    MMM-HomeKit | Control your MagicMirror with Apple HomeKit
    27 Posts 17 Posters 25.7k Views 20 Watching
      p4lsec
      Okay, looks like something with my npm was broken. It was working before, so I think installing this module or Homebridge did it. Attempting to fix.
        A Former User @p4lsec
        @p4lsec said in MMM-HomeKit | Control your MagicMirror with Apple HomeKit:
        Excellent module!
        Hello ! Thank you for that compliment.
        Unfortunately, I don’t know where your problem comes from. What is the command you are executing that gives you this error?
        Keep me informed :wink:
        • NiggichN
          Niggich
          @XC2DN
          My Homebridge is at another Pi then the Mirror. How I have to use it?
          C 1 Reply Last reply
            Caimin @Niggich
            @Niggich Making connection to the other pi through ssh to send commands? Or if your using a module which allows to give commands through a url u can use curl… In this example I use both…
                   "name" : "Magic Mirror",
                   "on_cmd": "curl -s 'http://192.168.X.XX:8080/remote?action=MONITORON'",
                   "off_cmd": "curl -s 'http://192.168.X.XX:8080/remote?action=MONITOROFF'",
                   "state_cmd": "sshpass -p 'sshpassword' ssh -oStrictHostKeyChecking=no pi@192.168.X.XX vcgencmd display_power | grep -q '1' && echo '1'",
                   "polling": true,
                   "interval": 10,
                   "manufacturer": "XXX",
                   "model": "v 1.0.0"
            You might need to install sshpass: apt-get install sshpass, which allows you to connect through ssh with password without being prompted on the command line for the password.
            NiggichN A 2 Replies Last reply
            • NiggichN
              Niggich @Caimin
              @Caimin Thank you a lot. It is working like this. I install sshpass to send the Commands via ssh.
              • K
                kevinlingley
                  Baassievalk
                    Baassievalk
                    Hi!
                    I need a little help setting it up…
                    When turning on the mirror in the HomeKit App I get the following log:
                    [2020-3-29 22:26:16] [Raspberry Pi] Mirror is off.
                    [2020-3-29 22:26:17] [Raspberry Pi] Failed to turn on Mirror
                    Als het goed is hebt u de gebruikelijke informatie ontvangen van uw
                    systeembeheerder. Gewoonlijk komt het neer op de volgende drie punten:
                        1. Respecteer de privacy van anderen.
                        2. Denk na voordat u iets doet.
                        3. Veel mogelijkheden betekent veel verantwoordelijkheid.
                    sudo: geen terminal aanwezig en geen wachtwoordvraag(askpass)-programma opgegeven
                    Translated
                    "Als het goed is hebt u de gebruikelijke informatie ontvangen van uw
                        3. Veel mogelijkheden betekent veel verantwoordelijkheid." This is a little talk about privacy but then:
                    sudo: no terminal available and no  passwordask(askpass) programs gave up.
                    If anyone knows a solution, would be appreciated!
                    N 1 Reply Last reply
                    • N
                      NorthernMan54 @Baassievalk
                      @Baassievalk
                      After much googling, the answer is here:
                      https://stackoverflow.com/questions/21659637/how-to-fix-sudo-no-tty-present-and-no-askpass-program-specified-error
                      and in particular this comment
                      username ALL = NOPASSWD: /fullpath/to/command, /fullpath/to/othercommand
                      In my setup I created a file called /etc/sudoers.d/010_cmdswitch2
                      And the file contains
                      homebrid ALL = NOPASSWD: /bin/chvt
                      chvt is the command I need to run, and homebrid is the account I use to run my homebridge with
                      • A
                        a0ies
                        • A
                          amaralia @Caimin
                          @Caimin Bonjour a toi
                          Would it be possible for you to give me a hand,
                          I have homebridge on one raspberry and magic mirror on another.
                          i am using hdmi on the magic mirror.
