    So I have a question about backup
    24 Posts 6 Posters 11.3k Views 5 Watching
      Ray
      I’m currently running my magic mirror on a Linux based system
      I want to back it up in case something goes wrong
      can I just clone all my modules and store them in a safe place
      including config, tokens, credentials
      then reinstall magic mirror the traditional way
      then copy all My modules into the folders
      then use npm install in each modules folders
      Would this method work without causing any problems?
        sdetweil @Ray
        @ray yes, that will work.
        save config.js
        u can save the module folders, or save the list of modules to install,
        git remote -v
        will list where u got the module from
        so u can git clone/npm install on restore
        with the config.js
          Ray @sdetweil
          @sdetweil that’s fantastic. I appreciate the quick response. I put a lot of effort and time in this mirror
          so is good to hear. I can back it up safely
            Ray @sdetweil
            @sdetweil forgot to ask
            so the git remote -v
            we’ll get all its information from my original config.js
            is that correct
              sdetweil @Ray
              @ray you do that in each module folder
              the info from config.js is settings and API keys for each/all the modules
              my grandson just went home from.sleepover. I can write a quick script to backup and restore
              • karsten13K
                karsten13 @sdetweil
                see also https://forum.magicmirror.builders/topic/14255/what-is-your-backup-and-restore-method
                  sdetweil @Ray
                  @ray i created two scripts mm_backup and mm_restore
                  you can get them here
                  they write/read from a folder (defaults to ~/MM_backup )
                  using ~/MagicMirror as the source (default)
                  (but take parms to change the names) see mm_backup.sh -h
                  this creates a git repository of the 2 files and creates a tag (label) for the instance of the backup.
                  you should create a (free) private repo (to keep any config settings private) on github and push the local repo there to have an offline backup
                  then u can clone it anytime and restore from the appropriate tag (date/time)
                  mumblebajM R 2 Replies Last reply Reply Quote 0
                  • mumblebajM
                    Hi Sam. Here? I checked your Github and nothing there either. Or maybe I am missed it?
                      sdetweil @mumblebaj
                      @mumblebaj doah!!.. forgot the link
                      https://github.com/sdetweil/MagicMirror-backup-restore
                      mumblebajM 2 Replies Last reply Reply Quote 0
                      • mumblebajM
                        @sdetweil Awesome. Thanks Sam. Always nice work from you.
                        • mumblebajM
                          @sdetweil When I ran the mm_backup.sh I saw this error but it created the output in the MM_backup folder as expected.
                          usage: git init [-q | --quiet] [--bare] [--template=<template-directory>] [--shared[=<permissions>]] [<directory>]
                              --template <template-directory>
                                                    directory from which templates will be used
                              --bare                create a bare repository
                                                    specify that the git repository is to be shared amongst several users
                              -q, --quiet           be quiet
                              --separate-git-dir <gitdir>
                                                    separate git dir from working tree
                          Is this because of some options that I did not specify? After the output was created I just manually pushed to a private directory on git.
                            sdetweil @mumblebaj
                            @mumblebaj probably git version before 2.28
                            the primary branch name option didn’t come in til 2.28. 0
                            i have
                            git --version
                            git version 2.34.1
                            I will add a check…
                            to upgrade git (don’t do it for these scripts… I have fixed the script to not need this capability, just documenting how)
                            sudo add-apt-repository -y ppa:git-core/ppa
                            sudo apt update
                            sudo apt install git -y
                              sdetweil @mumblebaj
                              @mumblebaj I pushed a change to set the primary branch name a different way…
                              give it a try
                              backup to some other folder (and then u can delete that folder)
                              ./mm_backup.sh -b somefolder
                              just pushed a change to create the output folder if it doesn’t exist, instead of error…
                              • mumblebajM
                                @sdetweil Awesome. That was clean.
                                • mumblebajM
                                  @sdetweil My git version is 2.20.1. Guess I need to update it.
                                    sdetweil @mumblebaj
                                    @mumblebaj said in So I have a question about backup:
                                    only if u need something
                                    • mumblebajM
                                      @sdetweil Right now, not. MM runs perfect as is. I’ll leave it for now. :beaming_face_with_smiling_eyes:
                                        sdetweil @mumblebaj
                                        @mumblebaj i don’t want to force people to upgrade, thanks for the report and test results
                                        • mumblebajM
                                          @sdetweil No worries and a pleasure.
                                            Ray @sdetweil
                                            @sdetweil hey thanks a lot. I appreciate that
                                            I will definitely check it out
                                            I kind of made my own. It’s very basic but seems to do the trick
                                            it is menu-driven so I can choose which modules I want to backup or restore
                                            I’m fairly new at writing scripts. They are a lot of fun
