    MM2 not loading text
    22 Posts 4 Posters 7.7k Views 3 Watching
      sdetweil @Beth
      @beth check your router to see if the system has a reserved address
      u can find its address with
      ifconfig command in a terminal window
      ethxx is ethernet wired
      wlanxx is wireless lan
      swvalentiS 1 Reply Last reply Reply Quote 0
      • swvalentiS Offline
        swvalenti Project Sponsor @sdetweil
        @Beth what Sam said
          Beth
          UPDATE: there is a command window that papers on the boot up screen it does not leave i connected keyboard/mouse to it and can enter commands like a terminal window although pm2start will not work and npm start gives the following err (note i copied this by hand so there may be slight imperfections)
          npm ERR! code ENOENT
          npm ERR! sysca11 open
          npm ERR! path /home/pi/package . json
          npm ERR! errno -2
          npm ERR! enoent no such file or directory, open ‘/home/pi/package . jason’
          npm ERR! enoent This is related to npm not being able to find a file.
          npm ERR! enoent
            sdetweil @Beth
            @beth said in MM2 not loading text:
            /home/pi/
            u are not in the MagicMirror folder for npm start
            and its pm2 start (notice the space)
            pm2 status will show u the pm2 currently managed apps
              Beth @sdetweil
              @sdetweil i did that and it gave me the following err:
              [PM2] spawning PM2 daemon with pm2 _home=/home/pi.pm2
              [PM2] PM2 successfully daemonized
              [PM2] [ERROR] Script not found: /home/pi/MagicMirror/mm.sh
                sdetweil @Beth
                ok, you used some old instructions, cause the file was moved to the installers folder a long time ago…
                pm2 status
                pm2 delete xx
                where xx is the number of the line in the status (usually 0)
                or the name in the line
                pm2 save
                then use my script to fixup pm2
                see https://github.com/sdetweil/MagicMirror_scripts
                the last command listed, fixuppm2.sh is the one u want to copy/paste to your terminal window
                  Beth
                  @sdetweil how do i use your script?
                    sdetweil @Beth
                    it says
                    fixuppm2.sh, cut/paste this line into the terminal window on your device
                      Beth @sdetweil
                      @sdetweil also i did the command and it said to type pm2 save so i did (i don’t remember the txt) then it gave me a err and said if i want to force save to type pm2 save --force i did that and now when i plug in the pi after showing the mm2 screen it just goes to a black screen
                        sdetweil @Beth
                        @beth this is the line you copy/pasted
                        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                        right?
                        u don’t need to git clone this repo, just copy/paste the line
