    Releasing stable
    Scheduled Pinned Locked Moved Core System
    22 Posts 6 Posters 22.7k Views 5 Watching
    • MichMichM Offline
      MichMich
      Since MagicMirror² is currently only available as a beta, and the ‘old’ version is still the master branch, I was wondering what you guys think should be the point to release v2 as the master branch?
      • paviroP Offline
        paviro
        Maybe once all the open calendar issues are closed? :smile:
        – The Doctor
        • MichMichM Offline
          MichMich
          👿😂 - Boy, do I hate that module … ;)
          • paviroP Offline
            paviro
            You have my deepest sympathies 😅
            – The Doctor
            • KirAsh4K Offline
              KirAsh4 Moderator
              Besides the Facebook issues, with else is wrong with the Calendar module?
              • MichMichM Offline
                MichMich
                It appears some feeds cant be loaded. But I can’t reproduce it. https://github.com/MichMich/MagicMirror/issues/221
                KirAsh4K Wilco89W 2 Replies Last reply Reply Quote 0
                • MichMichM Offline
                  MichMich
                  We also need to fix the installer (so we don’t need to manually set the latest node version) and the translation system.
                  • KirAsh4K Offline
                    KirAsh4 Moderator @MichMich
                    @MichMich, unfortunately I can’t reproduce that. I’m using my own private Google calendar and it loads just fine.
                    MichMichM 1 Reply Last reply Reply Quote 1
                    • MichMichM Offline
                      MichMich @KirAsh4
                      @KirAsh4 same here. It might have something to do with a module not working on a Pi B+ (like Curl)
                      • KirAsh4K Offline
                        KirAsh4 Moderator
                        Hrm, I have one of those but it’s currently in service for something else. Rats. Should probably get another one anyway (and another rPi-3 as well.) But, that makes me wonder if it’s simply software that needs updating …
                        • KirAsh4K Offline
                          KirAsh4 Moderator
                          Ugh … I should be beaten with a stick. I knew I forgot something. I ordered another rPi-3 yesterday and completely forgot to add an rPi-2 to the order to use as dev/test platform. But, I did order more HDMI cables and uSD cards … just forgot the rPi itself. Oh well … another shipping charge. I’ll get it eventually …
                          • KirAsh4K Offline
                            KirAsh4 Moderator
                            Hey @MichMich, you’re certain it’s the rPi B+ (512Mb) that has the curl issue, not the rPi-2 B (1Gb)? Perhaps this is one of those times where telling folks to upgrade their hardware is a better/easier solution considering a) how cheap they are, and b) hardware-wise, we’re several iterations ahead already. There’s a point where supporting older hardware (running older and unsupported base software) just becomes a pain.
                            • MichMichM Offline
                              MichMich
                              Agree. I don’t make any modifications for older pies.
                              • Wilco89W Offline
                                Wilco89 @MichMich
                                @MichMich I do have the same issue on my RP 3 , all calenders are working only my private google calender doesn’t
                                • KirAsh4K Offline
                                  KirAsh4 Moderator
                                  Hey @Wilco89, can you try creating a secondary private calendar, and importing that, see if it works? If it too fails, can you share that second URL with me so I can try to debug it?
                                  • MichMichM Offline
                                    MichMich
                                    Most issues seem to be solved, and the translation system is completed. I’m waiting for some feedback on the “wonky” time overflow, and might then move beta to stable.
                                    What do you guys suggest to be the best approach? Shall we keep a beta repository as well?
                                    • Wilco89W Offline
                                      Wilco89
                                      I think it is pretty stable, and think that future improvements should be worked out in a beta version.
                                      • KirAsh4K Offline
                                        KirAsh4 Moderator
                                        We could release v2 (stable), keep v2-beta to continue developing on that release. Or, start a new branch (v2-StuffWeThoughtWorkedButReallyDoesnt)… Or just start with v2.1, v2.2 etc., etc. At least till there’s another major update, or we’ve mucked with it so much that it’s not really a base v2 anymore…
                                        • MichMichM Offline
                                          MichMich
                                          Yeah, probably gonna move current master to 1.0, move v2-beta to master, and create a develop branch. Agree?
                                          Wilco89W 1 Reply Last reply Reply Quote 1
                                          • KirAsh4K Offline
                                            KirAsh4 Moderator
                                            Yep, that sounds like a plan.
