    MMM-HomeKit | Control your MagicMirror with Apple HomeKit
    27 Posts 17 Posters 25.7k Views 20 Watching
      A Former User @Guest
      @XC2DN
      Can we add additional cmdSwitch2 platform for other shell command? If so, module controlling could be added besides screen on/off
      ? 1 Reply Last reply
        @Sean said in MMM-HomeKit | Control your MagicMirror with Apple HomeKit:
        Yes! Absolutely. Just add this to the “switches” sections.
            "name" : "Name of the HomeKit command",
            "on_cmd": "bash command to show a module",
            "off_cmd": "bash command to hide a module",
            "state_cmd": "bash command to get the hide / show status'",
            "manufacturer": "Raspberry Pi Foundation",
            "model": "Raspberry Pi 3 Model B",
        Your config.json should look something like this.
        "platforms": [{
          "platform": "cmdSwitch2",
          "name": "Raspberry Pi",
          "switches": [{
            "name" : "Mirror",
            "on_cmd": "tvservice --preferred && sudo chvt 6 && sudo chvt 7",
            "off_cmd": "tvservice -o",
            "state_cmd": "tvservice --status | grep -i 'HDMI DMT'",
          p4lsec
          Excellent module!
          Got everything working fairly easily. I am attempting to add my own switches, but the issues I am having is that the “on_cmd” and “off_cmd” do not use npm correctly. Any ideas? This is the error it’s throwing. Didn’t have luck Googling.
          [3/10/2019, 1:42:17 PM] [Raspberry Pi] npm ERR! path /home/pi/package.json
          npm ERR! code ENOENT
          npm ERR! errno -2
          npm ERR! syscall open
          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
          npm ERR! enoent This is related to npm not being able to find a file.
          npm ERR! enoent
            p4lsec
            Okay, looks like something with my npm was broken. It was working before, so I think installing this module or Homebridge did it. Attempting to fix.
              A Former User @p4lsec
              @p4lsec said in MMM-HomeKit | Control your MagicMirror with Apple HomeKit:
              Excellent module!
              Hello ! Thank you for that compliment.
              Unfortunately, I don’t know where your problem comes from. What is the command you are executing that gives you this error?
              Keep me informed :wink:
              • NiggichN
                Niggich
                @XC2DN
                My Homebridge is at another Pi then the Mirror. How I have to use it?
                C 1 Reply Last reply
                  Caimin @Niggich
                  @Niggich Making connection to the other pi through ssh to send commands? Or if your using a module which allows to give commands through a url u can use curl… In this example I use both…
                         "name" : "Magic Mirror",
                         "on_cmd": "curl -s 'http://192.168.X.XX:8080/remote?action=MONITORON'",
                         "off_cmd": "curl -s 'http://192.168.X.XX:8080/remote?action=MONITOROFF'",
                         "state_cmd": "sshpass -p 'sshpassword' ssh -oStrictHostKeyChecking=no pi@192.168.X.XX vcgencmd display_power | grep -q '1' && echo '1'",
                         "polling": true,
                         "interval": 10,
                         "manufacturer": "XXX",
                         "model": "v 1.0.0"
                  You might need to install sshpass: apt-get install sshpass, which allows you to connect through ssh with password without being prompted on the command line for the password.
                  NiggichN A 2 Replies Last reply
                  • NiggichN
                    Niggich @Caimin
                    @Caimin Thank you a lot. It is working like this. I install sshpass to send the Commands via ssh.
                    • K
                      kevinlingley
                        Baassievalk
                          Baassievalk
                          Hi!
                          I need a little help setting it up…
                          When turning on the mirror in the HomeKit App I get the following log:
                          [2020-3-29 22:26:16] [Raspberry Pi] Mirror is off.
                          [2020-3-29 22:26:17] [Raspberry Pi] Failed to turn on Mirror
                          Als het goed is hebt u de gebruikelijke informatie ontvangen van uw
                          systeembeheerder. Gewoonlijk komt het neer op de volgende drie punten:
                              1. Respecteer de privacy van anderen.
                              2. Denk na voordat u iets doet.
                              3. Veel mogelijkheden betekent veel verantwoordelijkheid.
                          sudo: geen terminal aanwezig en geen wachtwoordvraag(askpass)-programma opgegeven
                          Translated
                          "Als het goed is hebt u de gebruikelijke informatie ontvangen van uw
                              3. Veel mogelijkheden betekent veel verantwoordelijkheid." This is a little talk about privacy but then:
                          sudo: no terminal available and no  passwordask(askpass) programs gave up.
                          If anyone knows a solution, would be appreciated!
