    MM2 not loading text
    22 Posts 4 Posters 9.4k Views 3 Watching
      Beth
      @sdetweil how do i use your script?
        sdetweil @Beth
        @beth said in MM2 not loading text:
        it says
        fixuppm2.sh, cut/paste this line into the terminal window on your device
          Beth @sdetweil
          @sdetweil also i did the command and it said to type pm2 save so i did (i don’t remember the txt) then it gave me a err and said if i want to force save to type pm2 save --force i did that and now when i plug in the pi after showing the mm2 screen it just goes to a black screen
            sdetweil @Beth
            @beth this is the line you copy/pasted
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
            right?
            u don’t need to git clone this repo, just copy/paste the line
              sdetweil @Beth
              @beth black screen is another problem… (but pm2 launched MM on boot, so pm2 is ok)
              typically it means a library needed by one of the MM modules you are using is missing
              (we removed some dead libraries, in 2.16 and 2.17, but many modules didn’t document needing them, so oops…)
              SO, you need to look at the logs
              minimize MM, alt-spacebar, n
              then open a terminal window
              ctrl-alt-t
              then type
              pm2 logs – lines=100
              and look for module not found
              we know about
              request
              rrule-alt
              valid-url
                Beth
                i can’t “minimize” mm2 it is just a black screen with a terminal window it just shows the mm2 logo and to the left a terminal window (it is rlly weird and looks the same as the backround all black)on the bottom left (below the terminal window) it says dphys-swapfile.service
                  sdetweil @Beth
                  @beth that is something else.
                  do you have ssh enabled?
                    Beth @sdetweil
                    @sdetweil i don’t have ssh although i do have vnc
                      sdetweil @Beth
                      @beth I think that is hung before mm gets running. the bottom message is a boot time message
                        Beth @sdetweil
                        @sdetweil ok so what do i need to do
                          sdetweil @Beth
                          @beth make a new sd card? i don’t know otherwise
