    updated installer script available for testing
    211 Posts 18 Posters 318.8k Views 19 Watching
      bhepler Module Developer
      @sdetweil - I will be running your script on a fresh Raspberry Pi 4 1GB w/Buster desktop in a couple minutes. I’ll report back. Thank you for your hard work.
      Updated to add: Well, it took a couple days because I didn’t have an microHDMI to HDMI adapter. But once I picked one up, I was able to get onto the Pi. The installation script worked first time with no issues. Great job!
        sdetweil @bhepler
        @bhepler and??? a week later no news ??
          bhepler Module Developer @sdetweil
          @sdetweil - Sorry, I thought the update to my post covered it. The installer worked like a charm. Thanks again for your hard work!
            sdetweil @bhepler
            @bhepler I missed the update
            • qu1queQ Offline
              qu1que Project Sponsor
              Hi. I’ve just installed MM on an Orange Pi PC board using this script. Works fine, and no errors. Thanks for your work @sdetweil
                sdetweil @qu1que
                @qu1que Cool, thx
                • N Offline
                  Newbie007
                  I used the regular method to install
                  bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh
                  and ran into below error
                  alt text
                  while searching on google came across this post. Now how do I proceed?
                  How do I uninstall previous version? and install this?
                    sdetweil @Newbie007
                    @Newbie007 rename the MagicMirror folder out of the way
                    What kind of pi are u using?
                    • N Offline
                      Newbie007
                      @sdetweil said in Anyone want to try updated installer...:
                      Raspberry Pi 2 Model B Rev 1.1
                      I don’t have to delete/uninstall previous one?
                        sdetweil @Newbie007
                        @Newbie007 no, just rename. If u are happy, just delete the older folder
                          sdetweil
                          I have submitted these changes under pull request 1789
                            mrdenmark
                            i’ve tried running this installer a couple of times now but i keep getting the message-unable to install dependencies-any suggestions on how to proceed?
                              sdetweil @mrdenmark
                              @mrdenmark show me the install.log from the MagicMirror folder… email to me if cannot post…
                              email userid is same as here on gmail
                                mrdenmark
                                [0_1571974919417_install.log](Uploading 100%)
                                  mrdenmark
                                  email sent,
                                    sdetweil @mrdenmark
                                    @mrdenmark thanks… can u try
                                    cd ~/MagicMirror
                                    rm -rf node_modules
                                    npm install
                                    please advise results
                                    • N Offline
                                      Newbie007
                                      Hey, it worked for me thanks!
                                        mrdenmark
                                        no joy for me,heres a copy of the terminal output-
                                        pi@raspberrypi:~/MagicMirror $ rm -rf node_modules
                                        pi@raspberrypi:~/MagicMirror $ npm install
                                        npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                                        npm ERR! code ENOENT
                                        npm ERR! syscall chmod
                                        npm ERR! path /home/pi/MagicMirror/node_modules/jsesc/bin/jsesc
                                        npm ERR! errno -2
                                        npm ERR! enoent ENOENT: no such file or directory, chmod ‘/home/pi/MagicMirror/node_modules/jsesc/bin/jsesc’
                                        npm ERR! enoent This is related to npm not being able to find a file.
                                        npm ERR! enoent
                                        npm ERR! /home/pi/.npm/_logs/2019-10-25T19_15_39_049Z-debug.log
                                        pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
                                        magicmirror@2.9.0 start /home/pi/MagicMirror
                                        sh run-start.sh
                                        run-start.sh: 7: run-start.sh: electron: not found
                                        npm ERR! code ELIFECYCLE
                                        npm ERR! syscall spawn
                                        npm ERR! file sh
                                        npm ERR! errno ENOENT
                                        npm ERR! magicmirror@2.9.0 start: sh run-start.sh
                                        npm ERR! spawn ENOENT
                                        npm ERR!
                                        npm ERR! Failed at the magicmirror@2.9.0 start script.
                                        npm ERR! /home/pi/.npm/_logs/2019-10-25T19_16_09_123Z-debug.log
                                        pi@raspberrypi:~/MagicMirror $ ^C
                                        any suggestions?
                                        many thanks for your help so far!
                                          mrdenmark
                                          heres the debug log-
                                          1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
                                          2 info using npm@6.12.0
                                          3 info using node@v12.13.0
                                          4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                                          5 info lifecycle magicmirror@2.9.0~prestart: magicmirror@2.9.0
                                          6 info lifecycle magicmirror@2.9.0~start: magicmirror@2.9.0
                                          7 verbose lifecycle magicmirror@2.9.0~start: unsafe-perm in lifecycle true
                                          8 verbose lifecycle magicmirror@2.9.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                          9 verbose lifecycle magicmirror@2.9.0~start: CWD: /home/pi/MagicMirror
                                          10 silly lifecycle magicmirror@2.9.0~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
                                          11 info lifecycle magicmirror@2.9.0~start: Failed to exec start script
                                          12 verbose stack Error: magicmirror@2.9.0 start: sh run-start.sh
                                          12 verbose stack spawn ENOENT
                                          12 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
                                          12 verbose stack at ChildProcess.emit (events.js:210:5)
                                          12 verbose stack at maybeClose (internal/child_process.js:1021:16)
                                          12 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)
                                          13 verbose pkgid magicmirror@2.9.0
                                          14 verbose cwd /home/pi/MagicMirror
                                          15 verbose Linux 4.19.75-v7+
                                          16 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                                          17 verbose node v12.13.0
                                          18 verbose npm v6.12.0
                                          19 error code ELIFECYCLE
                                          20 error syscall spawn
                                          21 error file sh
                                          22 error errno ENOENT
                                          23 error magicmirror@2.9.0 start: sh run-start.sh
                                          23 error spawn ENOENT
                                          24 error Failed at the magicmirror@2.9.0 start script.
                                          24 error This is probably not a problem with npm. There is likely additional logging output above.
                                          25 verbose exit [ 1, true ]
                                            sdetweil @mrdenmark
                                            @mrdenmark great info! Let me research this
                                            • 10
                                            • 11
                                            • 3 / 11
