Error on update to MM 2.11.0
32 Posts 2 Posters 6.2k Views 2 Watching
  • K Offline
    killing joke
    Dear all,
    after a long time I want to restart my not-finished-yet project.
    So I pluged in the cables to my raspberry pi logged into it via remotecontrol. I updated and upgraded my pi and afterwards I git pulled the MM.
    Till then I can´t start the MM because of the following error.
    > magicmirror@2.11.0 start /home/pi/MagicMirror
    App threw an error during load
    Error: Cannot find module 'logger'
    Require stack:
        at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Function.Module._load (internal/modules/cjs/loader.js:531:27)
        at Module.require (internal/modules/cjs/loader.js:685:19)
        at require (internal/modules/cjs/helpers.js:16:16)
        at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:13:13)
        at Module._compile (internal/modules/cjs/loader.js:786:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
        at Module.load (internal/modules/cjs/loader.js:645:32)
    A JavaScript error occurred in the main process
    Uncaught Exception:
    Require stack:
    Does anyone know what I an do to fix my problem?
    Thanks in advance and best wishes from Germany
    Daniel
    S 1 Reply Last reply Nov 12, 2021, 9:30 PM Reply Quote 0
      sdetweil @killing joke
      @killing-joke please run my script…
      https://forum.magicmirror.builders/topic/15862/error-on-update-to-mm-2-11-0/9?_=1636915152762
      K 1 Reply Last reply Nov 14, 2021, 7:04 PM Reply Quote 0
        @killing-joke said in Error on update to MM 2.11.0:
        AND did an npm install
        correct?
        (I wish u had used my upgrade script)
        see https://github.com/sdetweil/MagicMirror_scripts
        K 1 Reply Last reply Nov 14, 2021, 5:55 PM Reply Quote 0
        • K Offline
          killing joke @sdetweil
          thanks for the very quick reply.
          I don´t know, but when I try to start the MM with “npm start” the following error occurs which let me think it didn´t installed it properly?!
          pi@raspberrypi:~ $ npm start
          npm ERR! code ENOENT
          npm ERR! syscall open
          npm ERR! errno -2
          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
          npm ERR! enoent This is related to npm not being able to find a file.
          npm ERR! enoent
          npm ERR!     /home/pi/.npm/_logs/2021-11-14T17_51_18_189Z-debug.log
          pi@raspberrypi:~ $
          If my MM works again, I will definitly use your script to update it in the future. ;-)
          Best Regards from Germany
          Daniel
          S 1 Reply Last reply Nov 14, 2021, 5:56 PM Reply Quote 0
            @killing-joke you have to be in the MagicMirror folder to do npm start… you are in the users (pi) root
            cd MagicMirror
            npm start
            K 1 Reply Last reply Nov 14, 2021, 6:26 PM Reply Quote 0
            • K Offline
              I could facepalm me so hard for my last post since I want to hurry up my own post.
              Anyway, of course i have to be in the MM folder. but then it occurs the error which i wrote in my first code.
              How can I check the status of my npm?
              S 2 Replies Last reply Nov 14, 2021, 6:27 PM Reply Quote 0
                @killing-joke
                npm -v
                node -v
                K 1 Reply Last reply Nov 14, 2021, 6:28 PM Reply Quote 0
                • K Offline
                  npm version 6.14.5
                  node version 9.11.2
                  S 1 Reply Last reply Nov 14, 2021, 6:31 PM Reply Quote 0
                    @killing-joke
                    to update manually you did
                    ~/MagicMirror
                    git pull
                    npm install
                    right?
                    K 1 Reply Last reply Nov 14, 2021, 6:33 PM Reply Quote 0
                      @killing-joke no… that won’t do…
                      best thing is to run my upgrade script
                      and use force, instead of apply (because u already have the mm code pulled down)
                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                      • K Offline
                        I “git pulled” it in my MM folder but I didn´t installed npm again. I thought it is independent from the MM.
                        installed it again know but following occurs
                        pi@raspberrypi:~/MagicMirror $ npm install
                        > magicmirror@2.11.0 install /home/pi/MagicMirror
                        " && cd vendor && npm install --loglevel=error
                        > @fortawesome/fontawesome-free@5.15.4 postinstall /home/pi/MagicMirror/vendor/node_modules/@fortawesome/fontawesome-free
                        > node attribution.js
                        Font Awesome Free 5.15.4 by @fontawesome - https://fontawesome.com
                        License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL 1.1, Code: MIT License)
                        added 1 package from 1 contributor, removed 74 packages, updated 5 packages and audited 9 packages in 11.012s
                        found 0 vulnerabilities
                        > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
                        > npm run install-fonts && echo "MagicMirror installation finished successfully!
                        > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
                        > echo "Installing fonts ...
                        " && cd fonts && npm install --loglevel=error
                        updated 1 package and audited 1 package in 2.515s
                        audited 1172 packages in 61.47s
                        70 packages are looking for funding
                          run `npm fund` for details
                        found 88 vulnerabilities (4 low, 42 moderate, 40 high, 2 critical)
                          run `npm audit fix` to fix them, or `npm audit` for details
                        afterwards the same error occurs as in the first post described.
                        S 1 Reply Last reply Nov 14, 2021, 6:34 PM Reply Quote 0
                        • 1 / 4
                        1 / 4
