    MMM-SoccerLiveScore
    187 Posts 37 Posters 339.2k Views 35 Watching
    • N
      np27np27 @np27np27
      @0m4r ,the api call date changes on the module but the data is stuck and not updating.
      0m4r0 2 Replies Last reply
      • 0m4r0
        0m4r Module Developer @np27np27
        @np27np27 I’ll check that :(
        https://github.com/0m4r
        • 0m4r0
          @np27np27 I am checking right now the results for “Serie A” and they seem to update…
          N 1 Reply Last reply
          • N
            np27np27 @0m4r
            @0m4r
            Hey, yes just looking at the premier league scores today and it all seems to be updating OK so far. Not sure what was going on last time. Maybe it is OK then?
            0m4r0 1 Reply Last reply
            • 0m4r0
              @np27np27 well, I hope so!
              Let’s keep an eye on it and see if it really works or if it is just a feeling we have!
              Thanks for the feedback!
              • N
                np27np27 @0m4r
                Hi @0m4r,
                It seems to be stuck again for me. I think its happening on the last game on a game week there are multiple days. See screenshot attached taken today on the 28th.
                • 0m4r0
                  @np27np27 thanks for the hint - I will be looking into it.
                  • 0m4r0
                    @np27np27 I put in a fix, not sure it works 100% :P
                    I have noticed tho, my approach is not really the best, will need to re-think it and re-implement it. I’d like to reach a point where the API calls are done only if and when needed to reduce network traffic and avoid overloading the API service provider too.
                    N 2 Replies Last reply
                    • N
                      np27np27 @0m4r
                      @0m4r
                      OK thanks. Do I update it as you have mentioned before? Or a full reinstall?
                      • N
                        np27np27 @0m4r
                        @0m4r
                        Also, how do I find new league ID numbers. African nations Cup?
                        • 0m4r0
                          @np27np27 you can switch back to the master branch and do a git pull.
                          It does not look like the Africa nation cup is supported by the APIs :(
                          • N
                            np27np27 @0m4r
                            Hi @0m4r,
                            Sorry to report but I’m still seeing the same issue. 😔
                            It’s definitely not updating after the last game of the week starts. Same was seen in this round of premier league games, image attached.
                            click here for image
                            • 0m4r0
                              @np27np27 ok :( thanks for the info. I’ll be taking another look.
                              I think as a workaround you can probably try to refresh the mirror, but I understand it is not the desired behavior…
                              • N
                                np27np27 @0m4r
                                @0m4r said in MMM-SoccerLiveScore:
                                Yes that is what I’ve been doing. Hopefully you will have time to take another look at the module and code soon. Thanks for the help 👍🏾
                                • 0m4r0
                                  @np27np27 hey, I have just realized I mistakenly pushed the code with some hardcoded test values. Those might be the reason for the wrong behavior.
                                  Can you try pulling the code again and let me know?
                                  • N
                                    np27np27
                                    @0m4r
                                    Sorry for the long delay!
                                    I’ve tried git pull and it says I already have the latest version… 3.1.5?
                                    • 0m4r0
                                      @np27np27 do you mean you can still see the issue with that version? :(
                                      If so, most likely it is not resolved. I will need to find some time to look into it again
                                      • N
                                        np27np27 @0m4r
                                        @0m4r, yes still have the issue. Last game day of the week does not refresh and then the whole week fails to refresh and provide the new fixtures after that.
                                        Currently I am restarting MM each time we get to the end of a game week to refresh.
                                        • 0m4r0
                                          if you are interested into the WM results, add 4100 as a code into the module configuration :D
                                          E 1 Reply Last reply
                                          • E
                                            Egnos @0m4r
                                            Hi there,
                                            I’ve installed this module and it is very beautiful and useful, thanks @0m4r!
                                            Question: I’ve enabled in configuration the Scores & Details about Serie A. My mirror is quite big and all the matches are visible but I don’t know why starts the “auto-scroling”.
                                            I do not think that there is a config field for disable “auto-scroling”.
                                            Its possibile to remove somehow the auto scrolling (a little hack in the code…)?
                                            Thanks guys!
                                            • 10
                                            • 9 / 10
