    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
      sdetweil @mumblebaj
      @mumblebaj u did change the symbolic names to actual, right?
      machine_name
      MM_port
      right?
        sdetweil @mumblebaj
        @mumblebaj windows should have worked
        can u tell me what the url was?
        when u configure mm for address:“0.0.0.0”
        it’s not something I can connect to
        so I get the machine hostname
        I guess I need to figure out an IP address…
        mumblebajM 1 Reply Last reply
        • mumblebajM
          @sdetweil The QR code gave me machine name. But I figured that could not be correct. When I used the review URL earlier it did not work, When I started my Ubuntu Instance now and tried review with this URL:
          http://localhost:8080/modules/MMM-Config/review
          it worked fine and resolved to the following:
          http://localhost:8080/modules/MMM-Config/config.html?port=8300
          which I guess is what you were referring to?
          S 2 Replies Last reply
            sdetweil @mumblebaj
            @mumblebaj yes but localhost will only work w browser inside same machine as mm
              sdetweil @mumblebaj
              @mumblebaj typically dhcp addresses now register the hostname in the router DNS server.
                josh45631 @sdetweil
                @sdetweil I am using my cell phone connected to my wifi network. When I scan the code it sends me to
                http://raspberrypi:8080/modules/MMM-Config/review
                When I replace “raspberrypi” with the actual ip of the pi, it works.
                  sdetweil @josh45631
                  @josh45631 yes
                  I ‘assumed’ that name will work… doesn’t…
                  will fix, thx
                    @josh45631 @mumblebaj do a git pull in the module folder, and then restart mm and try the qr image again
                    • L
                      louise
                      When I try to use your MMM-config I get this error…
                      pi@raspberrypi:~ $ ~/MagicMirror/modules
                      bash: /home/pi/MagicMirror/modules: No such file or directory
                        sdetweil @louise
                        @louise explain a little more… where are u typing that info ?
                        where is your MagicMirror installed?
                        read the link in my signature How to add modules (I didn’t write it)
                        L 2 Replies Last reply
                        • L
                          louise @sdetweil
                          @sdetweil I am soooooo new at this. I had it working once by someone else, card got corrupted and the person building it no longer available. So I’m trying to rebuild on my own. Not a coder, programmer or anything else.
                          I’ve tried the modules, got the calendar and weather in the config.js but it doesn’t run.
                          So what do you need me to show you?
                          • L
                            louise @sdetweil
                            @sdetweil This is what I get when trying to run Magic Mirror from npm start
                            JavaScript error occurred in the main process
                            Uncaught Exception:
                            Error: Cannot find module ‘/home/pi/MagicMirror/js/…/modules/default/defaultmodules’
                            Require stack:
                            • at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
                              at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
                              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                              at Module._load (internal/modules/cjs/loader.js:732:27)
                              at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
                              at Module.require (internal/modules/cjs/loader.js:959:19)
                              at require (internal/modules/cjs/helpers.js:88:18)
                              at Object. (/home/pi/MagicMirror/js/app.js:16:24)
                              at Module._compile (internal/modules/cjs/loader.js:1078:30)
                              at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10)
                              sdetweil @louise
                              @louise so, read the link… it will help A LOT…
                              from a command line, (terminal window) you need to change folders
                              cd new_folder_name
                              just like on windows
                              (except here the names are case sensitive)
                              when I said in doc
                              Clone this repo into ~/MagicMirror/modules directory.
                              that means change directory (cd command)
                              cd ~/MagicMirror/modules
                              u left off the cd
                              but the error implies you have not installed MagicMirror yet…
                              I have a script for that
                              see
                              its just a cut/paste of one line
                                sdetweil @louise
                                @louise errors. looks like you didn’t do npm install after git clone of MagicMirror repo …
                                  @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                                  @josh45631 @mumblebaj i updated the readme to specify MM_IP_Address instead of ‘machine_name’ if you need/want/have to use the manual reivew url instead of the QR
                                    brianlove
                                    Thank you for this! So I’m new to MM (you’ve got to love that phrase, right?) but slowly learning. I’ve got MM-Config running and can access it via a separate laptop on my network. I can see the running modules, and the QR Code, but when I go to turn a module on/off and “save,” it won’t do anything on the MM side. I can see the “config_last_change” file has the date and time, but can’t figure out why nothing is changing or saving.
                                    Any ideas? Thanks again!
                                    BKeyportB S 2 Replies Last reply
                                    • BKeyportB
                                      BKeyport Module Developer @brianlove
                                      @brianlove Did you restart your Mirror? (Not the whole pi, just the mirror app)
                                      If so, please elaborate. Which module are you toggling? Can you share the config segment showing the change?
                                        brianlove
                                        @bkeyport
                                        I did restart the mirror. As for the modules, I’ve tried multiple ones, but specifically currentweather & CalendarWeek.
                                        	module:"MMM-Config",
                                        	position:"top_right",  // the QR code (if requested) will appear here
                                        	config:{
                                          sdetweil @brianlove
                                          @brianlove I will check when I can.
                                          could u enable debug in my module
                                          ( if using pm2, do pm2 stop all)
                                          then start with
                                          npm start > somefile.txt
                                          then do the edit and save on the form
                                          and then stop mm (ctrl-q) and send me the
                                          somefile.txt via email.
                                          same userid as here at gmail.
                                          thanks
                                            doogy_rev
                                            Hi All,
                                            I reinstalled my MM this week and decided to use this module to do the configurations. Its all installed and I can see all my modules, however it seems to be hit and miss on enabling and setting the positions. for example,
                                            default clock - this would not enable, I manually enabled it in the config and now shows Blue but can not set the position, either from the page or in the config.
                                            Default calendar - this enabled ok, shows blue, but can not set the position, does not save
                                            MMM-OpenWeatherForecast - works perfectly
                                            newsfeed - works perfectly.
                                            Any ideas on why some modules seem to be hit or miss?
                                            Sorry for the thread resurrection, was not sure where to post.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
