    MagicMirror uninstall/removal
    12 Posts 3 Posters 5.2k Views 3 Watching
    • ? Offline
      A Former User
      I downloaded the MagicMirror software and my pi did not have enough storage space for all the files. After deleting the ~/MagicMirror/ directory and making space on the pi (roughly 2GB) I now am unable to download the files as it says I already have it installed. My pi also thinks the ~/MagicMirror/ folder is still there when i try to run the command to download. Please help me Obi Wan, you’re my only hope
        Mykle1 Project Sponsor Module Developer @Guest
        @Neo237
        When you open a new terminal and type ls, is there a MagicMirror directory there?
        • ? Offline
          A Former User @Mykle1
          @Mykle1 no, I deleted the directory
            @Neo237
            Well, your OS thinks it’s there. Perhaps you should double check
            • ? Offline
              @Mykle1 I have… I’ve even tried ls -l incase its hidden, no dice.
                @Neo237
                Very odd. I wouldn’t know where to go from here. Did you try @sdetweil’s installer script to see if you encounter the same issue?
                • ? Offline
                  @Mykle1 I’m not sure, could you link me to it so I may test it?
                    @Neo237
                    bash -c "$(curl -sL https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0)"
                    Good luck.
                    EDIT
                    You should update your node and npm beforehand, I would think
                    ? S 2 Replies Last reply Reply Quote 1
                    • ? Offline
                      @Mykle1 this worked, I was using a different url to download. Thank you!
                        @Neo237
                        All credit to @sdetweil for his wonderful installer script.
                          sdetweil @Mykle1
                          @Mykle1 the script checks for node and npm and installs them first…
                          the product script does this too, but the npm side was removed from the support the script uses…
                          the script checks for the MagicMirror folder, just like the original…
                          weird…
                          glad it worked…
                            @sdetweil said in MagicMirror uninstall/removal:
                            This is why you’re the king! :thumbsup:
