    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
    • L
      louise
      When I try to use your MMM-config I get this error…
      pi@raspberrypi:~ $ ~/MagicMirror/modules
      bash: /home/pi/MagicMirror/modules: No such file or directory
        sdetweil @louise
        @louise explain a little more… where are u typing that info ?
        where is your MagicMirror installed?
        read the link in my signature How to add modules (I didn’t write it)
        L 2 Replies Last reply
        • L
          louise @sdetweil
          @sdetweil I am soooooo new at this. I had it working once by someone else, card got corrupted and the person building it no longer available. So I’m trying to rebuild on my own. Not a coder, programmer or anything else.
          I’ve tried the modules, got the calendar and weather in the config.js but it doesn’t run.
          So what do you need me to show you?
          • L
            louise @sdetweil
            @sdetweil This is what I get when trying to run Magic Mirror from npm start
            JavaScript error occurred in the main process
            Uncaught Exception:
            Error: Cannot find module ‘/home/pi/MagicMirror/js/…/modules/default/defaultmodules’
            Require stack:
            • at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
              at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
              at Module._load (internal/modules/cjs/loader.js:732:27)
              at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
              at Module.require (internal/modules/cjs/loader.js:959:19)
              at require (internal/modules/cjs/helpers.js:88:18)
              at Object. (/home/pi/MagicMirror/js/app.js:16:24)
              at Module._compile (internal/modules/cjs/loader.js:1078:30)
              at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10)
              sdetweil @louise
              @louise so, read the link… it will help A LOT…
              from a command line, (terminal window) you need to change folders
              cd new_folder_name
              just like on windows
              (except here the names are case sensitive)
              when I said in doc
              Clone this repo into ~/MagicMirror/modules directory.
              that means change directory (cd command)
              cd ~/MagicMirror/modules
              u left off the cd
              but the error implies you have not installed MagicMirror yet…
              I have a script for that
              see
              its just a cut/paste of one line
                sdetweil @louise
                @louise errors. looks like you didn’t do npm install after git clone of MagicMirror repo …
                  @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                  @josh45631 @mumblebaj
                  @josh45631 @mumblebaj i updated the readme to specify MM_IP_Address instead of ‘machine_name’ if you need/want/have to use the manual reivew url instead of the QR
                    brianlove
                    Thank you for this! So I’m new to MM (you’ve got to love that phrase, right?) but slowly learning. I’ve got MM-Config running and can access it via a separate laptop on my network. I can see the running modules, and the QR Code, but when I go to turn a module on/off and “save,” it won’t do anything on the MM side. I can see the “config_last_change” file has the date and time, but can’t figure out why nothing is changing or saving.
                    Any ideas? Thanks again!
                    BKeyportB S 2 Replies Last reply
                    • BKeyportB
                      BKeyport Module Developer @brianlove
                      @brianlove Did you restart your Mirror? (Not the whole pi, just the mirror app)
                      If so, please elaborate. Which module are you toggling? Can you share the config segment showing the change?
                        brianlove
                        @bkeyport
                        I did restart the mirror. As for the modules, I’ve tried multiple ones, but specifically currentweather & CalendarWeek.
                        	module:"MMM-Config",
                        	position:"top_right",  // the QR code (if requested) will appear here
                        	config:{
                          sdetweil @brianlove
                          @brianlove I will check when I can.
                          could u enable debug in my module
                          ( if using pm2, do pm2 stop all)
                          then start with
                          npm start > somefile.txt
                          then do the edit and save on the form
                          and then stop mm (ctrl-q) and send me the
                          somefile.txt via email.
                          same userid as here at gmail.
                          thanks
                            doogy_rev
                            Hi All,
                            I reinstalled my MM this week and decided to use this module to do the configurations. Its all installed and I can see all my modules, however it seems to be hit and miss on enabling and setting the positions. for example,
                            default clock - this would not enable, I manually enabled it in the config and now shows Blue but can not set the position, either from the page or in the config.
                            Default calendar - this enabled ok, shows blue, but can not set the position, does not save
                            MMM-OpenWeatherForecast - works perfectly
                            newsfeed - works perfectly.
                            Any ideas on why some modules seem to be hit or miss?
                            Sorry for the thread resurrection, was not sure where to post.
                              sdetweil @doogy_rev
                              @doogy_rev set debug in my module config
                              debug:true,
                              then start mm like this
                              npm start >somefile.txt
                              if you use pm2 for autostart
                              before the above do
                              pm2 stop all
                              after running and ‘saving’
                              ctrl-c to stop mm
                              send the somefile.txt to my email, or open an issue on the module and attach it there. (warning this log file has full text contents of config.js, so sending as email is better as issues are public). my email is this same userid at gmail
                              also, positions are set down below, not in the config up above… right?
                              D 1 Reply Last reply
                                doogy_rev @sdetweil
                                @sdetweil I just emailed you the file, and yes I am setting the positions using the positions drop down menu at the bottom.
                                  sdetweil @doogy_rev
                                  @doogy_rev yes, checking shortly
                                    sdetweil @doogy_rev
                                    @doogy_rev see email for downloading fix
                                      doogy_rev @sdetweil
                                      @sdetweil Works like a champ! Thank you for looking in to this and fixing.
                                        I posted a new release the other day, which finally fixes compliments the right way, and enables other module authors to leverage the same capabilities.
                                        documented in the readme.
                                          Socrates
                                          I love the idea of this module, not sure why i missed it out before. Anywho now that i am trying to set it up, i have installed the module (did not use sudo).
                                          Inserted this much code with no modification.
                                                          position:"bottom_right",  // the QR code (if requested) will appear here
                                                          config:{
                                          And when i go to the URL i see a blank page.
                                            sdetweil @Socrates
                                            @Socrates SOOOOO much fun, because there are no types in javascript and no standards for modules, i have to discover and guess the author’s intent.
                                            sometimes i have a bug, sometimes they do weird unexpected things
                                            can you look at the console where you do npm start?
                                            if you use pm2, then
                                            pn2 logs --lines=xxxx
                                            where xxxx is a number of lines to display, default 15
                                            I’ve tested w a lot of modules, but not all
                                            can u give me a list of all the modules in your config.js
                                            grep "module:" ~/MagicMirror/config/config.js | uniq | sort -h
                                            you didn’t see it cause its not listed in the modules list
                                            would you be willing to send me
                                            a copy of your config.js, xxx out apikeys, private data urls, but make sure to leave the structure
                                            from the the module folder, the
                                            defaults.js
                                            and the schema3.json —/ again edit out private things (near the bottom)
                                            i do not share info sent to me, ever,
                                            you can also attach the cleaned files to an issue on the module github page
                                            if emailing
                                            .js files have to be renamed by adding .txt to the end
                                            defaults and schema3 are constructed from your installed modules
                                            me email is the same userid as here at gmail.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
