    MMM-HomeKit | Control your MagicMirror with Apple HomeKit
    27 Posts 17 Posters 25.7k Views 20 Watching
    • N
      NorthernMan54 @Baassievalk
      @Baassievalk
      After much googling, the answer is here:
      https://stackoverflow.com/questions/21659637/how-to-fix-sudo-no-tty-present-and-no-askpass-program-specified-error
      and in particular this comment
      username ALL = NOPASSWD: /fullpath/to/command, /fullpath/to/othercommand
      In my setup I created a file called /etc/sudoers.d/010_cmdswitch2
      And the file contains
      homebrid ALL = NOPASSWD: /bin/chvt
      chvt is the command I need to run, and homebrid is the account I use to run my homebridge with
      • A
        a0ies
        • A
          amaralia @Caimin
          @Caimin Bonjour a toi
          Would it be possible for you to give me a hand,
          I have homebridge on one raspberry and magic mirror on another.
          i am using hdmi on the magic mirror.
          I can’t understand why I have this error on the image
          Yours
          j’ai cette configuration
              "platform": "cmdSwitch2",
              "name": "Ecran Mirroir",
              "switches": [
                      "name": "magicmirror",
                      "on_cmd": "curl -s 'http://192.168.1.2:8080/remote?action=MONITORON'",
                      "off_cmd": "curl -s 'http://192.168.1.2:8080/remote?action=MONITOROFF'",
                      "state_cmd": "sshpass -p 'Armagedon13' ssh -oStrictHostKeyChecking=no pi@192.168.1.2 vcgencmd display_power | grep -q 'HDMI DMT && echo '1'",
                      "polling": true,
                      "interval": 10,
                      "manufacturer": "Raspberry Pi Foundation",
                      "model": "Raspberry Pi 3 Model B"
            sdetweil @amaralia
            @amaralia said in MMM-HomeKit | Control your MagicMirror with Apple HomeKit:
            grep -q 'HDMI DMT && echo ‘1’
            seems u are missing a single quote (before the && )
              banbutcher
              Just installed homekit and its great… i can now have the mirror switch off when i say goodnight using shortcuts, i also have it set to turn off when im not there and switch on when i get home!
              next step is to get it to switch on my playstation on voice! :)
              • F
                fragler
                I am trying to setup a Mirror and make it work with homekit. I’m very unexperienced with coding and basically everything here :)
                I followed the instructions and get the following error.
                I would appreciate your help a lot!
                Thank you in advance:
                [11.12.2020, 17:48:04] Loading 2 platforms…
                [11.12.2020, 17:48:04] [Config] Initializing config platform…
                [11.12.2020, 17:48:04] [Config] Running in Service Mode
                [11.12.2020, 17:48:04] [Raspberry Pi] Initializing cmdSwitch2 platform…
                [11.12.2020, 17:48:04] Error: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 74adc578-9ce9-42de-bbbb-5e3d84a287a1
                at Bridge.Accessory._this.addBridgedAccessory (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/src/lib/Accessory.ts:416:15)
                at /usr/lib/node_modules/homebridge/src/server.ts:310:19
                at Array.filter ()
                at Server.restoreCachedPlatformAccessories (/usr/lib/node_modules/homebridge/src/server.ts:270:69)
                at Server.start (/usr/lib/node_modules/homebridge/src/server.ts:158:10)
                at cli (/usr/lib/node_modules/homebridge/src/cli.ts:80:10)
                at Object. (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
                at Module._compile (internal/modules/cjs/loader.js:1063:30)
                at Object.Module._extensions…js (internal/modules/cjs/loader.js:1092:10)
                at Module.load (internal/modules/cjs/loader.js:928:32)
                S BKeyportB 2 Replies Last reply
                  sdetweil @fragler
                  @fragler said in MMM-HomeKit | Control your MagicMirror with Apple HomeKit:
                  • BKeyportB
                    BKeyport Module Developer @fragler
                    @fragler
                    FYI, this non-module is a piece of abandonware.
                    Looks like you’ve got two devices using the same ID.
                    Do you have homebridge on your network already?
                    https://homebridge.io/ is the underlying software, and has moved past what this module had supported. I personally went to a smart plug instead. There’s too many problems with this module to set it up. Took me a solid 3 weeks of debugging to get this to work part of the time.
                    F 1 Reply Last reply
                    • F
                      fragler @BKeyport
                      @BKeyport Yes I have homebridge online and running. But there is no other device I’m using with homebridge.
                      Okay if this module does not work well, then that’s another story.
                      The problem with the smart plug is that when I turn off the monitor (i.e. kill power) and turn power on again, I need to turn the monitor on with a button as well. So if I were to use a smart plug I could turn on power for the monitor but would still have to press a button :/
                      That’s why I thought this would be a great solution with this module…
                      But thank you all so much for your quick replies!!
                      • BKeyportB
                        OK, then I think the Homebridge already has the accessory partially or fully defined. Something’s happening that duplicating your install somewhere.
                        M 1 Reply Last reply
                          MajorC Project Sponsor @BKeyport
                          @bkeyport is there a way to show my EVE Weather station data via HomeKit or HomeBridge on the MagicMirror?
                          BKeyportB 1 Reply Last reply
                          • BKeyportB
                            BKeyport Module Developer @MajorC
                            @majorc I stopped using this, It’s not really a “MagicMirror” module. It’s a basic concept.
                            I don’t know much about homebridge. You could look at https://homebridge.io/
                              janth
                              Hello :) I have been using th cmdSwitcht2 plugin for the past 3 years. Last weekend I updated homebridge for the (to me) new UI-X and MM and Raspberry Pi OS… I thought it’d take me an hour or so.
                              I can’t get the on-command to work. I tried different commands like 'vcgencmd display_power 1* and the one that is suggested here. vcgencmd display_power 1 does not work. /opt/vc/bin/tvservice -p; sudo /bin/chvt 6; sudo /bin/chvt 7 works from user pi, but homebridge runs from a different user also called homebridge.
                              When turning the switch on, it logs the following: "Failed to turn on Spiegelmonitor
                              [24.9.2021, 09:59:26] [cmdSwitch2] sudo: Kein TTY vorhanden und kein »askpass«-Programm angegeben
                              When running tvservice --preferred && sudo chvt 6 && sudo chvt 7 from the console in Homebridge UI X, it says
                              chvt: ioctl VT_ACTIVATE: Die Operation ist nicht erlaubt
                              I tried to give homebridge the same rights in /etc/sudoers and checked /dev/fb0 rights but I don’t fully understand everything I did there. Has anyone had the same issue before?
                                Jag_k
                                Hello guys! Some days ago, I created a plugin for Homebridge to connect MagicMirror!
                                Now this plugin can:
                                • Change brightness of mirror
                                • Enable/disable monitor
                                In future, I want add switchers to on/off modules on mirror, CPU/GPU usage, rebooting mirror (hardware and software), CPU temperature and more
                                Please, give feed-back about this plugin
                                • BKeyportB
                                  BKeyport Module Developer @Jag_k
                                  @jag_k 404 on the link.
