    MMM-CalendarExt2
    486 Posts 83 Posters 943.0k Views 83 Watching
      sdetweil @ccr41981
      @ccr41981 no idea
      2 things
      1 look for messages where you start MM
      npm start
      2, open the developers window, mm screen, ctrl-shift-i, select the tab labeled ‘console’ and then put a unique part of the module name in the filter field (ext for example)
        ccr41981 @sdetweil
        @sdetweil Yikes, ok, I’ll figure out what all that means.
        I’ve only been running it in server mode, since I haven’t been able to resolve the Display error to make it run as it’s own instance. I’ll try and resolve that and do these steps.
        C S 2 Replies Last reply Reply Quote 0
          ccr41981 @ccr41981
          @ccr41981 said in MMM-CalendarExt2:
          AS YOU WERE. For some unknown reason, the calendar just popped up
            sdetweil @ccr41981
            @ccr41981 display error
            https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/226?_=1642092517613
              ccr41981 @sdetweil
              @sdetweil I’ve been through those posts about the display error, but i will go back and try to troubleshoot again.
              However, the calendar did just pop up, so now I can go tinker with the look and set up my interface. Thanks for your help.
                sdetweil @ccr41981
                note that on node 16 the format of the correction has changed from prior posts
                  ccr41981 @sdetweil
                  @sdetweil Gotcha! Thanks again
                    ccr41981 @sdetweil
                    @sdetweil said in MMM-CalendarExt2:
                    @ccr41981 you’ve read the config doc?
                    https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/master/docs/Configuration.md
                    use the example, and your url .
                    also, this module suffers from a missing library ( that was removed from the base a couple releases back )
                    in the module folder (MagicMirror/modules/MMM-CalendarExt2) do
                    npm install request --save
                    Works great now! Thanks for your help
                      ccr41981 @ccr41981
                      @sdetweil One last question; would you know why CalendarExt2 doesn’t show up on the remote module? Not that I’d ever turn it off, just curious.
                        sdetweil @ccr41981
                        @ccr41981 on the remote?
                          ccr41981 @sdetweil
                          @sdetweil MMM-Remote-Control, that allows you to display or hide modules?
                            sdetweil @ccr41981
                            @ccr41981 sorry, no idea
                              ccr41981 @sdetweil
                              @sdetweil Ok, thanks. Just curious.
                              • BKeyportB Offline
                                BKeyport Module Developer @ccr41981
                                @ccr41981 it’s likely because how CX2 generates it’s positions. In short, it’s working AROUND the built in position system and kinda builds it own.
                                • N Offline
                                  noone
                                  after installing this modular i get the following error.
                                  pi@raspberrypi:~ $ npm run start
                                  npm ERR! code ENOENT
                                  npm ERR! syscall open
                                  npm ERR! errno -2
                                  npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                                  npm ERR! enoent This is related to npm not being able to find a file.
                                  anyone know why?
                                    sdetweil @noone
                                    @noone need to be in the MagicMirror folder
                                      sdetweil @noone
                                      @noone next error
                                      • N Offline
                                        noone @sdetweil
                                        @sdetweil thx its working now
                                          MMPenguin
                                          I am having difficulties understanding how the deduplicateEventsOn works. I can get the configuration to make duplicated events not show; but how do I combine the entries under calendarName so the events show up “Bob/Jane/Sue/John” ? Or just “Everyone” ??
                                          This is what I have that removes the duplication. Its at the very top of the module. Does it need to be somewhere else?
                                          		{module: 'MMM-CalendarExt2',
                                          					rotateInterval: 45*1000,
                                          					deduplicateEventsOn:["startDate","endDate","duration","title","location"],
                                          • F Offline
                                            fedale
                                            How to get quicker update of the google calendar in Magic mirror?
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 23 / 25
