    Make two modules overlap.
    8 Posts 2 Posters 1.4k Views 2 Watching
      jamaces
      I am trying to make a Christmas Countdown.
      Currently I have a .png working with MMM-ImagesPhotos and MMM-doomsDay. Currently the image sits above the doomsday. It looks ok but not 100%.
      Is it possible to overlap doomsDay with ImagesPhotos so that the number will sit in the space beside the tree. I have uploaded the png I am using below.
      Any help is greatly appreciated. Thank you!
        sdetweil @jamaces
        @jamaces what is the config for doomsday?
        module
        position:
        which appears first in config.js
          jamaces @sdetweil
          bottom_right
          I have the photo sitting above doomsday
            sdetweil @jamaces
            @jamaces can u show the config for those two modules?
            as they appear in config.js…
              jamaces @sdetweil
              MMM-ImagesPhotos
                   opacity: 100,
                   updateInterval: 999,
                   maxWidth:  “75%”,
                   maxHeight: “75%”,
              MMM-doomsDay
              config:{
                   toWhat:” “,
                   doomsDay: “2021-12-25 24:00:00”,
                   Present: “Merry Christmas”,
                   timesUp: “ “,
                   singular: “ “,
                   plural: “ “,
                sdetweil @jamaces
                @jamaces ok, the ‘problem’ is that you didn’t specify the position setting for each module.(right after module: line)
                imagesPhotos cheats and displays in the background
                the other will not be displayed at all without a position
                see
                https://docs.magicmirror.builders/modules/configuration.html#example
                  jamaces @sdetweil
                    sdetweil @jamaces
                    @jamaces set position for images to fullscreen_below. that should put it behind everthing
