    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 122.8k Views 16 Watching
    • G
      goedh452 @maxs
      @maxs
      I made some changes in the code. Can you download the latest version from GitHub and add the option enableReturn to the utility device? When set to false the return values are ignored and the correct value should be displayed. I’m unable to test properly since my device doesn’t generate this strange value.
      enableReturn: false,
      My config example looks like this:
      devices: [
                      idx: "304",
                      deviceHeader: "Elektriciteit",
                      useHeaderSymbol: true,
                      headerSymbol: "plug",
                      counterTodayLabel: "Vandaag",
                      counterTodayAppendText: "kWh",
                      gaugeMinValue: -3000,
                      gaugeMaxValue: 3000,
                      gaugeAppendText: "watt",
                      gaugeWidth: 200,
                      lineWidth: 16,
                      markerWidth: 16,
                      markerColor: "#F4D03F"
      M 1 Reply Last reply
        maxs @goedh452
        @goedh452
        Thanks for quick reply. Test it and works like a charm.
        :thumbs_up:
        Thanks.
        • majsoftM
          majsoft @goedh452
          @goedh452 said in MMM-Domoticz-ext: interact with Domoticz:
          You could create your own module based on the code and modify that css.
          I found that both mmm-domoticz-ext and mmm-domoticz-ext2 work separately for both modules
          If I enter them both at once in config.js it always works only the one that is written as the last one. Can anyone help please?
            Manu663
            Hi all, I’m an old geek who’s trying to keep up but learning by doing without initial training is long, difficult and the age of my brain cells doesn’t help me much.
            Could you please post some examples of your MMM-Domoticz-ext config? (from the simplest to the most elaborate, I’ll take anything that comes along!)
            It would help me to test different configurations and customize mine.
            Thanks in advance !
            G 1 Reply Last reply
            • G
              goedh452 @Manu663
              @manu663
              Please see the GitHub-page for some examples: MMM-Domoticz-ext
                Manu663 @goedh452
                @goedh452 Thank you for your quick reply, it’s much appreciated!
                I have read the whole github unfortunately, I don’t manage to get a convincing result. It doesn’t matter, I’ll calm down and read the github again over a cup of coffee and start all over again.
                But if others have examples, I’ll take them anyway ;-)
                  Manu663 @Manu663
                  Once I calmed down and reread everything from the beginning I finally managed to get a nice result.
                  I feel ashamed that I called for help when it was just a silly syntax error. :sad_but_relieved_face:
                  Anyway, thank you for the marvelous job done there !
                  • G
                    goedh452 @Manu663
                    @manu663
                    No problem at all! The module became a bit complex during the build :-)
                      Shaitan
                      Hi @goedh452,
                      Your mod is so great, but I think you already know that ;-).
                      Like the others, this is exactly what I was looking for.
