    MM2 not loading text
    22 Posts 4 Posters 9.8k Views 3 Watching
      sdetweil @Beth
      @beth said in MM2 not loading text:
      : /home/pi/MagicMirror/mm.sh
      ok, you used some old instructions, cause the file was moved to the installers folder a long time ago…
      pm2 status
      pm2 delete xx
      where xx is the number of the line in the status (usually 0)
      or the name in the line
      pm2 save
      then use my script to fixup pm2
      see https://github.com/sdetweil/MagicMirror_scripts
      the last command listed, fixuppm2.sh is the one u want to copy/paste to your terminal window
        Beth
        @sdetweil how do i use your script?
          sdetweil @Beth
          it says
          fixuppm2.sh, cut/paste this line into the terminal window on your device
            Beth @sdetweil
            @sdetweil also i did the command and it said to type pm2 save so i did (i don’t remember the txt) then it gave me a err and said if i want to force save to type pm2 save --force i did that and now when i plug in the pi after showing the mm2 screen it just goes to a black screen
              sdetweil @Beth
              @beth this is the line you copy/pasted
              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
              right?
              u don’t need to git clone this repo, just copy/paste the line
                sdetweil @Beth
                @beth black screen is another problem… (but pm2 launched MM on boot, so pm2 is ok)
                typically it means a library needed by one of the MM modules you are using is missing
                (we removed some dead libraries, in 2.16 and 2.17, but many modules didn’t document needing them, so oops…)
                SO, you need to look at the logs
                minimize MM, alt-spacebar, n
                then open a terminal window
                ctrl-alt-t
                then type
                pm2 logs – lines=100
                and look for module not found
                we know about
                request
                rrule-alt
                valid-url
                  Beth
                  i can’t “minimize” mm2 it is just a black screen with a terminal window it just shows the mm2 logo and to the left a terminal window (it is rlly weird and looks the same as the backround all black)on the bottom left (below the terminal window) it says dphys-swapfile.service
                    sdetweil @Beth
                    @beth that is something else.
                    do you have ssh enabled?
                      Beth @sdetweil
                      @sdetweil i don’t have ssh although i do have vnc
                        sdetweil @Beth
                        @beth I think that is hung before mm gets running. the bottom message is a boot time message
                          Beth @sdetweil
                          @sdetweil ok so what do i need to do
                            sdetweil @Beth
                            @beth make a new sd card? i don’t know otherwise
