    MMM-HomeKit | Control your MagicMirror with Apple HomeKit
    27 Posts 17 Posters 23.4k Views 20 Watching
      A Former User @p4lsec
      @p4lsec said in MMM-HomeKit | Control your MagicMirror with Apple HomeKit:
      Excellent module!
      Hello ! Thank you for that compliment.
      Unfortunately, I don’t know where your problem comes from. What is the command you are executing that gives you this error?
      Keep me informed :wink:
      • N Offline
        Niggich
        @XC2DN
        My Homebridge is at another Pi then the Mirror. How I have to use it?
          Caimin @Niggich
          @Niggich Making connection to the other pi through ssh to send commands? Or if your using a module which allows to give commands through a url u can use curl… In this example I use both…
                 "name" : "Magic Mirror",
                 "on_cmd": "curl -s 'http://192.168.X.XX:8080/remote?action=MONITORON'",
                 "off_cmd": "curl -s 'http://192.168.X.XX:8080/remote?action=MONITOROFF'",
                 "state_cmd": "sshpass -p 'sshpassword' ssh -oStrictHostKeyChecking=no pi@192.168.X.XX vcgencmd display_power | grep -q '1' && echo '1'",
                 "polling": true,
                 "interval": 10,
                 "manufacturer": "XXX",
                 "model": "v 1.0.0"
          You might need to install sshpass: apt-get install sshpass, which allows you to connect through ssh with password without being prompted on the command line for the password.
          N A 2 Replies Last reply Reply Quote 0
          • N Offline
            Niggich @Caimin
            @Caimin Thank you a lot. It is working like this. I install sshpass to send the Commands via ssh.
            • K Offline
              kevinlingley
                Baassievalk
                  Baassievalk
                  Hi!
                  I need a little help setting it up…
                  When turning on the mirror in the HomeKit App I get the following log:
                  [2020-3-29 22:26:16] [Raspberry Pi] Mirror is off.
                  [2020-3-29 22:26:17] [Raspberry Pi] Failed to turn on Mirror
                  Als het goed is hebt u de gebruikelijke informatie ontvangen van uw
                  systeembeheerder. Gewoonlijk komt het neer op de volgende drie punten:
                      1. Respecteer de privacy van anderen.
                      2. Denk na voordat u iets doet.
                      3. Veel mogelijkheden betekent veel verantwoordelijkheid.
                  sudo: geen terminal aanwezig en geen wachtwoordvraag(askpass)-programma opgegeven
                  Translated
                  "Als het goed is hebt u de gebruikelijke informatie ontvangen van uw
                      3. Veel mogelijkheden betekent veel verantwoordelijkheid." This is a little talk about privacy but then:
                  sudo: no terminal available and no  passwordask(askpass) programs gave up.
                  If anyone knows a solution, would be appreciated!
                  • N Offline
                    NorthernMan54 @Baassievalk
                    @Baassievalk
                    After much googling, the answer is here:
                    https://stackoverflow.com/questions/21659637/how-to-fix-sudo-no-tty-present-and-no-askpass-program-specified-error
                    and in particular this comment
                    username ALL = NOPASSWD: /fullpath/to/command, /fullpath/to/othercommand
                    In my setup I created a file called /etc/sudoers.d/010_cmdswitch2
                    And the file contains
                    homebrid ALL = NOPASSWD: /bin/chvt
                    chvt is the command I need to run, and homebrid is the account I use to run my homebridge with
                      a0ies
                        amaralia @Caimin
                        @Caimin Bonjour a toi
                        Would it be possible for you to give me a hand,
                        I have homebridge on one raspberry and magic mirror on another.
                        i am using hdmi on the magic mirror.
                        I can’t understand why I have this error on the image
                        Yours
                        j’ai cette configuration
                            "platform": "cmdSwitch2",
                            "name": "Ecran Mirroir",
                            "switches": [
                                    "name": "magicmirror",
                                    "on_cmd": "curl -s 'http://192.168.1.2:8080/remote?action=MONITORON'",
                                    "off_cmd": "curl -s 'http://192.168.1.2:8080/remote?action=MONITOROFF'",
                                    "state_cmd": "sshpass -p 'Armagedon13' ssh -oStrictHostKeyChecking=no pi@192.168.1.2 vcgencmd display_power | grep -q 'HDMI DMT && echo '1'",
                                    "polling": true,
                                    "interval": 10,
                                    "manufacturer": "Raspberry Pi Foundation",
                                    "model": "Raspberry Pi 3 Model B"