                          I can’t understand why I have this error on the image
                          Yours
                          j’ai cette configuration
                              "platform": "cmdSwitch2",
                              "name": "Ecran Mirroir",
                              "switches": [
                                      "name": "magicmirror",
                                      "on_cmd": "curl -s 'http://192.168.1.2:8080/remote?action=MONITORON'",
                                      "off_cmd": "curl -s 'http://192.168.1.2:8080/remote?action=MONITOROFF'",
                                      "state_cmd": "sshpass -p 'Armagedon13' ssh -oStrictHostKeyChecking=no pi@192.168.1.2 vcgencmd display_power | grep -q 'HDMI DMT && echo '1'",
                                      "polling": true,
                                      "interval": 10,
                                      "manufacturer": "Raspberry Pi Foundation",
                                      "model": "Raspberry Pi 3 Model B"
                            sdetweil @amaralia
                            @amaralia said in MMM-HomeKit | Control your MagicMirror with Apple HomeKit:
                            grep -q 'HDMI DMT && echo ‘1’
                            seems u are missing a single quote (before the && )
                              banbutcher
                              Just installed homekit and its great… i can now have the mirror switch off when i say goodnight using shortcuts, i also have it set to turn off when im not there and switch on when i get home!
                              next step is to get it to switch on my playstation on voice! :)
                              • F
                                fragler
                                I am trying to setup a Mirror and make it work with homekit. I’m very unexperienced with coding and basically everything here :)
                                I followed the instructions and get the following error.
                                I would appreciate your help a lot!
                                Thank you in advance:
                                [11.12.2020, 17:48:04] Loading 2 platforms…
                                [11.12.2020, 17:48:04] [Config] Initializing config platform…
                                [11.12.2020, 17:48:04] [Config] Running in Service Mode
                                [11.12.2020, 17:48:04] [Raspberry Pi] Initializing cmdSwitch2 platform…
                                [11.12.2020, 17:48:04] Error: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 74adc578-9ce9-42de-bbbb-5e3d84a287a1
                                at Bridge.Accessory._this.addBridgedAccessory (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/src/lib/Accessory.ts:416:15)
                                at /usr/lib/node_modules/homebridge/src/server.ts:310:19
                                at Array.filter ()
                                at Server.restoreCachedPlatformAccessories (/usr/lib/node_modules/homebridge/src/server.ts:270:69)
                                at Server.start (/usr/lib/node_modules/homebridge/src/server.ts:158:10)
                                at cli (/usr/lib/node_modules/homebridge/src/cli.ts:80:10)
                                at Object. (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
                                at Module._compile (internal/modules/cjs/loader.js:1063:30)
                                at Object.Module._extensions…js (internal/modules/cjs/loader.js:1092:10)
                                at Module.load (internal/modules/cjs/loader.js:928:32)
                                S BKeyportB 2 Replies Last reply
                                  sdetweil @fragler
                                  @fragler said in MMM-HomeKit | Control your MagicMirror with Apple HomeKit:
                                  • BKeyportB
                                    BKeyport Module Developer @fragler
                                    @fragler
                                    FYI, this non-module is a piece of abandonware.
                                    Looks like you’ve got two devices using the same ID.
                                    Do you have homebridge on your network already?
                                    https://homebridge.io/ is the underlying software, and has moved past what this module had supported. I personally went to a smart plug instead. There’s too many problems with this module to set it up. Took me a solid 3 weeks of debugging to get this to work part of the time.
                                    F 1 Reply Last reply
                                    • F
                                      fragler @BKeyport
                                      @BKeyport Yes I have homebridge online and running. But there is no other device I’m using with homebridge.
                                      Okay if this module does not work well, then that’s another story.
                                      The problem with the smart plug is that when I turn off the monitor (i.e. kill power) and turn power on again, I need to turn the monitor on with a button as well. So if I were to use a smart plug I could turn on power for the monitor but would still have to press a button :/
                                      That’s why I thought this would be a great solution with this module…
                                      But thank you all so much for your quick replies!!
                                      • BKeyportB
                                        OK, then I think the Homebridge already has the accessory partially or fully defined. Something’s happening that duplicating your install somewhere.
                                        M 1 Reply Last reply
                                          MajorC Project Sponsor @BKeyport
                                          @bkeyport is there a way to show my EVE Weather station data via HomeKit or HomeBridge on the MagicMirror?
                                          BKeyportB 1 Reply Last reply
                                          • BKeyportB
                                            BKeyport Module Developer @MajorC
                                            @majorc I stopped using this, It’s not really a “MagicMirror” module. It’s a basic concept.
                                            I don’t know much about homebridge. You could look at https://homebridge.io/
