    Map visible in browser but not on mirror
    7 Posts 4 Posters 9.8k Views 2 Watching
    • L Offline
      Lorenz
      I want to show a map from mapbox on my magic mirror but it is only visible when i browse to the magic mirror (localhost:192.168.1.10:8080) and not on the mirror self.
      Has someone any idea how to fix this problem?
        broberg Project Sponsor @Lorenz
        @Lorenz If it shows on other browsers then it’s probably so that the built in electron browser isn’t capable of rendering the map.
        Try running a different browser on the Pi itself and see if that sorts it.
          sdetweil
          you can also run electron on the pi, open a terminal window
          ~/MagicMirror/node_modules/electron/dist/electron url
          • L Offline
            Lorenz
            Yeah it’s because the electron browser doesn’t support webgl2. Do you know a solution for this problem?
              bhepler Module Developer @Lorenz
              @Lorenz - You can configure your mirror to use the built-in Chromium browser instead of electron. You’ll need to do the following:
              1. modify your startup script to go node serveronly instead of the usual npm start.
              2. Set the home page of the chromium browser to http://localhost:8080.
              3. Put the browser into kiosk mode.
              4. Set the browser to start on boot.
              S L 2 Replies Last reply Reply Quote 1
                sdetweil @bhepler
                @bhepler never thought of doing it that way!
                • L Offline
                  Lorenz @bhepler
                  @bhepler thank you !!
