    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      ccr41981 @ccr41981
      @ccr41981 said in MMM-CalendarExt2:
      @sdetweil One last question; would you know why CalendarExt2 doesn’t show up on the remote module? Not that I’d ever turn it off, just curious.
        sdetweil @ccr41981
        @ccr41981 on the remote?
          ccr41981 @sdetweil
          @sdetweil MMM-Remote-Control, that allows you to display or hide modules?
            sdetweil @ccr41981
            @ccr41981 sorry, no idea
              ccr41981 @sdetweil
              @sdetweil Ok, thanks. Just curious.
              • BKeyportB Offline
                BKeyport Module Developer @ccr41981
                @ccr41981 it’s likely because how CX2 generates it’s positions. In short, it’s working AROUND the built in position system and kinda builds it own.
                • N Offline
                  noone
                  after installing this modular i get the following error.
                  pi@raspberrypi:~ $ npm run start
                  npm ERR! code ENOENT
                  npm ERR! syscall open
                  npm ERR! errno -2
                  npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                  npm ERR! enoent This is related to npm not being able to find a file.
                  anyone know why?
                    sdetweil @noone
                    @noone need to be in the MagicMirror folder
                      sdetweil @noone
                      @noone next error
                      • N Offline
                        noone @sdetweil
                        @sdetweil thx its working now
                          MMPenguin
                          I am having difficulties understanding how the deduplicateEventsOn works. I can get the configuration to make duplicated events not show; but how do I combine the entries under calendarName so the events show up “Bob/Jane/Sue/John” ? Or just “Everyone” ??
                          This is what I have that removes the duplication. Its at the very top of the module. Does it need to be somewhere else?
                          		{module: 'MMM-CalendarExt2',
                          					rotateInterval: 45*1000,
                          					deduplicateEventsOn:["startDate","endDate","duration","title","location"],
                          • F Offline
                            fedale
                            How to get quicker update of the google calendar in Magic mirror?
                              sdetweil @fedale
                              @fedale u can change the updateInterval… but note that too fast might get you denied for a while…
                              • F Offline
                                fedale @sdetweil
                                @sdetweil I tried that earlier without any result. And seemed like the only thing updating was the screen flickering
                                I put it under the module config in the config.js was that the correct postion?
                                  sdetweil @fedale
                                  @fedale ok, in the calendar its
                                  fetchInterval
                                  sorry,
                                  doc always wins!
                                  https://docs.magicmirror.builders/modules/calendar.html#configuration-options
                                  • F Offline
                                    fedale @sdetweil
                                    @sdetweil I tried the fetchInterval. But have not been sucessfull with that one.
                                    But everytime i save my config file it update at once.
                                    Is there somewhere else than in the config.js file i need to change the fetchInterval?
                                      sdetweil @fedale
                                      @fedale that is inside the config:{} section of the calendar module, yes,
                                      and NOT in the place where url: is
                                      BKeyportB F 2 Replies Last reply Reply Quote 0
                                      • BKeyportB Offline
                                        This works. URL Blanked to prevent private data.
                                        			module: "MMM-CalendarExt2", // https://github.com/MMM-CalendarExt2/MMM-CalendarExt2
                                        				calendars : [
                                        						url: "",
                                        						name: "Main", // Optional, Recommended
                                        						maxItems: 1,
                                        						scanInterval: 1000*60*.5, // every 30 seconds, Appt Book, needs this speed
                                        						beforeDays: 0,
                                        						afterDays: 2,
                                        						forceLocalTZ: false,
                                        • F Offline
                                          fedale @sdetweil
                                          • F Offline
                                            fedale @BKeyport
                                            @BKeyport This solved the problem. Thank you
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 23 / 25
