    MMM-HomeKit | Control your MagicMirror with Apple HomeKit
    27 Posts 17 Posters 25.6k Views 20 Watching
    • NiggichN
      Niggich
      @XC2DN
      My Homebridge is at another Pi then the Mirror. How I have to use it?
      C 1 Reply Last reply
        Caimin @Niggich
        @Niggich Making connection to the other pi through ssh to send commands? Or if your using a module which allows to give commands through a url u can use curl… In this example I use both…
               "name" : "Magic Mirror",
               "on_cmd": "curl -s 'http://192.168.X.XX:8080/remote?action=MONITORON'",
               "off_cmd": "curl -s 'http://192.168.X.XX:8080/remote?action=MONITOROFF'",
               "state_cmd": "sshpass -p 'sshpassword' ssh -oStrictHostKeyChecking=no pi@192.168.X.XX vcgencmd display_power | grep -q '1' && echo '1'",
               "polling": true,
               "interval": 10,
               "manufacturer": "XXX",
               "model": "v 1.0.0"
        You might need to install sshpass: apt-get install sshpass, which allows you to connect through ssh with password without being prompted on the command line for the password.
        NiggichN A 2 Replies Last reply
        • NiggichN
          Niggich @Caimin
          @Caimin Thank you a lot. It is working like this. I install sshpass to send the Commands via ssh.
          • K
            kevinlingley
              Baassievalk
                Baassievalk
                Hi!
                I need a little help setting it up…
                When turning on the mirror in the HomeKit App I get the following log:
                [2020-3-29 22:26:16] [Raspberry Pi] Mirror is off.
                [2020-3-29 22:26:17] [Raspberry Pi] Failed to turn on Mirror
                Als het goed is hebt u de gebruikelijke informatie ontvangen van uw
                systeembeheerder. Gewoonlijk komt het neer op de volgende drie punten:
                    1. Respecteer de privacy van anderen.
                    2. Denk na voordat u iets doet.
                    3. Veel mogelijkheden betekent veel verantwoordelijkheid.
                sudo: geen terminal aanwezig en geen wachtwoordvraag(askpass)-programma opgegeven
                Translated
                "Als het goed is hebt u de gebruikelijke informatie ontvangen van uw
                    3. Veel mogelijkheden betekent veel verantwoordelijkheid." This is a little talk about privacy but then:
                sudo: no terminal available and no  passwordask(askpass) programs gave up.
                If anyone knows a solution, would be appreciated!
                N 1 Reply Last reply
                • N
                  NorthernMan54 @Baassievalk
                  @Baassievalk
                  After much googling, the answer is here:
                  https://stackoverflow.com/questions/21659637/how-to-fix-sudo-no-tty-present-and-no-askpass-program-specified-error
                  and in particular this comment
                  username ALL = NOPASSWD: /fullpath/to/command, /fullpath/to/othercommand
                  In my setup I created a file called /etc/sudoers.d/010_cmdswitch2
                  And the file contains
                  homebrid ALL = NOPASSWD: /bin/chvt
                  chvt is the command I need to run, and homebrid is the account I use to run my homebridge with
                  • A
                    a0ies
                    • A
                      amaralia @Caimin
                      @Caimin Bonjour a toi
                      Would it be possible for you to give me a hand,
                      I have homebridge on one raspberry and magic mirror on another.
                      i am using hdmi on the magic mirror.
                      I can’t understand why I have this error on the image
                      Yours
                      j’ai cette configuration
                          "platform": "cmdSwitch2",
                          "name": "Ecran Mirroir",
                          "switches": [
                                  "name": "magicmirror",
                                  "on_cmd": "curl -s 'http://192.168.1.2:8080/remote?action=MONITORON'",
                                  "off_cmd": "curl -s 'http://192.168.1.2:8080/remote?action=MONITOROFF'",
                                  "state_cmd": "sshpass -p 'Armagedon13' ssh -oStrictHostKeyChecking=no pi@192.168.1.2 vcgencmd display_power | grep -q 'HDMI DMT && echo '1'",
                                  "polling": true,
                                  "interval": 10,
                                  "manufacturer": "Raspberry Pi Foundation",
                                  "model": "Raspberry Pi 3 Model B"
                        sdetweil @amaralia
                        @amaralia said in MMM-HomeKit | Control your MagicMirror with Apple HomeKit:
                        grep -q 'HDMI DMT && echo ‘1’
                        seems u are missing a single quote (before the && )
                          banbutcher
                          Just installed homekit and its great… i can now have the mirror switch off when i say goodnight using shortcuts, i also have it set to turn off when im not there and switch on when i get home!
                          next step is to get it to switch on my playstation on voice! :)
                          • F
                            fragler
                            I am trying to setup a Mirror and make it work with homekit. I’m very unexperienced with coding and basically everything here :)
                            I followed the instructions and get the following error.
