    MM2 not loading text
    22 Posts 4 Posters 10.2k Views 3 Watching
    • swvalentiS
      swvalenti Project Sponsor @sdetweil
      Did the IP change by chance? Check to see if IP is static and ssh into pi that way.
      B 1 Reply Last reply
        Beth @swvalenti
        @swvalenti how do i check?
          sdetweil @Beth
          @beth check your router to see if the system has a reserved address
          u can find its address with
          ifconfig command in a terminal window
          ethxx is ethernet wired
          wlanxx is wireless lan
          swvalentiS 1 Reply Last reply
          • swvalentiS
            @Beth what Sam said
              Beth
              UPDATE: there is a command window that papers on the boot up screen it does not leave i connected keyboard/mouse to it and can enter commands like a terminal window although pm2start will not work and npm start gives the following err (note i copied this by hand so there may be slight imperfections)
              npm ERR! code ENOENT
              npm ERR! sysca11 open
              npm ERR! path /home/pi/package . json
              npm ERR! errno -2
              npm ERR! enoent no such file or directory, open ‘/home/pi/package . jason’
              npm ERR! enoent This is related to npm not being able to find a file.
              npm ERR! enoent
                sdetweil @Beth
                @beth said in MM2 not loading text:
                /home/pi/
                u are not in the MagicMirror folder for npm start
                and its pm2 start (notice the space)
                pm2 status will show u the pm2 currently managed apps
                  Beth @sdetweil
                  @sdetweil i did that and it gave me the following err:
                  [PM2] spawning PM2 daemon with pm2 _home=/home/pi.pm2
                  [PM2] PM2 successfully daemonized
                  [PM2] [ERROR] Script not found: /home/pi/MagicMirror/mm.sh
                    sdetweil @Beth
                    ok, you used some old instructions, cause the file was moved to the installers folder a long time ago…
                    pm2 status
                    pm2 delete xx
                    where xx is the number of the line in the status (usually 0)
                    or the name in the line
                    pm2 save
                    then use my script to fixup pm2
                    see https://github.com/sdetweil/MagicMirror_scripts
                    the last command listed, fixuppm2.sh is the one u want to copy/paste to your terminal window
                      Beth
                      @sdetweil how do i use your script?
                        sdetweil @Beth
                        it says
                        fixuppm2.sh, cut/paste this line into the terminal window on your device
                          Beth @sdetweil
                          @sdetweil also i did the command and it said to type pm2 save so i did (i don’t remember the txt) then it gave me a err and said if i want to force save to type pm2 save --force i did that and now when i plug in the pi after showing the mm2 screen it just goes to a black screen
                          S 2 Replies Last reply
                            sdetweil @Beth
                            @beth this is the line you copy/pasted
                            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                            right?
                            u don’t need to git clone this repo, just copy/paste the line
                              sdetweil @Beth
                              @beth black screen is another problem… (but pm2 launched MM on boot, so pm2 is ok)
                              typically it means a library needed by one of the MM modules you are using is missing
                              (we removed some dead libraries, in 2.16 and 2.17, but many modules didn’t document needing them, so oops…)
                              SO, you need to look at the logs
                              minimize MM, alt-spacebar, n
                              then open a terminal window
                              ctrl-alt-t
                              then type
                              pm2 logs – lines=100
                              and look for module not found
                              we know about
                              request
                              rrule-alt
                              valid-url
                                Beth
                                i can’t “minimize” mm2 it is just a black screen with a terminal window it just shows the mm2 logo and to the left a terminal window (it is rlly weird and looks the same as the backround all black)on the bottom left (below the terminal window) it says dphys-swapfile.service
                                  sdetweil @Beth
                                  @beth that is something else.
                                  do you have ssh enabled?
                                    Beth @sdetweil
                                    @sdetweil i don’t have ssh although i do have vnc
                                      sdetweil @Beth
                                      @beth I think that is hung before mm gets running. the bottom message is a boot time message
                                        Beth @sdetweil
                                        @sdetweil ok so what do i need to do
                                          sdetweil @Beth
                                          @beth make a new sd card? i don’t know otherwise
