    MMM-SoccerLiveScore
    187 Posts 37 Posters 339.5k Views 35 Watching
    • N
      np27np27 @0m4r
      Hi @0m4r,
      It seems to be stuck again for me. I think its happening on the last game on a game week there are multiple days. See screenshot attached taken today on the 28th.
      0m4r0 2 Replies Last reply
      • 0m4r0
        0m4r Module Developer @np27np27
        @np27np27 thanks for the hint - I will be looking into it.
        https://github.com/0m4r
        • 0m4r0
          @np27np27 I put in a fix, not sure it works 100% :P
          I have noticed tho, my approach is not really the best, will need to re-think it and re-implement it. I’d like to reach a point where the API calls are done only if and when needed to reduce network traffic and avoid overloading the API service provider too.
          N 2 Replies Last reply
          • N
            np27np27 @0m4r
            @0m4r
            OK thanks. Do I update it as you have mentioned before? Or a full reinstall?
            • N
              np27np27 @0m4r
              @0m4r
              Also, how do I find new league ID numbers. African nations Cup?
              0m4r0 1 Reply Last reply
              • 0m4r0
                @np27np27 you can switch back to the master branch and do a git pull.
                It does not look like the Africa nation cup is supported by the APIs :(
                N 1 Reply Last reply
                • N
                  np27np27 @0m4r
                  Hi @0m4r,
                  Sorry to report but I’m still seeing the same issue. 😔
                  It’s definitely not updating after the last game of the week starts. Same was seen in this round of premier league games, image attached.
                  click here for image
                  • 0m4r0
                    @np27np27 ok :( thanks for the info. I’ll be taking another look.
                    I think as a workaround you can probably try to refresh the mirror, but I understand it is not the desired behavior…
                    • N
                      np27np27 @0m4r
                      @0m4r said in MMM-SoccerLiveScore:
                      Yes that is what I’ve been doing. Hopefully you will have time to take another look at the module and code soon. Thanks for the help 👍🏾
                      • 0m4r0
                        @np27np27 hey, I have just realized I mistakenly pushed the code with some hardcoded test values. Those might be the reason for the wrong behavior.
                        Can you try pulling the code again and let me know?
                        • N
                          np27np27
                          @0m4r
                          Sorry for the long delay!
                          I’ve tried git pull and it says I already have the latest version… 3.1.5?
                          • 0m4r0
                            @np27np27 do you mean you can still see the issue with that version? :(
                            If so, most likely it is not resolved. I will need to find some time to look into it again
                            • N
                              np27np27 @0m4r
                              @0m4r, yes still have the issue. Last game day of the week does not refresh and then the whole week fails to refresh and provide the new fixtures after that.
                              Currently I am restarting MM each time we get to the end of a game week to refresh.
                              • 0m4r0
                                if you are interested into the WM results, add 4100 as a code into the module configuration :D
                                E 1 Reply Last reply
                                • E
                                  Egnos @0m4r
                                  Hi there,
                                  I’ve installed this module and it is very beautiful and useful, thanks @0m4r!
                                  Question: I’ve enabled in configuration the Scores & Details about Serie A. My mirror is quite big and all the matches are visible but I don’t know why starts the “auto-scroling”.
                                  I do not think that there is a config field for disable “auto-scroling”.
                                  Its possibile to remove somehow the auto scrolling (a little hack in the code…)?
                                  Thanks guys!
                                  • 0m4r0
                                    0m4r Module Developer @Egnos
                                    @Egnos this is now done.
                                    Please add “scrollVertical: false” into your config for the module.
                                    (of course, updated it first!)
                                    Let me know if it works!
                                    • E
                                      Egnos @0m4r
                                      Thanks @0m4r, seems works!
                                      Sorry for the late reply!