                            I would appreciate your help a lot!
                            Thank you in advance:
                            [11.12.2020, 17:48:04] Loading 2 platforms…
                            [11.12.2020, 17:48:04] [Config] Initializing config platform…
                            [11.12.2020, 17:48:04] [Config] Running in Service Mode
                            [11.12.2020, 17:48:04] [Raspberry Pi] Initializing cmdSwitch2 platform…
                            [11.12.2020, 17:48:04] Error: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 74adc578-9ce9-42de-bbbb-5e3d84a287a1
                            at Bridge.Accessory._this.addBridgedAccessory (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/src/lib/Accessory.ts:416:15)
                            at /usr/lib/node_modules/homebridge/src/server.ts:310:19
                            at Array.filter ()
                            at Server.restoreCachedPlatformAccessories (/usr/lib/node_modules/homebridge/src/server.ts:270:69)
                            at Server.start (/usr/lib/node_modules/homebridge/src/server.ts:158:10)
                            at cli (/usr/lib/node_modules/homebridge/src/cli.ts:80:10)
                            at Object. (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
                            at Module._compile (internal/modules/cjs/loader.js:1063:30)
                            at Object.Module._extensions…js (internal/modules/cjs/loader.js:1092:10)
                            at Module.load (internal/modules/cjs/loader.js:928:32)
                            S BKeyportB 2 Replies Last reply
                              sdetweil @fragler
                              @fragler said in MMM-HomeKit | Control your MagicMirror with Apple HomeKit:
                              • BKeyportB
                                BKeyport Module Developer @fragler
                                @fragler
                                FYI, this non-module is a piece of abandonware.
                                Looks like you’ve got two devices using the same ID.
                                Do you have homebridge on your network already?
                                https://homebridge.io/ is the underlying software, and has moved past what this module had supported. I personally went to a smart plug instead. There’s too many problems with this module to set it up. Took me a solid 3 weeks of debugging to get this to work part of the time.
                                F 1 Reply Last reply
                                • F
                                  fragler @BKeyport
                                  @BKeyport Yes I have homebridge online and running. But there is no other device I’m using with homebridge.
                                  Okay if this module does not work well, then that’s another story.
                                  The problem with the smart plug is that when I turn off the monitor (i.e. kill power) and turn power on again, I need to turn the monitor on with a button as well. So if I were to use a smart plug I could turn on power for the monitor but would still have to press a button :/
                                  That’s why I thought this would be a great solution with this module…
                                  But thank you all so much for your quick replies!!
                                  • BKeyportB
                                    OK, then I think the Homebridge already has the accessory partially or fully defined. Something’s happening that duplicating your install somewhere.
                                    M 1 Reply Last reply
                                      MajorC Project Sponsor @BKeyport
                                      @bkeyport is there a way to show my EVE Weather station data via HomeKit or HomeBridge on the MagicMirror?
                                      BKeyportB 1 Reply Last reply
                                      • BKeyportB
                                        BKeyport Module Developer @MajorC
                                        @majorc I stopped using this, It’s not really a “MagicMirror” module. It’s a basic concept.
                                        I don’t know much about homebridge. You could look at https://homebridge.io/
                                          janth
                                          Hello :) I have been using th cmdSwitcht2 plugin for the past 3 years. Last weekend I updated homebridge for the (to me) new UI-X and MM and Raspberry Pi OS… I thought it’d take me an hour or so.
                                          I can’t get the on-command to work. I tried different commands like 'vcgencmd display_power 1* and the one that is suggested here. vcgencmd display_power 1 does not work. /opt/vc/bin/tvservice -p; sudo /bin/chvt 6; sudo /bin/chvt 7 works from user pi, but homebridge runs from a different user also called homebridge.
                                          When turning the switch on, it logs the following: "Failed to turn on Spiegelmonitor
                                          [24.9.2021, 09:59:26] [cmdSwitch2] sudo: Kein TTY vorhanden und kein »askpass«-Programm angegeben
                                          When running tvservice --preferred && sudo chvt 6 && sudo chvt 7 from the console in Homebridge UI X, it says
                                          chvt: ioctl VT_ACTIVATE: Die Operation ist nicht erlaubt
                                          I tried to give homebridge the same rights in /etc/sudoers and checked /dev/fb0 rights but I don’t fully understand everything I did there. Has anyone had the same issue before?
                                            Jag_k
                                            Hello guys! Some days ago, I created a plugin for Homebridge to connect MagicMirror!
                                            Now this plugin can:
                                            • Change brightness of mirror
                                            • Enable/disable monitor
                                            In future, I want add switchers to on/off modules on mirror, CPU/GPU usage, rebooting mirror (hardware and software), CPU temperature and more
                                            Please, give feed-back about this plugin
