Make two modules overlap.
8 Posts 2 Posters 1.1k Views 2 Watching
    jamaces
    I am trying to make a Christmas Countdown.
    Currently I have a .png working with MMM-ImagesPhotos and MMM-doomsDay. Currently the image sits above the doomsday. It looks ok but not 100%.
    Is it possible to overlap doomsDay with ImagesPhotos so that the number will sit in the space beside the tree. I have uploaded the png I am using below.
    Any help is greatly appreciated. Thank you!
    S 1 Reply Last reply Nov 25, 2021, 4:06 PM Reply Quote 0
      sdetweil @jamaces
      @jamaces what is the config for doomsday?
      module
      position:
      which appears first in config.js
      J 1 Reply Last reply Nov 25, 2021, 6:15 PM Reply Quote 0
        jamaces @sdetweil
        bottom_right
        I have the photo sitting above doomsday
        S 1 Reply Last reply Nov 25, 2021, 6:20 PM Reply Quote 0
          sdetweil @jamaces
          @jamaces can u show the config for those two modules?
          as they appear in config.js…
          J 1 Reply Last reply Nov 25, 2021, 11:45 PM Reply Quote 0
            jamaces @sdetweil
            MMM-ImagesPhotos
                 opacity: 100,
                 updateInterval: 999,
                 maxWidth:  “75%”,
                 maxHeight: “75%”,
            MMM-doomsDay
            config:{
                 toWhat:” “,
                 doomsDay: “2021-12-25 24:00:00”,
                 Present: “Merry Christmas”,
                 timesUp: “ “,
                 singular: “ “,
                 plural: “ “,
            S 1 Reply Last reply Nov 26, 2021, 12:10 AM Reply Quote 0
              sdetweil @jamaces
              @jamaces ok, the ‘problem’ is that you didn’t specify the position setting for each module.(right after module: line)
              imagesPhotos cheats and displays in the background
              the other will not be displayed at all without a position
              see
              https://docs.magicmirror.builders/modules/configuration.html#example
              J 1 Reply Last reply Nov 26, 2021, 12:22 AM Reply Quote 0
                jamaces @sdetweil
                S 1 Reply Last reply Nov 26, 2021, 12:29 AM Reply Quote 0
                  sdetweil @jamaces
                  @jamaces set position for images to fullscreen_below. that should put it behind everthing