                                      • E
                                        Egnos
                                        Hi all,
                                        i have these errors refer to the “MMM-SoccerLiveScore” module in “MagicMirror-error.log” file:
                                        [27.09.2023 18:40.07.575] [ERROR] MMM-SoccerLiveScore doPost URL {
                                          href: 'https://toralarm.com/api/api/competitions/23/matches/30580909/details',
                                          origin: 'https://toralarm.com',
                                          protocol: 'https:',
                                          username: '',
                                          password: '',
                                          host: 'toralarm.com',
                                          hostname: 'toralarm.com',
                                          port: '',
                                          pathname: '/api/api/competitions/23/matches/30580909/details',
                                          search: '',
                                          searchParams: URLSearchParams {},
                                          hash: ''
                                          method: 'POST',
                                          gzip: true,
                                          headers: {
                                            Host: 'toralarm.com',
                                            'accept-language': 'en-US,en;q=0.9,it;q=0.8,de-DE;q=0.7,de;q=0.6',
                                            'content-type': 'application/json;charset=UTF-8'
                                          body: '{"lng":"it"}'
                                        } Response {
                                          timeout: 0,
                                          [Symbol(Body internals)]: {
                                            body: Gunzip {
                                              _writeState: [Uint32Array],
                                              _readableState: [ReadableState],
                                              _events: [Object: null prototype],
                                              _eventsCount: 5,
                                              _maxListeners: undefined,
                                              _writableState: [WritableState],
                                              allowHalfOpen: true,
                                              bytesWritten: 0,
                                              _handle: [Zlib],
                                              _outBuffer: <Buffer 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ... 16334 more bytes>,
                                              _outOffset: 0,
                                              _chunkSize: 16384,
                                              _defaultFlushFlag: 2,
                                              _finishFlushFlag: 2,
                                              _defaultFullFlushFlag: 3,
                                              _info: undefined,
                                              _maxOutputLength: 1073741823,
                                              _level: -1,
                                              _strategy: 0,
                                              [Symbol(kCapture)]: false,
                                              [Symbol(kCallback)]: null,
                                              [Symbol(kError)]: null
                                            disturbed: false,
                                            error: null
                                          [Symbol(Response internals)]: {
                                            url: 'https://toralarm.com/api/api/competitions/23/matches/30580909/details',
                                            status: 500,
                                            statusText: 'Internal Server Error',
                                            headers: Headers { [Symbol(map)]: [Object: null prototype] },
                                            counter: 0
                                        [27.09.2023 18:40.07.577] [ERROR] MMM-SoccerLiveScore getDetails 23 https://toralarm.com/api/api/competitions/23/matches/30580909/details null
                                        [27.09.2023 18:40.07.592] [ERROR] (node:12212) UnhandledPromiseRejectionWarning: TypeError: Cannot read properties of undefined (reading 'filter')
                                            at forLoop (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:237:54)
                                            at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
                                        (Use `electron --trace-warnings ...` to show where the warning was created)
                                        This is my sw configuration:
                                        S.O.: Buster
                                        MM: v2.23.0
                                        RPI4 4gb
                                        Is it possible to solve it?
                                        Thanks.
                                        • 0m4r0
                                          Hi @Egnos, I am not able to replicate it.
                                          I can see from the logs it is a server error (500, Internal Server Error).
                                          This has something to do with the server that provides the data to display.
                                          Anyway, can show me your config for the module?
                                          And, have you tried to pull the latest version?
                                          Thanks - Omar
                                          • E
                                            Egnos @0m4r
                                            Hi @0m4r, this is my RPI configuration:
                                            • S.O.: Buster
                                            • MM: v2.23.0 (the 2.24.0 version it gives me some problems…)
                                            • RPI4 4gb
                                            Below my module’s configuration:
                                            		  module: 'MMM-SoccerLiveScore',
                                            		  position: 'top_right',
                                            		  //header: 'Live-Scores',
                                            			leagues: [23],
                                            			showNames: true,
                                            			showLogos: true,
                                            			displayTime: 60 * 1000,
                                            			showStandings: true,
                                            			showTables: false,
                                            			showDetails: true,
                                            			showScorers: false,
                                            			scrollVertical: false,
                                            			language: 'it', // supported values are en, de, it
                                            Thanks for your help!
                                            • 10
                                            • 9 / 10
