    MMM-CalendarExt2
    486 Posts 83 Posters 1.0m Views 83 Watching
      ccr41981 @sdetweil
      @sdetweil MMM-Remote-Control, that allows you to display or hide modules?
        sdetweil @ccr41981
        @ccr41981 sorry, no idea
          ccr41981 @sdetweil
          @sdetweil Ok, thanks. Just curious.
          • BKeyportB Offline
            BKeyport Module Developer @ccr41981
            @ccr41981 it’s likely because how CX2 generates it’s positions. In short, it’s working AROUND the built in position system and kinda builds it own.
            • N Offline
              noone
              after installing this modular i get the following error.
              pi@raspberrypi:~ $ npm run start
              npm ERR! code ENOENT
              npm ERR! syscall open
              npm ERR! errno -2
              npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
              npm ERR! enoent This is related to npm not being able to find a file.
              anyone know why?
                sdetweil @noone
                @noone need to be in the MagicMirror folder
                  sdetweil @noone
                  @noone next error
                  • N Offline
                    noone @sdetweil
                    @sdetweil thx its working now
                      MMPenguin
                      I am having difficulties understanding how the deduplicateEventsOn works. I can get the configuration to make duplicated events not show; but how do I combine the entries under calendarName so the events show up “Bob/Jane/Sue/John” ? Or just “Everyone” ??
                      This is what I have that removes the duplication. Its at the very top of the module. Does it need to be somewhere else?
                      		{module: 'MMM-CalendarExt2',
                      					rotateInterval: 45*1000,
                      					deduplicateEventsOn:["startDate","endDate","duration","title","location"],
                      • F Offline
                        fedale
                        How to get quicker update of the google calendar in Magic mirror?
                          sdetweil @fedale
                          @fedale u can change the updateInterval… but note that too fast might get you denied for a while…
                          • F Offline
                            fedale @sdetweil
                            @sdetweil I tried that earlier without any result. And seemed like the only thing updating was the screen flickering
                            I put it under the module config in the config.js was that the correct postion?
                              sdetweil @fedale
                              @fedale ok, in the calendar its
                              fetchInterval
                              sorry,
                              doc always wins!
                              https://docs.magicmirror.builders/modules/calendar.html#configuration-options
                              • F Offline
                                fedale @sdetweil
                                @sdetweil I tried the fetchInterval. But have not been sucessfull with that one.
                                But everytime i save my config file it update at once.
                                Is there somewhere else than in the config.js file i need to change the fetchInterval?
                                  sdetweil @fedale
                                  @fedale that is inside the config:{} section of the calendar module, yes,
                                  and NOT in the place where url: is
                                  BKeyportB F 2 Replies Last reply Reply Quote 0
                                  • BKeyportB Offline
                                    This works. URL Blanked to prevent private data.
                                    			module: "MMM-CalendarExt2", // https://github.com/MMM-CalendarExt2/MMM-CalendarExt2
                                    				calendars : [
                                    						url: "",
                                    						name: "Main", // Optional, Recommended
                                    						maxItems: 1,
                                    						scanInterval: 1000*60*.5, // every 30 seconds, Appt Book, needs this speed
                                    						beforeDays: 0,
                                    						afterDays: 2,
                                    						forceLocalTZ: false,
                                    • F Offline
                                      fedale @sdetweil
                                      • F Offline
                                        fedale @BKeyport
                                        @BKeyport This solved the problem. Thank you
                                        • F Offline
                                          fedale
                                          How can i have week numbers as an own colum?
                                          Showing the weeks separerat in its own colum?
                                          And the yellow marking accross the week for the current week?
                                          Like in this picture https://imgur.com/mwwPwEl
                                          Today i have it in the first day of the week. Due to a small screen its not showing all the calendar inputs as it takes up a row by itself. limiting the amount of events i could have
                                          • N Offline
                                            nschertz
                                            Great Module!! I started customizing a CSS file to enhance the display. I was able to do everything I wanted to do except one mod. I’m trying to make the calendar title font larger on each of 2 calendars, but can’t seem to find where this property is set. Looking for help with this.
                                            Thx Norb
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 23 / 25
