    Releasing stable
    Scheduled Pinned Locked Moved Core System
    22 Posts 6 Posters 27.9k Views 5 Watching
    • MichMichM Offline
      MichMich
      It appears some feeds cant be loaded. But I can’t reproduce it. https://github.com/MichMich/MagicMirror/issues/221
      K W 2 Replies Last reply Reply Quote 0
      • MichMichM Offline
        MichMich
        We also need to fix the installer (so we don’t need to manually set the latest node version) and the translation system.
        • K Offline
          KirAsh4 Moderator @MichMich
          @MichMich, unfortunately I can’t reproduce that. I’m using my own private Google calendar and it loads just fine.
          MichMichM 1 Reply Last reply Reply Quote 1
          • MichMichM Offline
            MichMich @KirAsh4
            @KirAsh4 same here. It might have something to do with a module not working on a Pi B+ (like Curl)
            • K Offline
              KirAsh4 Moderator
              Hrm, I have one of those but it’s currently in service for something else. Rats. Should probably get another one anyway (and another rPi-3 as well.) But, that makes me wonder if it’s simply software that needs updating …
              • K Offline
                KirAsh4 Moderator
                Ugh … I should be beaten with a stick. I knew I forgot something. I ordered another rPi-3 yesterday and completely forgot to add an rPi-2 to the order to use as dev/test platform. But, I did order more HDMI cables and uSD cards … just forgot the rPi itself. Oh well … another shipping charge. I’ll get it eventually …
                • K Offline
                  KirAsh4 Moderator
                  Hey @MichMich, you’re certain it’s the rPi B+ (512Mb) that has the curl issue, not the rPi-2 B (1Gb)? Perhaps this is one of those times where telling folks to upgrade their hardware is a better/easier solution considering a) how cheap they are, and b) hardware-wise, we’re several iterations ahead already. There’s a point where supporting older hardware (running older and unsupported base software) just becomes a pain.
                  • MichMichM Offline
                    MichMich
                    Agree. I don’t make any modifications for older pies.
                    • W Offline
                      Wilco89 @MichMich
                      @MichMich I do have the same issue on my RP 3 , all calenders are working only my private google calender doesn’t
                      • K Offline
                        KirAsh4 Moderator
                        Hey @Wilco89, can you try creating a secondary private calendar, and importing that, see if it works? If it too fails, can you share that second URL with me so I can try to debug it?
                        • MichMichM Offline
                          MichMich
                          Most issues seem to be solved, and the translation system is completed. I’m waiting for some feedback on the “wonky” time overflow, and might then move beta to stable.
                          What do you guys suggest to be the best approach? Shall we keep a beta repository as well?
                          • W Offline
                            Wilco89
                            I think it is pretty stable, and think that future improvements should be worked out in a beta version.
                            • K Offline
                              KirAsh4 Moderator
                              We could release v2 (stable), keep v2-beta to continue developing on that release. Or, start a new branch (v2-StuffWeThoughtWorkedButReallyDoesnt)… Or just start with v2.1, v2.2 etc., etc. At least till there’s another major update, or we’ve mucked with it so much that it’s not really a base v2 anymore…
                              • MichMichM Offline
                                MichMich
                                Yeah, probably gonna move current master to 1.0, move v2-beta to master, and create a develop branch. Agree?
                                W 1 Reply Last reply Reply Quote 1
                                • K Offline
                                  KirAsh4 Moderator
                                  Yep, that sounds like a plan.
                                  • W Offline
                                    Wilco89 @MichMich
                                    @MichMich Sounds good!
                                    • MichMichM Offline
                                      MichMich
                                      V2.0.0 is now released: https://forum.magicmirror.builders/topic/76/magicmirror-released
