    MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform
    11 Posts 6 Posters 3.0k Views 6 Watching
    • K Offline
      Katai
      MMM-BackgroundSlideshow doesn’t seem to work.
      /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      [13.12.2021 00:33.17.130] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.
      [13.12.2021 00:33.17.155] [ERROR] App threw an error during load
      [13.12.2021 00:33.17.158] [ERROR] Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.
          at Object.hasVendoredLibvips (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/libvips.js:82:13)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/constructor.js:7:22)
          at Module._compile (internal/modules/cjs/loader.js:1078:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
          at Module.load (internal/modules/cjs/loader.js:935:32)
          at Module._load (internal/modules/cjs/loader.js:776:14)
          at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
          at Module.require (internal/modules/cjs/loader.js:959:19)
          at require (internal/modules/cjs/helpers.js:88:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/index.js:3:15)
      [13.12.2021 00:33.17.161] [ERROR] Whoops! There was an uncaught exception...
      [13.12.2021 00:33.17.169] [ERROR] Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.
      Any clue what might be going on here?
        sdetweil @Katai
        @katai tell us more
        output of
        uname -a
        and
        lsb_release -a
          Brandoney @sdetweil
          I have this issue.
           uname -a
          Linux raspberrypi 5.10.63-v7l+ #1488 SMP Thu Nov 18 16:15:28 GMT 2021 armv7l GNU/Linux
          pi@raspberrypi:~/MagicMirror/config $ lsb_release -a
          No LSB modules are available.
          Distributor ID: Raspbian
          Description:    Raspbian GNU/Linux 11 (bullseye)
          Release:        11
          Codename:       bullseye
          SyntaxError: Unexpected identifier
              at wrapSafe (internal/modules/cjs/loader.js:986:16)
              at Module._compile (internal/modules/cjs/loader.js:1034:27)
              at loadConfig (/home/pi/MagicMirror/js/app.js:69:14)
              at App.start (/home/pi/MagicMirror/js/app.js:212:3)
          [13.12.2021 21:11.52.510] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.
          [13.12.2021 21:11.52.533] [ERROR] App threw an error during load
          [13.12.2021 21:11.52.535] [ERROR] Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.
          [13.12.2021 21:11.52.536] [ERROR] Whoops! There was an uncaught exception...
          [13.12.2021 21:11.52.539] [ERROR] Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.
          [13.12.2021 21:11.52.540] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [13.12.2021 21:11.52.540] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            sdetweil @Brandoney
            @brandoney yes, I saw your report before…
            can u also do
            node -v
            and npm -v
              Brandoney @sdetweil
              @sdetweil said in MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform:
              node -v
              and npm -v
              node -v
              v14.18.2
              pi@raspberrypi:~/MagicMirror/config $ npm -v
              6.14.15
                sdetweil @Brandoney
                @brandoney thx. this looks like a problem with bullseye and node
                here is similar sharp problem
                https://github.com/lovell/sharp/issues/2287
                I don’t know what to do about this
                • karsten13K Offline
                  karsten13 @sdetweil
                  there is already an issue in the github repo
                    sdetweil @karsten13
                    @karsten13 yes, that is the one I linked to. but it says armv6, not armv7…
                    • BKeyportB Offline
                      @sdetweil FWIW, I downgraded to buster and it does it there as well, I’ve disabled the module for the short term.
                        sdetweil @BKeyport
                        @bkeyport I think one would have to set the parms on install per the sharp doc
                        https://sharp.pixelplumbing.com/install
                        looks like prebuilt binaries are not produced for 32bit os systems (raspi os)
                        • wishmaster270W Offline
                          wishmaster270 Module Developer
                          For me it worked to install a self compiled version of vips…
                          sudo apt install -y build-essential libglib2.0 libjpeg9 libopenjp2-7 librsvg2-dev imagemagick libtiff5-dev
                          wget https://github.com/libvips/libvips/releases/download/v8.12.1/vips-8.12.1.tar.gz
                          tar xfvz vips-8.12.1.tar.gz
                          cd vips-8.12.1
                          ./configure
                          make
                          sudo make install
                          sudo ldconfig
                          npm install
                          It will take a while to compile the library and a lot of disk space will be used.
