MM2 not loading text
22 Posts 4 Posters 6.0k Views 3 Watching
    Beth
    hi i made my MM2 a year or so ago and it has worked fine but recently on boot it will show the mm2 screen and then not load the text it just shows a black screen i have tried to log into vnc but the RPI refuses the connection i tried swapping RPI’s and that didn’t work i also can’t open a command window or shut it down what should i do?
    C 1 Reply Last reply Aug 31, 2021, 12:06 AM Reply Quote 0
      cowboysdude Module Developer @Beth
      @beth run it in ‘dev mode’ and see what the output is.
      S 1 Reply Last reply Aug 31, 2021, 12:11 AM Reply Quote 0
        sdetweil @cowboysdude
        @cowboysdude they can’t get into the machine… vnc doesn’t connect
        S 1 Reply Last reply Aug 31, 2021, 12:26 AM Reply Quote 0
          swvalenti Project Sponsor @sdetweil
          Did the IP change by chance? Check to see if IP is static and ssh into pi that way.
          B 1 Reply Last reply Sep 18, 2021, 8:15 PM Reply Quote 1
            Beth @swvalenti
            @swvalenti how do i check?
            S 1 Reply Last reply Sep 18, 2021, 8:17 PM Reply Quote 0
              sdetweil @Beth
              @beth check your router to see if the system has a reserved address
              u can find its address with
              ifconfig command in a terminal window
              ethxx is ethernet wired
              wlanxx is wireless lan
              S 1 Reply Last reply Sep 18, 2021, 8:18 PM Reply Quote 0
                @Beth what Sam said
                  Beth
                  UPDATE: there is a command window that papers on the boot up screen it does not leave i connected keyboard/mouse to it and can enter commands like a terminal window although pm2start will not work and npm start gives the following err (note i copied this by hand so there may be slight imperfections)
                  npm ERR! code ENOENT
                  npm ERR! sysca11 open
                  npm ERR! path /home/pi/package . json
                  npm ERR! errno -2
                  npm ERR! enoent no such file or directory, open ‘/home/pi/package . jason’
                  npm ERR! enoent This is related to npm not being able to find a file.
                  npm ERR! enoent
                  S 1 Reply Last reply Sep 18, 2021, 8:24 PM Reply Quote 0
                    sdetweil @Beth
                    @beth said in MM2 not loading text:
                    /home/pi/
                    u are not in the MagicMirror folder for npm start
                    and its pm2 start (notice the space)
                    pm2 status will show u the pm2 currently managed apps
                    B 1 Reply Last reply Oct 9, 2021, 9:29 PM Reply Quote 0
                      Beth @sdetweil
                      @sdetweil i did that and it gave me the following err:
                      [PM2] spawning PM2 daemon with pm2 _home=/home/pi.pm2
                      [PM2] PM2 successfully daemonized
                      [PM2] [ERROR] Script not found: /home/pi/MagicMirror/mm.sh
                      S 1 Reply Last reply Oct 9, 2021, 10:39 PM Reply Quote 0
