    Releasing stable
    Scheduled Pinned Locked Moved Core System
    22 Posts 6 Posters 21.3k Views 5 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      Besides the Facebook issues, with else is wrong with the Calendar module?
      • MichMichM Offline
        MichMich
        It appears some feeds cant be loaded. But I can’t reproduce it. https://github.com/MichMich/MagicMirror/issues/221
        KirAsh4K Wilco89W 2 Replies Last reply Reply Quote 0
        • MichMichM Offline
          MichMich
          We also need to fix the installer (so we don’t need to manually set the latest node version) and the translation system.
          • KirAsh4K Offline
            KirAsh4 Moderator @MichMich
            @MichMich, unfortunately I can’t reproduce that. I’m using my own private Google calendar and it loads just fine.
            MichMichM 1 Reply Last reply Reply Quote 1
            • MichMichM Offline
              MichMich @KirAsh4
              @KirAsh4 same here. It might have something to do with a module not working on a Pi B+ (like Curl)
              • KirAsh4K Offline
                KirAsh4 Moderator
                Hrm, I have one of those but it’s currently in service for something else. Rats. Should probably get another one anyway (and another rPi-3 as well.) But, that makes me wonder if it’s simply software that needs updating …
                • KirAsh4K Offline
                  KirAsh4 Moderator
                  Ugh … I should be beaten with a stick. I knew I forgot something. I ordered another rPi-3 yesterday and completely forgot to add an rPi-2 to the order to use as dev/test platform. But, I did order more HDMI cables and uSD cards … just forgot the rPi itself. Oh well … another shipping charge. I’ll get it eventually …
                  • KirAsh4K Offline
                    KirAsh4 Moderator
                    Hey @MichMich, you’re certain it’s the rPi B+ (512Mb) that has the curl issue, not the rPi-2 B (1Gb)? Perhaps this is one of those times where telling folks to upgrade their hardware is a better/easier solution considering a) how cheap they are, and b) hardware-wise, we’re several iterations ahead already. There’s a point where supporting older hardware (running older and unsupported base software) just becomes a pain.
                    • MichMichM Offline
                      MichMich
                      Agree. I don’t make any modifications for older pies.
                      • Wilco89W Offline
                        Wilco89 @MichMich
                        @MichMich I do have the same issue on my RP 3 , all calenders are working only my private google calender doesn’t