                      But after installing it, it doesn’t display anything, just the title on my MM. I notice in the domoticz log that he contacts him but I do not know if it is a problem of connection or reception of data…
                      Thank a lot for your help
                      Here are the informations and screenshots :
                      Domoticz ip : 192.168.1.3
                      MM’s ip : 192.168.1.40
                      My Config.js
                      			module: "MMM-Domoticz-ext",
                      			header: "Domoticz",
                      			  apiBase: "192.168.1.3",
                      			  apiPort: "8080",
                      			  updateInterval: 5,
                      			  animationSpeed: 0,
                      			  displayType: "all",
                      			  horizontal: true,
                      			  dashboardColumnCount: 2,
                      			  showTotals: true,
                      			  dashboardRooms: [ "1", "2" ],
                      My json for IDX 1
                      	"ActTime" : xxxxxx,
                      	"AstrTwilightEnd" : "xxxxx",
                      	"AstrTwilightStart" : "xxxxx",
                      	"CivTwilightEnd" : "xxxxxx",
                      	"CivTwilightStart" : "xxxxx",
                      	"DayLength" : "xxxxxx",
                      	"NautTwilightEnd" : "xxxxx",
                      	"NautTwilightStart" : "xxxxx",
                      	"ServerTime" : "xxxxxxxxx",
                      	"SunAtSouth" : "xxxxx",
                      	"Sunrise" : "xxxxx",
                      	"Sunset" : "xxxxx",
                      	"app_version" : "2021.1",
                      	"result" :
                      			"AddjMulti" : 1.0,
                      			"AddjMulti2" : 1.0,
                      			"AddjValue" : 0.0,
                      			"AddjValue2" : 0.0,
                      			"BatteryLevel" : 255,
                      			"CustomImage" : 0,
                      			"Data" : "21.4 C, 56 %",
                      			"Description" : "",
                      			"DewPoint" : "12.26",
                      			"Favorite" : 0,
                      			"HardwareDisabled" : false,
                      			"HardwareID" : 2,
                      			"HardwareName" : "DHT 22 ext",
                      			"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
                      			"HardwareTypeVal" : 15,
                      			"HaveTimeout" : false,
                      			"Humidity" : 56,
                      			"HumidityStatus" : "Comfortable",
                      			"ID" : "14051",
                      			"LastUpdate" : "2021-11-29 15:03:03",
                      			"Name" : "DHT22 ext",
                      			"Notifications" : "false",
                      			"PlanID" : "0",
                      			"PlanIDs" :
                      			"Protected" : false,
                      			"ShowNotifications" : true,
                      			"SignalLevel" : 3,
                      			"SubType" : "THGN122/123/132, THGR122/228/238/268",
                      			"Temp" : 21.399999999999999,
                      			"Timers" : "false",
                      			"Type" : "Temp + Humidity",
                      			"TypeImg" : "temperature",
                      			"Unit" : 1,
                      			"Used" : 1,
                      			"XOffset" : "0",
                      			"YOffset" : "0",
                      			"idx" : "1",
                      			"trend" : 2
                      	"status" : "OK",
                      	"title" : "Devices"
                      My Setting on Domoticz
                      Log domoticz
                      My MM
                      • G
                        goedh452 @Shaitan
                        @shaitan
                        Hi, thanks for the compliment!
                        At first glance, I do not see any reason why it doesn’t work. Could you try opening the mirror in a browser on a computer: :8080.
                        Then open the monitor with F12 and see if the module generates error messages. Post the error messages here please.
                          Shaitan
                          This is what you want @goedh452 ? There are only these errors
                          S G 2 Replies Last reply
                            sdetweil @Shaitan
                            @shaitan by default custom.css doesn’t exist… if you used my install script I would have created an empty one
                            but u can do this
                            touch ~/MagicMirror/css/custom.css
                              Shaitan @sdetweil
                              Hi @sdetweil
                              the new file has been created, but nothing on the MM’s screen… But this errors are been vanish !
                                sdetweil @Shaitan
                                @shaitan cool… black screen, maybe this
                                  Shaitan @sdetweil
                                  sorry I misled you. with your command the errors have disappeared, but the display of my MM is the same as before. there is no black screen
                                    sdetweil @Shaitan
                                    @shaitan ok, I can’t help with the module operation… have no system like that
                                      Shaitan @sdetweil
                                      @sdetweil thanks anyway for this errors ! Less is the better !
                                      • G
                                        goedh452 @Shaitan
                                        @shaitan
                                        Ok, so the module doesn’t produce any errors. I’ll dive into it to see what is causing the problem.
                                        S 2 Replies Last reply
                                          Shaitan @goedh452
                                          @goedh452 ok thank you !
                                            Shaitan @goedh452
                                            @goedh452
                                            I started from zero to be sure that it is not a problem between your module and another program on my pi.
                                            So I did a new installation of MM on another Raspberry Pi with a clean raspian.
                                            Above, there is only your modules installed (I just copy my config.js from my other MM).
                                            Here is the MM launch screen with SSH :
                                            • 5 / 7
