    MM2 not loading text
    22 Posts 4 Posters 10.2k Views 3 Watching
    • cowboysdudeC
      cowboysdude Module Developer @Beth
      @beth run it in ‘dev mode’ and see what the output is.
        sdetweil @cowboysdude
        @cowboysdude they can’t get into the machine… vnc doesn’t connect
        swvalentiS 1 Reply Last reply
        • swvalentiS
          swvalenti Project Sponsor @sdetweil
          Did the IP change by chance? Check to see if IP is static and ssh into pi that way.
          B 1 Reply Last reply
            Beth @swvalenti
            @swvalenti how do i check?
              sdetweil @Beth
              @beth check your router to see if the system has a reserved address
              u can find its address with
              ifconfig command in a terminal window
              ethxx is ethernet wired
              wlanxx is wireless lan
              • swvalentiS
                @Beth what Sam said
                  Beth
                  UPDATE: there is a command window that papers on the boot up screen it does not leave i connected keyboard/mouse to it and can enter commands like a terminal window although pm2start will not work and npm start gives the following err (note i copied this by hand so there may be slight imperfections)
                  npm ERR! code ENOENT
                  npm ERR! sysca11 open
                  npm ERR! path /home/pi/package . json
                  npm ERR! errno -2
                  npm ERR! enoent no such file or directory, open ‘/home/pi/package . jason’
                  npm ERR! enoent This is related to npm not being able to find a file.
                  npm ERR! enoent
                    sdetweil @Beth
                    @beth said in MM2 not loading text:
                    /home/pi/
                    u are not in the MagicMirror folder for npm start
                    and its pm2 start (notice the space)
                    pm2 status will show u the pm2 currently managed apps
                      Beth @sdetweil
                      @sdetweil i did that and it gave me the following err:
                      [PM2] spawning PM2 daemon with pm2 _home=/home/pi.pm2
                      [PM2] PM2 successfully daemonized
                      [PM2] [ERROR] Script not found: /home/pi/MagicMirror/mm.sh
                        sdetweil @Beth
                        ok, you used some old instructions, cause the file was moved to the installers folder a long time ago…
                        pm2 status
                        pm2 delete xx
                        where xx is the number of the line in the status (usually 0)
                        or the name in the line
                        pm2 save
                        then use my script to fixup pm2
                        see https://github.com/sdetweil/MagicMirror_scripts
                        the last command listed, fixuppm2.sh is the one u want to copy/paste to your terminal window
                          Beth
                          @sdetweil how do i use your script?
                            sdetweil @Beth
                            it says
                            fixuppm2.sh, cut/paste this line into the terminal window on your device
                              Beth @sdetweil
                              @sdetweil also i did the command and it said to type pm2 save so i did (i don’t remember the txt) then it gave me a err and said if i want to force save to type pm2 save --force i did that and now when i plug in the pi after showing the mm2 screen it just goes to a black screen
                              S 2 Replies Last reply
                                sdetweil @Beth
                                @beth this is the line you copy/pasted
                                bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                                right?
                                u don’t need to git clone this repo, just copy/paste the line
                                  sdetweil @Beth
                                  @beth black screen is another problem… (but pm2 launched MM on boot, so pm2 is ok)
                                  typically it means a library needed by one of the MM modules you are using is missing
                                  (we removed some dead libraries, in 2.16 and 2.17, but many modules didn’t document needing them, so oops…)
                                  SO, you need to look at the logs
                                  minimize MM, alt-spacebar, n
                                  then open a terminal window
                                  ctrl-alt-t
                                  then type
                                  pm2 logs – lines=100
                                  and look for module not found
                                  we know about
                                  request
                                  rrule-alt
                                  valid-url
                                    Beth
                                    i can’t “minimize” mm2 it is just a black screen with a terminal window it just shows the mm2 logo and to the left a terminal window (it is rlly weird and looks the same as the backround all black)on the bottom left (below the terminal window) it says dphys-swapfile.service
                                      sdetweil @Beth
                                      @beth that is something else.
                                      do you have ssh enabled?
                                        Beth @sdetweil
                                        @sdetweil i don’t have ssh although i do have vnc
                                          sdetweil @Beth
                                          @beth I think that is hung before mm gets running. the bottom message is a boot time message
                                            Beth @sdetweil
                                            @sdetweil ok so what do i need to do
