    MM2 not loading text
    22 Posts 4 Posters 10.2k Views 3 Watching
      sdetweil @Beth
      @beth said in MM2 not loading text:
      /home/pi/
      u are not in the MagicMirror folder for npm start
      and its pm2 start (notice the space)
      pm2 status will show u the pm2 currently managed apps
      B 1 Reply Last reply
        Beth @sdetweil
        @sdetweil i did that and it gave me the following err:
        [PM2] spawning PM2 daemon with pm2 _home=/home/pi.pm2
        [PM2] PM2 successfully daemonized
        [PM2] [ERROR] Script not found: /home/pi/MagicMirror/mm.sh
          sdetweil @Beth
          ok, you used some old instructions, cause the file was moved to the installers folder a long time ago…
          pm2 status
          pm2 delete xx
          where xx is the number of the line in the status (usually 0)
          or the name in the line
          pm2 save
          then use my script to fixup pm2
          see https://github.com/sdetweil/MagicMirror_scripts
          the last command listed, fixuppm2.sh is the one u want to copy/paste to your terminal window
            Beth
            @sdetweil how do i use your script?
              sdetweil @Beth
              it says
              fixuppm2.sh, cut/paste this line into the terminal window on your device
                Beth @sdetweil
                @sdetweil also i did the command and it said to type pm2 save so i did (i don’t remember the txt) then it gave me a err and said if i want to force save to type pm2 save --force i did that and now when i plug in the pi after showing the mm2 screen it just goes to a black screen
                S 2 Replies Last reply
                  sdetweil @Beth
                  @beth this is the line you copy/pasted
                  bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                  right?
                  u don’t need to git clone this repo, just copy/paste the line
                    sdetweil @Beth
                    @beth black screen is another problem… (but pm2 launched MM on boot, so pm2 is ok)
                    typically it means a library needed by one of the MM modules you are using is missing
                    (we removed some dead libraries, in 2.16 and 2.17, but many modules didn’t document needing them, so oops…)
                    SO, you need to look at the logs
                    minimize MM, alt-spacebar, n
                    then open a terminal window
                    ctrl-alt-t
                    then type
                    pm2 logs – lines=100
                    and look for module not found
                    we know about
                    request
                    rrule-alt
                    valid-url
                      Beth
                      i can’t “minimize” mm2 it is just a black screen with a terminal window it just shows the mm2 logo and to the left a terminal window (it is rlly weird and looks the same as the backround all black)on the bottom left (below the terminal window) it says dphys-swapfile.service
                        sdetweil @Beth
                        @beth that is something else.
                        do you have ssh enabled?
                          Beth @sdetweil
                          @sdetweil i don’t have ssh although i do have vnc
                            sdetweil @Beth
                            @beth I think that is hung before mm gets running. the bottom message is a boot time message
                              Beth @sdetweil
                              @sdetweil ok so what do i need to do
                                sdetweil @Beth
                                @beth make a new sd card? i don’t know otherwise
