    MMM-HomeKit | Control your MagicMirror with Apple HomeKit
    27 Posts 17 Posters 23.0k Views 20 Watching
      Baassievalk
      This post is deleted!
        Baassievalk
        Hi!
        I need a little help setting it up…
        When turning on the mirror in the HomeKit App I get the following log:
        [2020-3-29 22:26:16] [Raspberry Pi] Mirror is off.
        [2020-3-29 22:26:17] [Raspberry Pi] Failed to turn on Mirror
        Als het goed is hebt u de gebruikelijke informatie ontvangen van uw
        systeembeheerder. Gewoonlijk komt het neer op de volgende drie punten:
            1. Respecteer de privacy van anderen.
            2. Denk na voordat u iets doet.
            3. Veel mogelijkheden betekent veel verantwoordelijkheid.
        sudo: geen terminal aanwezig en geen wachtwoordvraag(askpass)-programma opgegeven
        Translated
        "Als het goed is hebt u de gebruikelijke informatie ontvangen van uw
            3. Veel mogelijkheden betekent veel verantwoordelijkheid." This is a little talk about privacy but then:
        sudo: no terminal available and no  passwordask(askpass) programs gave up.
        If anyone knows a solution, would be appreciated!
        • N Offline
          NorthernMan54 @Baassievalk
          @Baassievalk
          After much googling, the answer is here:
          https://stackoverflow.com/questions/21659637/how-to-fix-sudo-no-tty-present-and-no-askpass-program-specified-error
          and in particular this comment
          username ALL = NOPASSWD: /fullpath/to/command, /fullpath/to/othercommand
          In my setup I created a file called /etc/sudoers.d/010_cmdswitch2
          And the file contains
          homebrid ALL = NOPASSWD: /bin/chvt
          chvt is the command I need to run, and homebrid is the account I use to run my homebridge with
            a0ies
              amaralia @Caimin
              @Caimin Bonjour a toi
              Would it be possible for you to give me a hand,
              I have homebridge on one raspberry and magic mirror on another.
              i am using hdmi on the magic mirror.
              I can’t understand why I have this error on the image
              Yours
              j’ai cette configuration
                  "platform": "cmdSwitch2",
                  "name": "Ecran Mirroir",
                  "switches": [
                          "name": "magicmirror",
                          "on_cmd": "curl -s 'http://192.168.1.2:8080/remote?action=MONITORON'",
                          "off_cmd": "curl -s 'http://192.168.1.2:8080/remote?action=MONITOROFF'",
                          "state_cmd": "sshpass -p 'Armagedon13' ssh -oStrictHostKeyChecking=no pi@192.168.1.2 vcgencmd display_power | grep -q 'HDMI DMT && echo '1'",
                          "polling": true,
                          "interval": 10,
                          "manufacturer": "Raspberry Pi Foundation",
                          "model": "Raspberry Pi 3 Model B"
                sdetweil @amaralia
                @amaralia said in MMM-HomeKit | Control your MagicMirror with Apple HomeKit:
                grep -q 'HDMI DMT && echo ‘1’
                seems u are missing a single quote (before the && )
                  banbutcher
                  Just installed homekit and its great… i can now have the mirror switch off when i say goodnight using shortcuts, i also have it set to turn off when im not there and switch on when i get home!
                  next step is to get it to switch on my playstation on voice! :)
                  • F Offline
                    fragler
                    Hello,
                    I am trying to setup a Mirror and make it work with homekit. I’m very unexperienced with coding and basically everything here :)
                    I followed the instructions and get the following error.
                    I would appreciate your help a lot!
                    Thank you in advance:
                    [11.12.2020, 17:48:04] Loading 2 platforms…
                    [11.12.2020, 17:48:04] [Config] Initializing config platform…
                    [11.12.2020, 17:48:04] [Config] Running in Service Mode
                    [11.12.2020, 17:48:04] [Raspberry Pi] Initializing cmdSwitch2 platform…
                    [11.12.2020, 17:48:04] Error: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 74adc578-9ce9-42de-bbbb-5e3d84a287a1
                    at Bridge.Accessory._this.addBridgedAccessory (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/src/lib/Accessory.ts:416:15)
                    at /usr/lib/node_modules/homebridge/src/server.ts:310:19
                    at Array.filter ()
                    at Server.restoreCachedPlatformAccessories (/usr/lib/node_modules/homebridge/src/server.ts:270:69)
                    at Server.start (/usr/lib/node_modules/homebridge/src/server.ts:158:10)
                    at cli (/usr/lib/node_modules/homebridge/src/cli.ts:80:10)
                    at Object. (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
                    at Module._compile (internal/modules/cjs/loader.js:1063:30)
                    at Object.Module._extensions…js (internal/modules/cjs/loader.js:1092:10)
                    at Module.load (internal/modules/cjs/loader.js:928:32)
                    S BKeyportB 2 Replies Last reply Reply Quote 0
                      sdetweil @fragler
                      @fragler said in MMM-HomeKit | Control your MagicMirror with Apple HomeKit:
                      • BKeyportB Offline
                        BKeyport Module Developer @fragler
                        @fragler
                        FYI, this non-module is a piece of abandonware.
                        Looks like you’ve got two devices using the same ID.
                        Do you have homebridge on your network already?
                        https://homebridge.io/ is the underlying software, and has moved past what this module had supported. I personally went to a smart plug instead. There’s too many problems with this module to set it up. Took me a solid 3 weeks of debugging to get this to work part of the time.
                        • 2 / 3
