    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      sdetweil @ccr41981
      @ccr41981 on the remote?
        ccr41981 @sdetweil
        @sdetweil MMM-Remote-Control, that allows you to display or hide modules?
          sdetweil @ccr41981
          @ccr41981 sorry, no idea
            ccr41981 @sdetweil
            @sdetweil Ok, thanks. Just curious.
            • BKeyportB
              BKeyport Module Developer @ccr41981
              @ccr41981 it’s likely because how CX2 generates it’s positions. In short, it’s working AROUND the built in position system and kinda builds it own.
              • N
                noone
                after installing this modular i get the following error.
                pi@raspberrypi:~ $ npm run start
                npm ERR! code ENOENT
                npm ERR! syscall open
                npm ERR! errno -2
                npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                npm ERR! enoent This is related to npm not being able to find a file.
                anyone know why?
                  sdetweil @noone
                  @noone need to be in the MagicMirror folder
                    sdetweil @noone
                    @noone next error
                    • N
                      noone @sdetweil
                      @sdetweil thx its working now
                        MMPenguin
                        I am having difficulties understanding how the deduplicateEventsOn works. I can get the configuration to make duplicated events not show; but how do I combine the entries under calendarName so the events show up “Bob/Jane/Sue/John” ? Or just “Everyone” ??
                        This is what I have that removes the duplication. Its at the very top of the module. Does it need to be somewhere else?
                        		{module: 'MMM-CalendarExt2',
                        					rotateInterval: 45*1000,
                        					deduplicateEventsOn:["startDate","endDate","duration","title","location"],
                        • F
                          fedale
                          How to get quicker update of the google calendar in Magic mirror?
                            sdetweil @fedale
                            @fedale u can change the updateInterval… but note that too fast might get you denied for a while…
                            • F
                              fedale @sdetweil
                              @sdetweil I tried that earlier without any result. And seemed like the only thing updating was the screen flickering
                              I put it under the module config in the config.js was that the correct postion?
                                sdetweil @fedale
                                @fedale ok, in the calendar its
                                fetchInterval
                                sorry,
                                doc always wins!
                                https://docs.magicmirror.builders/modules/calendar.html#configuration-options
                                • F
                                  fedale @sdetweil
                                  @sdetweil I tried the fetchInterval. But have not been sucessfull with that one.
                                  But everytime i save my config file it update at once.
                                  Is there somewhere else than in the config.js file i need to change the fetchInterval?
                                    sdetweil @fedale
                                    @fedale that is inside the config:{} section of the calendar module, yes,
                                    and NOT in the place where url: is
                                    BKeyportB F 2 Replies Last reply Reply Quote 0
                                    • BKeyportB
                                      This works. URL Blanked to prevent private data.
                                      			module: "MMM-CalendarExt2", // https://github.com/MMM-CalendarExt2/MMM-CalendarExt2
                                      				calendars : [
                                      						url: "",
                                      						name: "Main", // Optional, Recommended
                                      						maxItems: 1,
                                      						scanInterval: 1000*60*.5, // every 30 seconds, Appt Book, needs this speed
                                      						beforeDays: 0,
                                      						afterDays: 2,
                                      						forceLocalTZ: false,
                                      • F
                                        fedale @sdetweil
                                        • F
                                          fedale @BKeyport
                                          @BKeyport This solved the problem. Thank you
                                          • F
                                            fedale
                                            How can i have week numbers as an own colum?
                                            Showing the weeks separerat in its own colum?
                                            And the yellow marking accross the week for the current week?
                                            Like in this picture https://imgur.com/mwwPwEl
                                            Today i have it in the first day of the week. Due to a small screen its not showing all the calendar inputs as it takes up a row by itself. limiting the amount of events i could have
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 23 / 25
