    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      ccr41981 @sdetweil
      @sdetweil Gotcha! Thanks again
        ccr41981 @sdetweil
        @sdetweil said in MMM-CalendarExt2:
        @ccr41981 you’ve read the config doc?
        https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/master/docs/Configuration.md
        use the example, and your url .
        also, this module suffers from a missing library ( that was removed from the base a couple releases back )
        in the module folder (MagicMirror/modules/MMM-CalendarExt2) do
        npm install request --save
        Works great now! Thanks for your help
          ccr41981 @ccr41981
          @ccr41981 said in MMM-CalendarExt2:
          @sdetweil One last question; would you know why CalendarExt2 doesn’t show up on the remote module? Not that I’d ever turn it off, just curious.
            sdetweil @ccr41981
            @ccr41981 on the remote?
              ccr41981 @sdetweil
              @sdetweil MMM-Remote-Control, that allows you to display or hide modules?
                sdetweil @ccr41981
                @ccr41981 sorry, no idea
                  ccr41981 @sdetweil
                  @sdetweil Ok, thanks. Just curious.
                  • BKeyportB Offline
                    BKeyport Module Developer @ccr41981
                    @ccr41981 it’s likely because how CX2 generates it’s positions. In short, it’s working AROUND the built in position system and kinda builds it own.
                    • N Offline
                      noone
                      after installing this modular i get the following error.
                      pi@raspberrypi:~ $ npm run start
                      npm ERR! code ENOENT
                      npm ERR! syscall open
                      npm ERR! errno -2
                      npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                      npm ERR! enoent This is related to npm not being able to find a file.
                      anyone know why?
                        sdetweil @noone
                        @noone need to be in the MagicMirror folder
                          sdetweil @noone
                          @noone next error
                          • N Offline
                            noone @sdetweil
                            @sdetweil thx its working now
                              MMPenguin
                              I am having difficulties understanding how the deduplicateEventsOn works. I can get the configuration to make duplicated events not show; but how do I combine the entries under calendarName so the events show up “Bob/Jane/Sue/John” ? Or just “Everyone” ??
                              This is what I have that removes the duplication. Its at the very top of the module. Does it need to be somewhere else?
                              		{module: 'MMM-CalendarExt2',
                              					rotateInterval: 45*1000,
                              					deduplicateEventsOn:["startDate","endDate","duration","title","location"],
                              • F Offline
                                fedale
                                How to get quicker update of the google calendar in Magic mirror?
                                  sdetweil @fedale
                                  @fedale u can change the updateInterval… but note that too fast might get you denied for a while…
                                  • F Offline
                                    fedale @sdetweil
                                    @sdetweil I tried that earlier without any result. And seemed like the only thing updating was the screen flickering
                                    I put it under the module config in the config.js was that the correct postion?
                                      sdetweil @fedale
                                      @fedale ok, in the calendar its
                                      fetchInterval
                                      sorry,
                                      doc always wins!
                                      https://docs.magicmirror.builders/modules/calendar.html#configuration-options
                                      • F Offline
                                        fedale @sdetweil
                                        @sdetweil I tried the fetchInterval. But have not been sucessfull with that one.
                                        But everytime i save my config file it update at once.
                                        Is there somewhere else than in the config.js file i need to change the fetchInterval?
                                          sdetweil @fedale
                                          @fedale that is inside the config:{} section of the calendar module, yes,
                                          and NOT in the place where url: is
                                          BKeyportB F 2 Replies Last reply Reply Quote 0
                                          • BKeyportB Offline
                                            This works. URL Blanked to prevent private data.
                                            			module: "MMM-CalendarExt2", // https://github.com/MMM-CalendarExt2/MMM-CalendarExt2
                                            				calendars : [
                                            						url: "",
                                            						name: "Main", // Optional, Recommended
                                            						maxItems: 1,
                                            						scanInterval: 1000*60*.5, // every 30 seconds, Appt Book, needs this speed
                                            						beforeDays: 0,
                                            						afterDays: 2,
                                            						forceLocalTZ: false,
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 23 / 25
