MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform
@sdetweil said in MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform:
node -v
and npm -vnode -v
v14.18.2
pi@raspberrypi:~/MagicMirror/config $ npm -v
6.14.15 -
@brandoney thx. this looks like a problem with bullseye and node
here is similar sharp problem
https://github.com/lovell/sharp/issues/2287I don’t know what to do about this
there is already an issue in the github repo
@karsten13 yes, that is the one I linked to. but it says armv6, not armv7…
@sdetweil FWIW, I downgraded to buster and it does it there as well, I’ve disabled the module for the short term.
@bkeyport I think one would have to set the parms on install per the sharp doc
https://sharp.pixelplumbing.com/install
looks like prebuilt binaries are not produced for 32bit os systems (raspi os)
For me it worked to install a self compiled version of vips…
sudo apt install -y build-essential libglib2.0 libjpeg9 libopenjp2-7 librsvg2-dev imagemagick libtiff5-dev wget https://github.com/libvips/libvips/releases/download/v8.12.1/vips-8.12.1.tar.gz tar xfvz vips-8.12.1.tar.gz cd vips-8.12.1 ./configure make sudo make install sudo ldconfig npm installIt will take a while to compile the library and a lot of disk space will be used.
