    Develop module with API
    42 Posts 6 Posters 18.0k Views 6 Watching
    • ? Offline
      A Former User @htilburgs
      @htilburgs
      If your API can be reached simply (without authentification, or any other dependencies), You can use xmlHttpRequest to get contents of specific URL in your main module js.
      When you need that result of API, Use this logic. (It’s better to make function. but here is just example)
      var url = "http://api.aladhan.com/......"
      var req = new XMLHttpRequest()
      req.overrideMimeType("application/json")
      req.open('GET', url, true)
      req.onload  = () => {
         var jsonResult = JSON.parse(req.responseText)
         // do your job with jsonResult
         console.log(jsonResult)
      req.send()
      See https://www.w3schools.com/xml/xml_http.asp to learn about XMLHttpRequest
      • ? Offline
        @htilburgs
        Then, you can access the jsonData like this; (This will be your main job)
        var Fajr = jsonResult.data.timings.Fajr
        console.log(Fajr)
        last, you can print it MM screen with .getDom()(You should call .updateDom() to update screen) or DOM manipulation.
        this.dataToShow.Fajr = jsonResult.data.timings.Fajr
        getDom : function() {
          var dom = document.createElement("div")
          if (this.dataToShow) dom.innerHTML = this.dataToShow.Fajr
          return dom
        I’m skipping many things. This is just hint or sample. Remains will be your homework. :D
        • htilburgsH Offline
          htilburgs @Mykle1
          @Mykle1 @Sean
          Both thanks for the quick reply.
          For now I’ve information that I can use to start.
          If there are any questions, I know where to be ;-)
          (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
            htilburgs
            I used the example from MMM-UFO, and started the module.
            How can I check if there is data from the API URL?
            htilburgsH 1 Reply Last reply Reply Quote 0
              htilburgs @htilburgs
              Oke, got it. I had to add some console.log settings…:flushed_face:
                htilburgs
                @Mykle1 I’m using MMM-UFO as example and trying to figure out. I’m getting somewhere but… The data is retrieved through the api and this is the result:
                Asr: "16:01"
                Dhuhr: "12:46"
                Fajr: "05:12"
                Imsak: "05:02"
                Isha: "20:21"
                Maghrib: "18:49"
                Midnight: "00:46"
                Sunrise: "06:44"
                Sunset: "18:49"
                The module is generated on the MM
                alt text
                But as you can see, it cannot read or display the data in the correct way.
                This is the code that I use to get the data from the resultset.
                // Fajr from data
                var mptFajr = document.createElement("div");
                mptFajr.classList.add("small", "bright", "fajr");
                mptFajr.innerHTML = "Fajr : " + MPT.Fajr;
                wrapper.appendChild(mptFajr);
                I can’t figure out what the problem is. It seems have something to do with the time-string that is returned. But whatever I try, no luck. Any idea?
                  Mykle1 Project Sponsor Module Developer @htilburgs
                  @htilburgs said in Develop module with API:
                  Is this correct? MPT.Fajr above? Not mpt.Fajr?
                    sdetweil @Mykle1
                    @Mykle1 it’s not json format. Same problem as your PC stats
                      htilburgs
                      @Mykle1, @sdetweil ,
                      Looking at the website from the API Prayer Times API, the result are all displayed in JSON
                      The API has several endpoints to assist developers. Note that all the endpoints return JSON and are available over http and https.
                      I’ve looked at the code again and it should be MPT.Fajr.
                      I’ve made the module public on github, so you can take a look if you like.
                      MMM-MyPrayerTime
                      Meanwhile I’m trying to solve it…
                      • ? Offline
                        @htilburgs
                        I don’t know what you exactly want,
                        but ,
                        Instead
                        var MPT = this.MPT[Keys[this.activeItem]];
                        Use this;
                        var MPT = this.MPT
                        You can get above picture.
                        • 4 / 5
