    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      ccr41981 @sdetweil
      @sdetweil Very well. So, how does one set this up? I installed the module, but it doesn’t show up at all. I’ve put in my ics links in the calendar spots, but nothing. I’ve gleaned that there is something to be done with custom css, but I haven’t been able to figure it out. Can someone break down what needs to be done just get a visual going?
        sdetweil @ccr41981
        @ccr41981 you’ve read the config doc?
        https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/master/docs/Configuration.md
        use the example, and your url .
        also, this module suffers from a missing library ( that was removed from the base a couple releases back )
        in the module folder (MagicMirror/modules/MMM-CalendarExt2) do
        npm install request --save
        C 2 Replies Last reply Reply Quote 1
          ccr41981 @sdetweil
          @sdetweil I DID use that example, but I did not know about the missing library. I will run that and let you know.
          Thank you for taking the time.
            ccr41981 @ccr41981
            @ccr41981 said in MMM-CalendarExt2:
            Ugh, still nothing.
            Out of curiosity, are there any resolution constraints? Or are there any problems with running this on something other than a raspberry pi? I am running MagicMirror2 on my Windows 10 machine, just to play around with the settings while I wait on my pi.
              sdetweil @ccr41981
              @ccr41981 no idea
              2 things
              1 look for messages where you start MM
              npm start
              2, open the developers window, mm screen, ctrl-shift-i, select the tab labeled ‘console’ and then put a unique part of the module name in the filter field (ext for example)
                ccr41981 @sdetweil
                @sdetweil Yikes, ok, I’ll figure out what all that means.
                I’ve only been running it in server mode, since I haven’t been able to resolve the Display error to make it run as it’s own instance. I’ll try and resolve that and do these steps.
                C S 2 Replies Last reply Reply Quote 0
                  ccr41981 @ccr41981
                  AS YOU WERE. For some unknown reason, the calendar just popped up
                    sdetweil @ccr41981
                    @ccr41981 display error
                    https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/226?_=1642092517613
                      ccr41981 @sdetweil
                      @sdetweil I’ve been through those posts about the display error, but i will go back and try to troubleshoot again.
                      However, the calendar did just pop up, so now I can go tinker with the look and set up my interface. Thanks for your help.
                        sdetweil @ccr41981
                        note that on node 16 the format of the correction has changed from prior posts
                          ccr41981 @sdetweil
                          @sdetweil Gotcha! Thanks again
                            ccr41981 @sdetweil
                            @sdetweil said in MMM-CalendarExt2:
                            Works great now! Thanks for your help
                              ccr41981 @ccr41981
                              @sdetweil One last question; would you know why CalendarExt2 doesn’t show up on the remote module? Not that I’d ever turn it off, just curious.
                                sdetweil @ccr41981
                                @ccr41981 on the remote?
                                  ccr41981 @sdetweil
                                  @sdetweil MMM-Remote-Control, that allows you to display or hide modules?
                                    sdetweil @ccr41981
                                    @ccr41981 sorry, no idea
                                      ccr41981 @sdetweil
                                      @sdetweil Ok, thanks. Just curious.
                                      • BKeyportB Offline
                                        BKeyport Module Developer @ccr41981
                                        @ccr41981 it’s likely because how CX2 generates it’s positions. In short, it’s working AROUND the built in position system and kinda builds it own.
                                        • N Offline
                                          noone
                                          after installing this modular i get the following error.
                                          pi@raspberrypi:~ $ npm run start
                                          npm ERR! code ENOENT
                                          npm ERR! syscall open
                                          npm ERR! errno -2
                                          npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                                          npm ERR! enoent This is related to npm not being able to find a file.
                                          anyone know why?
                                            sdetweil @noone
                                            @noone need to be in the MagicMirror folder
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 23 / 25
