    Make two modules overlap.
    8 Posts 2 Posters 1.3k Views 2 Watching
      jamaces @sdetweil
      bottom_right
      I have the photo sitting above doomsday
        sdetweil @jamaces
        @jamaces can u show the config for those two modules?
        as they appear in config.js…
          jamaces @sdetweil
          MMM-ImagesPhotos
               opacity: 100,
               updateInterval: 999,
               maxWidth:  “75%”,
               maxHeight: “75%”,
          MMM-doomsDay
          config:{
               toWhat:” “,
               doomsDay: “2021-12-25 24:00:00”,
               Present: “Merry Christmas”,
               timesUp: “ “,
               singular: “ “,
               plural: “ “,
            sdetweil @jamaces
            @jamaces ok, the ‘problem’ is that you didn’t specify the position setting for each module.(right after module: line)
            imagesPhotos cheats and displays in the background
            the other will not be displayed at all without a position
            see
            https://docs.magicmirror.builders/modules/configuration.html#example
              jamaces @sdetweil
                sdetweil @jamaces
                @jamaces set position for images to fullscreen_below. that should put it behind everthing
