    question about MMM-MarineWeather module
    4 Posts 3 Posters 831 Views 2 Watching
      r3d6
      I’m very new to this so please bear with me.
      I have successfully added the above module to Magic Mirror and it’s working! However, I want to change units from Celsius to Fahrenheit. The module’s readme file says I can do this by coding config.units = imperial. I’m not exactly sure how to actually put this into the config.js file though.
      I tried typing it out right after the last line of code, which was apid: XXXX and ended up crashing mm. little help?
        A Former User
        • strawberry 3.141S
          @r3d6 you have two options.
          Either you change it globally for your mirror here (recommended, because it also controls the units for other modules):
          Or only for this module specifically:
          R 1 Reply Last reply
            r3d6 @strawberry 3.141
            @strawberry-3-141 Thank you. I changed it globally. This was very helpful. What did you mean by start a github?
