    Issues with config file
    7 Posts 3 Posters 1.7k Views 3 Watching
      smalluk
      I have managed to install the MagicMirror app and have it working. I have managed to alter the weather to my village and the news to a different source.
      The issue is when I try a new module completely. It seems to corrupt my config file… “please create a config file” error. I restore a backup and it works again.
      I have tried using sites to check my code and they seem to be fine. I’ve used the exact code as in Readme files for the modules and still the same error.
      I have tried a few different modules and the same issue.
      I think I might be missing some dependency or something similar.
      What would you need to help me troubleshoot this?
      S Mykle1M 2 Replies Last reply Reply Quote 0
        sdetweil @smalluk
        @smalluk from the magic mirror folder do
        npm config:check
        Fix first error reported, run again
        Repeat.
        All braces and brackets must be matched, all lines should end in a comma
        Text to the right of : must be in quotes
        Numbers or true/false not in quotes
        Look at the original for examples
          Mykle1 Project Sponsor Module Developer @smalluk
          @smalluk
          This should help you. It’s an easy read.
          https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
            smalluk
            Thanks both! I’ll take a look this evening
              smalluk @sdetweil
              @sdetweil tried this and got the following, seems check isnt a valid command
              NPM check
              I tried running npm i npm-check and still the same
                smalluk
                Solved my issue with the module! Hadn’t copied to the module folder!
                1 Reply Last reply Reply Quote -1
                  sdetweil @smalluk
                  @smalluk opps. sorry there is no space between those two
                  npm config:check
