    Rookie just starting with magic mirror
    11 Posts 3 Posters 3.8k Views 3 Watching
    • F
      frode
      Hello good people.
      From Norway, just starting with this magicmirror. Just this minute I’m “destroying” a old pc screen. Just for now I’m wondering if its possible to choose my own news feed? I want news from Norway and english premier league, goals and so on.
      My project is not going to be a mirror but a built in screen in my wall… Black screen when not used
        sdetweil @frode
        @frode yes, if there is a feed that provides the data you want, just yse that URL instead of (or in addition to) any other
        • F
          frode
          Hi again
          Working with this some days now :) I like it! But the neverending question it seems : I’m trying to remote control this unit.
          I’ve installed by : bash -c “$(curl -s https://raw.githubusercontent.com/Jopyth/MMM-Remote-Control/master/installer.sh)” without * of course and that went ok, but when I try to add this
          module: ‘MMM-Remote-Control’
          // uncomment the following line to show the URL of the remote control on the mirror
          // , position: ‘bottom_left’
          // you can hide this module afterwards from the remote control itself
          customCommand: {}, // Optional, See “Using Custom Commands” below
          customMenu: “custom_menu.json”, // Optional, See “Custom Menu Items” below
          showModuleApiMenu: true, // Optional, Enable the Module Controls menu
          apiKey: “”, // Optional, See API/README.md for details
          its error anywhere I try to insert it to modules? I have put it between { (at the start of code) and }, in the end.
          But where ever I try to insert it, it goes to error? What am I doing wrong :)
            sdetweil @frode
            @frode what is the error?
            In config?
            Do
             npm run check:config
            from the mm folder
            • F
              frode
              Dont remember exactly, its a basic page saying something about missing config or error in config… I deleted something that I shouldnt do, so now its all black… :)
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @frode
                @frode
                The example config entry in the readme has a couple of errors. This should work for you.
                    module: 'MMM-Remote-Control',
                    position: 'bottom_left',
                        customCommand: {},
                        customMenu: "custom_menu.json",
                        apiKey: "",
                F 1 Reply Last reply Reply Quote 1
                • F
                  frode @Mykle1
                  @Mykle1 your my hero :)
                  That was amazing :) thank you so much, maybe its time to edit the readme :)
                  • Mykle1M
                    @frode
                    It’s not MY readme. :-)
                    • F
                      frode
                      No, I meant for the person who made it :)
                      • Mykle1M
                        @frode
                        Understood. I’ll leave a message for the author.
                        • Mykle1M
                          It appears the issue has already been raised at the repo. :thumbsup:
