                        No Node.js upgrade necessary.
                                        upgrading from version 2.17.1 to 2.17.1
                                        npm ERR! errno -13
                                        npm ERR! }
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!     /home/pi/.npm/_logs/2021-11-17T21_23_10_794Z-debug.log
                                        up to date in 1.262s
                                        added 47 packages from 58 contributors and audited 47 packages in 7.638s
                                        added 47 packages from 58 contributors and audited 47 packages in 6.311s
                                        added 53 packages from 62 contributors and audited 54 packages in 9.551s
                                        added 464 packages from 298 contributors and audited 464 packages in 67.606s
                                        pi@raspberrypi:~ $
                                        “npm start” gives me the following error code
                                        pi@raspberrypi:~ $ npm start
                                        npm ERR! code ENOENT
                                        npm ERR! syscall open
                                        npm ERR! errno -2
                                        npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                        npm ERR! enoent This is related to npm not being able to find a file.
                                        npm ERR! enoent
                                        npm ERR!     /home/pi/.npm/_logs/2021-11-17T21_27_04_499Z-debug.log
                                        pi@raspberrypi:~ $
                                        I don´t have a folder named “.npm” to show the logs. Is it a hidden folder?
                                          @killing-joke you need to be IN the MagicMirror folder to do npm start
                                            @killing-joke but u missed a step right at the beginning
                                            so u didn’t erase the bad folder which is causing all the problems
