    So I have a question about backup
    24 Posts 6 Posters 11.3k Views 5 Watching
      sdetweil @Ray
      @ray yes, that will work.
      save config.js
      u can save the module folders, or save the list of modules to install,
      git remote -v
      will list where u got the module from
      so u can git clone/npm install on restore
      with the config.js
        Ray @sdetweil
        @sdetweil that’s fantastic. I appreciate the quick response. I put a lot of effort and time in this mirror
        so is good to hear. I can back it up safely
          Ray @sdetweil
          @sdetweil forgot to ask
          so the git remote -v
          we’ll get all its information from my original config.js
          is that correct
            sdetweil @Ray
            @ray you do that in each module folder
            the info from config.js is settings and API keys for each/all the modules
            my grandson just went home from.sleepover. I can write a quick script to backup and restore
            • karsten13K
              karsten13 @sdetweil
              see also https://forum.magicmirror.builders/topic/14255/what-is-your-backup-and-restore-method
                sdetweil @Ray
                @ray i created two scripts mm_backup and mm_restore
                you can get them here
                they write/read from a folder (defaults to ~/MM_backup )
                using ~/MagicMirror as the source (default)
                (but take parms to change the names) see mm_backup.sh -h
                this creates a git repository of the 2 files and creates a tag (label) for the instance of the backup.
                you should create a (free) private repo (to keep any config settings private) on github and push the local repo there to have an offline backup
                then u can clone it anytime and restore from the appropriate tag (date/time)
                mumblebajM R 2 Replies Last reply Reply Quote 0
                • mumblebajM
                  Hi Sam. Here? I checked your Github and nothing there either. Or maybe I am missed it?
                    sdetweil @mumblebaj
                    @mumblebaj doah!!.. forgot the link
                    https://github.com/sdetweil/MagicMirror-backup-restore
                    mumblebajM 2 Replies Last reply Reply Quote 0
                    • mumblebajM
                      @sdetweil Awesome. Thanks Sam. Always nice work from you.
                      • mumblebajM
                        @sdetweil When I ran the mm_backup.sh I saw this error but it created the output in the MM_backup folder as expected.
                        usage: git init [-q | --quiet] [--bare] [--template=<template-directory>] [--shared[=<permissions>]] [<directory>]
                            --template <template-directory>
                                                  directory from which templates will be used
                            --bare                create a bare repository
                                                  specify that the git repository is to be shared amongst several users
                            -q, --quiet           be quiet
                            --separate-git-dir <gitdir>
                                                  separate git dir from working tree
                        Is this because of some options that I did not specify? After the output was created I just manually pushed to a private directory on git.
                          sdetweil @mumblebaj
                          @mumblebaj probably git version before 2.28
                          the primary branch name option didn’t come in til 2.28. 0
                          i have
                          git --version
                          git version 2.34.1
                          I will add a check…
                          to upgrade git (don’t do it for these scripts… I have fixed the script to not need this capability, just documenting how)
                          sudo add-apt-repository -y ppa:git-core/ppa
                          sudo apt update
                          sudo apt install git -y
                            sdetweil @mumblebaj
                            @mumblebaj I pushed a change to set the primary branch name a different way…
                            give it a try
                            backup to some other folder (and then u can delete that folder)
                            ./mm_backup.sh -b somefolder
                            just pushed a change to create the output folder if it doesn’t exist, instead of error…
                            • mumblebajM
                              @sdetweil Awesome. That was clean.
                              • mumblebajM
                                @sdetweil My git version is 2.20.1. Guess I need to update it.
                                  sdetweil @mumblebaj
                                  @mumblebaj said in So I have a question about backup:
                                  only if u need something
                                  • mumblebajM
                                    @sdetweil Right now, not. MM runs perfect as is. I’ll leave it for now. :beaming_face_with_smiling_eyes:
                                      sdetweil @mumblebaj
                                      @mumblebaj i don’t want to force people to upgrade, thanks for the report and test results
                                      • mumblebajM
                                        @sdetweil No worries and a pleasure.
                                          Ray @sdetweil
                                          @sdetweil hey thanks a lot. I appreciate that
                                          I will definitely check it out
                                          I kind of made my own. It’s very basic but seems to do the trick
                                          it is menu-driven so I can choose which modules I want to backup or restore
                                          I’m fairly new at writing scripts. They are a lot of fun
                                            sdetweil @Ray
                                            @ray said in So I have a question about backup:
                                            yes, indeed… i learn new stuff all the time (like parameter handling this time)