                          N 1 Reply Last reply
                          • N
                            NorthernMan54 @Baassievalk
                            @Baassievalk
                            After much googling, the answer is here:
                            https://stackoverflow.com/questions/21659637/how-to-fix-sudo-no-tty-present-and-no-askpass-program-specified-error
                            and in particular this comment
                            username ALL = NOPASSWD: /fullpath/to/command, /fullpath/to/othercommand
                            In my setup I created a file called /etc/sudoers.d/010_cmdswitch2
                            And the file contains
                            homebrid ALL = NOPASSWD: /bin/chvt
                            chvt is the command I need to run, and homebrid is the account I use to run my homebridge with
                            • A
                              a0ies
                              • A
                                amaralia @Caimin
                                @Caimin Bonjour a toi
                                Would it be possible for you to give me a hand,
                                I have homebridge on one raspberry and magic mirror on another.
                                i am using hdmi on the magic mirror.
                                I can’t understand why I have this error on the image
                                Yours
                                j’ai cette configuration
                                    "name": "Ecran Mirroir",
                                    "switches": [
                                            "name": "magicmirror",
                                            "on_cmd": "curl -s 'http://192.168.1.2:8080/remote?action=MONITORON'",
                                            "off_cmd": "curl -s 'http://192.168.1.2:8080/remote?action=MONITOROFF'",
                                            "state_cmd": "sshpass -p 'Armagedon13' ssh -oStrictHostKeyChecking=no pi@192.168.1.2 vcgencmd display_power | grep -q 'HDMI DMT && echo '1'",
                                            "polling": true,
                                            "interval": 10,
                                  sdetweil @amaralia
                                  @amaralia said in MMM-HomeKit | Control your MagicMirror with Apple HomeKit:
                                  grep -q 'HDMI DMT && echo ‘1’
                                  seems u are missing a single quote (before the && )
                                    banbutcher
                                    Just installed homekit and its great… i can now have the mirror switch off when i say goodnight using shortcuts, i also have it set to turn off when im not there and switch on when i get home!
                                    next step is to get it to switch on my playstation on voice! :)
                                    • F
                                      fragler
                                      I am trying to setup a Mirror and make it work with homekit. I’m very unexperienced with coding and basically everything here :)
                                      I followed the instructions and get the following error.
                                      I would appreciate your help a lot!
                                      Thank you in advance:
                                      [11.12.2020, 17:48:04] Loading 2 platforms…
                                      [11.12.2020, 17:48:04] [Config] Initializing config platform…
                                      [11.12.2020, 17:48:04] [Config] Running in Service Mode
                                      [11.12.2020, 17:48:04] [Raspberry Pi] Initializing cmdSwitch2 platform…
                                      [11.12.2020, 17:48:04] Error: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 74adc578-9ce9-42de-bbbb-5e3d84a287a1
                                      at Bridge.Accessory._this.addBridgedAccessory (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/src/lib/Accessory.ts:416:15)
                                      at /usr/lib/node_modules/homebridge/src/server.ts:310:19
                                      at Array.filter ()
                                      at Server.restoreCachedPlatformAccessories (/usr/lib/node_modules/homebridge/src/server.ts:270:69)
                                      at Server.start (/usr/lib/node_modules/homebridge/src/server.ts:158:10)
                                      at cli (/usr/lib/node_modules/homebridge/src/cli.ts:80:10)
                                      at Object. (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
                                      at Module._compile (internal/modules/cjs/loader.js:1063:30)
                                      at Object.Module._extensions…js (internal/modules/cjs/loader.js:1092:10)
                                      at Module.load (internal/modules/cjs/loader.js:928:32)
                                      S BKeyportB 2 Replies Last reply
                                        sdetweil @fragler
                                        @fragler said in MMM-HomeKit | Control your MagicMirror with Apple HomeKit:
                                        • BKeyportB
                                          BKeyport Module Developer @fragler
                                          @fragler
                                          FYI, this non-module is a piece of abandonware.
                                          Looks like you’ve got two devices using the same ID.
                                          Do you have homebridge on your network already?
                                          https://homebridge.io/ is the underlying software, and has moved past what this module had supported. I personally went to a smart plug instead. There’s too many problems with this module to set it up. Took me a solid 3 weeks of debugging to get this to work part of the time.
                                          F 1 Reply Last reply
                                          • F
                                            fragler @BKeyport
                                            @BKeyport Yes I have homebridge online and running. But there is no other device I’m using with homebridge.
                                            Okay if this module does not work well, then that’s another story.
                                            The problem with the smart plug is that when I turn off the monitor (i.e. kill power) and turn power on again, I need to turn the monitor on with a button as well. So if I were to use a smart plug I could turn on power for the monitor but would still have to press a button :/
                                            That’s why I thought this would be a great solution with this module…
                                            But thank you all so much for your quick replies!!
